neazoi
Advanced Member level 6
This little transceiver www.home.earthlink.net/~christrask/Gnat 40.pdf uses a reflex topology for the receiving section, with applied crystal based regeneration,
Since it is used only for CW, I was thinking that audio regeneration could be applied to it, leading in a dramatic increasing of the sensitivity and audio selectivity.
Audio regeneration means that the audio bandwidth will decrease dramatically, but because this receiver is only used for CW (single audio tone) this is not a problem.
Audio regeneration also means that there must be a means of controlling the positive audio feedback to prevent the audio amplifier to oscillate.
The pdf file, describes the different sections in detail.
I would like to give me general advices of where to start, if I want to apply audio positive feedback to the transistor?
