dzakriel
Junior Member level 3
i need to build a ladder program with this PLC (A1shCPU from mitsubishi) and use GX Developer v.8 as the software. if u can help me with the list of relay an timer simbols that i can use from this PLC, since i need a relay, timer to build this program.
and if you could help me, how should i build a multiple selection program that select by a mere seletion with push button...2 push button, one in the top, n the other in the bottom. when i push the up button once, it will select program number"1", if i push the bottom button, the program that will run is program number "2", etc.
all of your experteded opinion an suggesstion will be help me alot
with regard.
with regard.
