Analog power switch 1A, 20V, control voltage < 3V is it possible to find such Switch?
Re: Analog power switch 1A, 20V, control voltage < 3V is it possible to find such Swi
I guess i can't find such part for my case :-(
it becomes to be too complicated.
Tnx,
Arye
---------- Post added at 09:39 ---------- Previous post was at 09:28 ----------
The thing that i don't understand is:
aren't there such switches in cell Phones?
aren't they using Fets that operating in 800-900 MHz?
I previously mentioned some manufacturers of GaAs switches. They have switches up to 10W power handling, which should be sufficient for the said voltage level. There are however some unclear points, e.g. switching speed or if DC capability is required. RF relays are probably the most simple solution.
Reactions: levnu
    levnu
Thanks, (i'm sorry for repeting some details).
Unclear points are due to my thought that the case is easy
every post i understand, more detail makes it more complicated
i.e. i want it to be SMT part
i didn't mentioned it before, i thought it is obvios that if there is throe hole component there will be such SMT too etc
clarfication:
- no need for DC capabily
- switch speed not so importent
importent:
- switch passing power @ 500KHz (maximum 200mOhm Rdson)
- switch blocking voltage @ 20MHz (as if there is 10KOhm on the line)
- using 3Vdc control
- SMT part possible
- not so expansive (<2$)
- i prefer some antiseriel Power Fets for i.e. Opto Mos seems not be able to pass power am i wrong?
about L or T topologies i not yet found
i hope you are not lossing your patiance w all me questions & unclear info
Thanks
Arye
---------- Post added at 11:23 ---------- Previous post was at 10:26 ----------
i listen to your advice w RF switches companies:
This one looks good although i'm not sure about the input voltage
https://www.rfmd.com/CS/Documents/FMS2031DS.pdf
- it can handle 10W power but the input voltage is limited?
- are other specification are ok?
Tnx
I asked for DC capabilities, because GaAs switches mostly use AC coupling. Isolation and insertion losses are usually specified in dB, also power in dBm, both referring to 50 ohm load. You have to translate it to your units. While isolation and power handling of the 5 or 10 W GaAs switches seems to fit, insertion losses refer to about 1 ohm switch resistance. http://www.rfmd.com/CS/Documents/RF1201DS.pdf
Thus I think, RF relays are a more simple solution. Like this **broken link removed**
They are also availabe with coaxial screen for 50 ohm impedance matching, but according to your specification, this doesn't seem appropriate.
Reactions: levnu
    levnu
first of all thank you very much for all your answers and specs of components you sent me
i appriciate this very much.
"You have to translate it to your units."
how can i translate it to my units?
this kind of solution seems better to me due to the low profile of the GaAs switch which eventually i would like to achive
as i saw RF relay's are high more than 1mm and i more positive to the fact that GaAs are low profile
so for now from all our discutions i will focus on
1. GaAs switches translation to my units
2. Anti seriel L or T topologies
3. Rf relays that will be low profile as possible (i'm sorry that i didn't mention it before, cause i didn't thought this limitation exsit, but after short research i didn't find low profile relay)
4. maybe some Pin diode topology what do you think about this? its something new i heard today
so thanks again & if you have some more Rf companies like the ones you gave me (RFm ) it will help a lot
BR
Arye
i think that i already not limited by 3Vdc control signal,
Because i found a way to increase it if needed by using charge pump
does it some how helps to find the switch i'm looking for?
- i'm still looking for L T topologies for antiseriel mosfets
- checking Pin diode switches due to low profile possiblility less than 1mm
- RF low profile relay less than 1mm
- the translation is
my power (mW) = 10^(P(dbm)/10)
am i right?
i'm adding here specification hope it will now be more possible to help
HTML:
<a href="http://obrazki.elektroda.pl/75_1320137804.jpg"><img src="http://obrazki.elektroda.pl/75_1320137804_thumb.jpg" alt="75_1320137804.jpg" /></a>
URL:
https://obrazki.elektroda.pl/75_1320137804.jpg
Tnx
Arye
RF relay are too high could find somthing around 1mm hieght,
ST semiconductors recomanded:
"unfortunately we do not have this kinds of switchs working at so high frequencies.
What we could suggest is to have a look to the START499ETR (which is a RF Bipolar Product housed in SOT343) and to check if it might fit your application. Please find here enclosed its datasheet.
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00186036.pdf"
i don't know to analys if its suitable for my application?
could you please advice me?
