chemelec
Full Member level 4
- Joined
- Jul 21, 2007
- Messages
- 218
- Helped
- 46
- Reputation
- 92
- Reaction score
- 42
- Trophy points
- 1,308
- Location
- BC. Canada
- Activity points
- 2,368
Can't a digital meter show capacitor leakage? Or only analog meters?
If you have a 400 Volt Capacitor, and your meter is Only Applying a LOW VOLTAGE (Under 10 Volts) It Can't determine Leakage at the 400 Volt rating. Or Even at just 50 volts.
I have a Sencore, LC102 Capacitor and Inductor Tester.
It Tests ACTUAL Leakage with Voltages up to 1000 Volts.
It Also tests for Capacitance Value, ESR and Dielectric Absorbtion.
at my work they do test diodes using an analog meter set a RX1, Why is that?
Only because it doesn't need a Higher Range to give a Reading.
But after over 40 years of Designing, Manufacturing and Servicing, I PREFER the "DIODE TEST" on a Digital Meter.
In My Opinion, it gives a Better Indication of the Diodes operation.
