just put ground or supply (depending on which your signal is reference to) around your signal.
In this case you could shield it by a large grounded metal patch on m2 between the crossing.... if sensitive signals is in m3 and clock is in m1, which is perpendicular to sensitive signal i.e m3. what should i do to shield the sensitive
what is use of putting gnd or supply around it
let say example if sensitive signals is in m3 and clock is in m1, which is perpendicular to sensitive signal i.e m3. what should i do to sheild the sensitive
How to decide - we need to shield both sides with vcc or vss or one side vcc and the other side vss?
May be because the designer knows which node is easier to reach. A (good) designer thinks about the layout of his design!But why the designers specify it? Sometimes ask to shield both sides with vcc or vdd or sometimes one side vcc and other side vss.
Isolation doesn't mean shielding from capacitive RF coupling!... if two different signals are in different metals, I don't think there is any need of shielding. Suppose there are two signals - one high frequency clock signal in m2 and other critical signal in m3.
The critical signal don't need any shielding to get protection from m2 clock signal.
Because during fabrication all m2 are deposited first, then on top of it insulator is placed, and then on top of it m3 is deposited, so the isolation is already taken care of.
Inductive coupling by current flow.Other than the capacitive coupling is there any other way that the sensitive signal can become noisy due to the influence of high frequency signal?
You mentioned that the designer knows which node is easier to reach. Can you explain it a bit as I can't make out what the edge is achieved with the position? Please explain.
By the way what is inductive coupling?
Actually not the clock (frequency) itself, just the clock edges.Btw if you'll add shielding you'll also add parasitic cap between clock and shielding wire. Therefore you'll slow this clock.
True: just at the crossings, as the OP asked.So I usually place shield just where it's needed.
