barry
Advanced Member level 7
- Joined
- Mar 31, 2005
- Messages
- 6,554
- Helped
- 1,206
- Reputation
- 2,424
- Reaction score
- 1,434
- Trophy points
- 1,393
- Location
- California, USA
- Activity points
- 35,649
Re not caring too much about distortion......except that it defeats my purpose if the 'victims' can hear the additional harmonics on top of the 17Hz infrasound.
1% distortion is inaudible to most people, especially at 17Hz.
Why would you create a triangle wave, convert it to PWM, and then filter it BACK to a triangle wave??? Talk about over-engineering.You can modulate a 555 to produce a low (or high) freq PWM waveform which, when filtered will give a near sine wave, a simple C -R blocking ckt will then remove the DC to give a 0v reference for driving an amplifier. If you modulate with a triangle wave (17 Hz) and then filter you will get good enough.
From a 12V supply a simple darlington emitter follower could be used to buffer the filtered 555 output (with DC average level in place) and then feed to the speaker - with a blocking cap ( 220uF 63V) to prevent DC from entering the speaker.
This would suffice for the stated app.
