Altium schematic to pcb import problems
sobj
Newbie level 2
Newbie level 2
Hi all,
I am new to altium. I am using version 14. My problems when importing changes (design > import changes)
1. unknown pin.
2. failed to add class member.
I imported an eagle library. Copied two components from this library into an custom altium library - image 3. When I copied them I made sure the pins designators match the pads designator - image 1 & image 2
When I try to import changes, it's showing that pins 2, 3, 4 as unknown pins but not pin 1. It happens for both the parts :( - image 4
I've read most of the threads on these issues but I can't seem to solve them.
I am attaching screenshots of one of the problematic parts.
Thank you so much.
-S
Hope this helps someone who is confused and frustrated.
This what I did:
1. Save schematic .SchDoc
2. Save pcb .PcbDoc.
3. Save project .PrjPcb.
4. Remove pcb doc from project (right click on .PcbDoc -> remove from project).
5. Add new pcb doc to project (right click on .PrjPcb -> add new to project -> pcb).
6. Save new pcbdoc. Name does not matter.
7. Both of these work - from .SchDoc [design -> update pcb document] OR from .PcbDoc [design -> import changes].
8. Save this PcbDoc.
9. Remove this new PcbDoc from project.
10. Add the OLD pcbDoc to project (right click on PrjPcb -> add existing to project).
11. Repeat step 7.
12. Delete the new PcbDoc using explorer.
13. Get up from your chair and dance/rejoice in silence.
14. Get back to work.
I have no idea why this worked.
Let me know if this might be one of solutions and I will mark it as solved.
