Algorithm to find out how much Torque is necessary by a DC motor to rotate a rotor...
... the Mi of the shaft was calculated including the blades right? how can i calculate the Mi of the blade again???
Seems this was a misunderstanding on my side about the shaft: I thought with shaft you thought of the axis of the motor. I don't think you have to recalculate the Mi value.
also i understood all those calculation parts but i was wondering what formula or how did you derive this expression angle = (α/2)*t2
can you direct me what expression or formula is it?
i sense it is a expression to know how much amount of radians/degree has the object rotated with the given angular acceleration in given time t.
Right. It's just analog to the equation for the covered distance of linear movement (s) of a mass (m) accelerated by the acceleration (a) during a time (t):
s = (a/2)*t2 , where a = F/m (F=force [N])
If you need a more exact explanation, I'd recommend to study thoroughly this Wiki explanation - which I've linked already in my first answer to you.
Sorry,im back after some gap,
Another simple doubt was raised,the SI unit of Moment of Inertia is kg.m² not Nm² right??
[original post] In that case,each blade weighs 1.5kg and length is 1.5meter each..
hence the Moment of Inertia = (mL²)/3 = (1.5kg X (1.5 meter)²)/3 = 1.125 kg.meter² of Moment of Inertia
as there are 3 Blades,so the total Mi is 1.125 * 3 = 3.375 kg.meter² (or 33Nm²).
so i want to accelerate this shaft with 3.375 kg.m² of Mi to 2500 RPM in 15 seconds..
2500 RPM = 262 Rads/Second
Acceleration from 0 rads/se to 262 rads/sec in 15 seconds
so 262/15 = 17.46 rads/sec² Acceleration
now T = Mi X Acc
now is the Mi unit in kg.m² or Nm²?
if i plug in kg.m²,i get T = 3.375kg.m² * 17.46 rads/sec² = 58.92 Newton Meter of Troque,which looks kinda realistic number
but if i plug in Mi in Nm² unit,then its becomes T = 33Nm² X 17.46 = 576 Newton meter of Torque,which doesnt look quite realistic...
so which unit of Mi is used in T = Mi X Acc
is it Nm² or kg.m²?
,and what is the unit of T then?...
thank you
Another simple doubt was raised, the SI unit of Moment of Inertia is kg.m² not Nm² right??
Yes, you are right: the original error was here in your very first question of this thread (and I didn't notice it either, before now):
the weight of the each blade is 1.5 kg/14.7 Newtons
It is not allowed to use the acceleration of gravity for the conversion of [kg] into [N*s2/m] (not simply [N]!), because not the gravity's acceleration will be used, but the motor's.
Hence 1kg = 1N*s2/m
So your above calculation seems correct:
T = 3.375kg.m² * 17.46 rads/sec² = 58.92 Newton Meter of Torque
[kg.m2 * [rads]/s2] =[(N*s2/m)*m2 * [[rads]/s2] = [Nm]
[rads] is a dimensionless unit.
Merry Christmas! - erikl
