Hi, I'm still new in using ADS. So, I tried to design a voltage double rectifier. But, when I tried to simulate it gives me a warning that 'no source was found'. May I know what the problem is?
it's quite a while ago since I used ADS, but is it even possible to run both analyis at the same time? Have you tried to run the simulation when only TRANSIENT or S-PARAMETERS is enabled. Further, is P_1Tone actually connected, its connection might be coverd by the width (1.5 mm) of the MLOC.
