volker@muehlhaus
Advanced Member level 6
im using microstrip and not coplanar. what im looking for is ground separation between micro strip runners.
Understood, and GCPW would be a possible way to create these side ground strips.
But you can also draw them by hand in layout: rectangle or polygon on layer "cond" for metal, circle for vias on your via layer. Not sure what you via layer is - typically it is "hole" but you can check in layout.
how if i need accurate electrical model from schematic?
