AMAN SAXENA_E_S
Newbie
ADC WORKING Copy - Wokwi ESP32, STM32, Arduino Simulator
Run IoT and embedded projects in your browser: ESP32, STM32, Arduino, Pi Pico, and more. No installation required!
[Moderator action]
- Paste here the code took from the external link.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 void timerSetup() { // Configure Timer1 for Fast PWM mode, non-inverted, 8-bit resolution TCCR1A = (1 << WGM10) |(1<<COM1A0)|(1 << COM1A1)|(1<<WGM11); // Fast PWM 10 BIT, non-inverted mode TCCR1B = (1 << WGM12) | (1 << CS11) |(1<<CS10); // Prescaler = 64 ICR1 = 1023; // FREQUENCY 250HZ OCR1A= 300; //INITIAL dutyCycle } void setup() { // Set PORTB pin 1 (OC1A) as output for PWM DDRB |= (1 << PB1); // Initialize Serial communication Serial.begin(9600); // Setup the timer timerSetup(); // Configure ADC ADMUX = 0x00; // Use ADC0, Vref = AVcc ADCSRB = 0x00; // Free-running mode ADCSRA |= (1 << ADEN) | (1 << ADATE) | (1 << ADIE) | (1 << ADPS2); // Start the first ADC conversion ADCSRA |= (1 << ADSC); } void loop() { // Main loop remains empty; all work is done in interrupts } ISR(ADC_vect) { // Read the ADC value and update the PWM duty cycle OCR1A = ADC; // dutycycle value equals provided by adc Serial.println(ADC); ADCSRA |= (1 << ADSC); // WORKING WHEN MANUALLY START }
