wwfeldman
circuit attached
when the wires A, B or C are connected between their respective op amps and the AD75019, the voltage on the output
of the op amp reads about 0.5 V
when the wires A, B or C are disconnected from their respective op amps and the AD75019, the voltage on the output
of the op amp reads correctly, per the resistor divider.
the AD75019 appears to be loading the op amps or shorting them to ground(?).
a second AD75019 behaves the same way.
all power and ground are correct.
if the output of the AD75019 is disconnected, the op amp output behaves the same way.
the data, the serial clock, and the parallel clock are ok.
what did I do wrong?
what needs to be done to fix it?
