[SOLVED] Active Devices & Passive Devices
I think you can waste a lot of time and energy worrying about something that is really an imprecise, arbitrary definition. Some definitions and ambiguities are given here: Passivity (engineering)
Keith
Thanks for the link. Interestingly, the suggested Incremental passivity definition refers to some borderline cases, that have been mentioned in the discussion before: diodes with monotonic versus non-monotonic voltage-current characteristic, and e.g. relays. Personally, I tend to emphasize the functionality of a device in a particular circuit. Devices, that act as a parametric amplifier (e.g. diodes, inductors) would be also considered active in this role. But as said by many contributors, all these defintions are arbitrary.
The controlling of electrons by switch is not same as control of electrons by active devices.
Switch is just opening and closing circuit. If you think that switch is controlling electrons then rheostat is also a control device. What would you name the rheostat ? an active device? definitely not.
Generally, the diode is active device, but is ideal diode is still passive components.
一般将二极管归入有源器件,但理想二极管仍然是无源器件。
Is this a question?
If not and if this really is your understanding I think you should read some other contributions within this thread.
