About functional library - an error occurs in model
kollayliu
Newbie level 6
Newbie level 6
I add a opamp macromodel from the functional library of cadence to my schematic. The model's parameters are setted by default, and the last parameter is 'macro name=f_op1v1c'. The schematic is simulated in Analog environment, but an error is given that X2 is an instance of undefined model of f_op1v1c. Does the error means that the simulation of the model needs a model library, just like the simulaion of transistors? If it is true, How can I get this library? Thank you!
