If we use QAM-16 then is it possible to find baud rate ? If yes then how?
Ok I'll do some simple calculation using this equations to solve this issueDon't want to convert baud rate into frequency, I'm trying to say,
Suppose the frequency is: 12000HZ, how do we find the baud rate ?
and I've read all the posts above, and didn't understand, so I decided to register and ask
Well said, but this is a published resource and didn't see anywhere mentioned that this wikipedia's article on baud.halee awan said:In telecommunications and electronics, baud (/ˈbɔːd/, unit symbol "Bd") is........
.......................a measure of the gross bitrate R as: R= fs * log2(M).
yep exactly this is Baud - Wikipedia, the free encyclopedia, then?
But its correct
Then it supposed to be closed ..Since it is published from wikipedia I also suppose it's correct, then?
hi,
Baud Rate is the total number of bits i.e 1's and 0's transmitted per second.
And Frequency is number of complete (sinusoidal or square or triangular ) cycles per second.
Therefore, if only the sequence of 0's & 1's are transmitted then the frequency is 9600/2=4800 Hz
Code ASM - [expand] 1 2 3 4 5 6 [/QUOTE] baud rate is the rate of symbol changes...symbol can be of 1 bit, 2 bit , 3 bit etc.... Where as frequency is the inverse of rate of lowest unit in a digital transimission...
