facepalmThe phase difference between the two outputs is 90 degree.Please correct me if I am wrong.
How will I connect this this to my system.
My system can take only one input which is a 90 degree phase shift of the I/P signal.
Below is my system block diagram
No, that will not help you.
I will check one more time with the team(Optics Team).What they told me is that they have an input sine wave of frequency which varies from 5K-50Khz and they needIf you explained why you need this phase shift and what role it plays in your system, it's likely we can find a way to get what you want.
ALC means "Automatic Level Control (ALC) Circuit"Please correct me if I am wrong.ALC circuit
I checked again if "output amplitude little less than 1V if also fine,we can amplify the phase shifted signal". this is what I received.Initial intention is to create phase shifted signalOutput signal:
- should track input magnitude
- should maintain 1 V (pk, rms ?) independent of input magnitude
- either of both
Sine wave comes from Function generator.Where does Sine in come from? Sig Gen, VCO? S/W?
It is better to create IQ from 2f then convert to sine or use Nxf then IQ then convert each to sine using R-DAC /N registers for perfect phase.
Do you agree?
Does DC bias matter?
Sine wave frequency is 5Khz to 50khzhow fast does the frequency change? Or Is it static? What is the required response time? I’m thinking a digital solution might be simplest.
If you do not think harder about your design specs and answer my questions this is going to sound like an immigration interrogation.
That's not what I asked. I asked how fast the frequency changed, not what the range was.Sine wave comes from Function generator.
--- Updated ---
You know, they make frequency generators with quadrature (90 degree) outputs...Input is coming from external world like function generator.
