drwho78
Full Member level 3
miso mosi schematic at89
You should look at the beginning of this thread.
Use the schematics isp_C_v5.PDF, this is the at89isp cable with the following naming changes:
Mappings of the pins are as follow:
TCK --> SCK
TDO --> MISO
TMS --> RST
TDI --> MOSI
The LPT connections are on page 2 of the PDF file. You may want to use 68 Ohms instead of 100 Ohm resistors if you can't get it to work.
TCK --> SCK
TDO --> MISO
TMS --> RST
TDI --> MOSI
