i am new one to programmers.Can you provide the source code for this programmer?
thanks in advance....
But no one providing the source code for the software which runs on computer..
Check here for the changed firmware for atmega8 which can support 89S series micros.
program the chip with code you know. Lock the chip. Now read the chip. Post the code here. I will bet you that the code is 00010203040506.......
compare the two files. they won't be the same. EVEN THOUGH THE EZDL4.exe program gives a message "lock failed" it still works. The atmel code in the programmer takes care of locking the device. It is very reliable and works well.
No...All are providing source file for controller.
hello ctownsend
good work
realy appreciated
if u mix these two programmer it will become one fo the best programmer that will burn atmel C and S series and will fulfill the demand of many students
and
Why go else where while you have it on EDA board too. Here is the threda related to the same with 3 pages of discussions.here u can find the solution u must first stablish a avr programmer then use it to program 8051 using usb port http://www.8051projects.info/content/8051-tools/14-usb-8051-avr-programmer.html
Kindly "Quote" which schematic you are refering to.Hi in the circuit diagram what is connected at the pins p1.4,p1.5,p1.6,p1.7 (MISO,MOSI,SCK,RST)
