speedEC
Full Member level 6
battery is lead acid type:
Battery is charging now correctly. Now, the voltage of the battery increases to 6.83v.
Output Voltage set to charge the battery = around 7.5v
Voltage Between PIN2 and GND = +7.74v
Voltage Between PIN5 and GND = +7.84v
Voltage Between PIN5 and PIN2 = + 0.08v
*Battery Connected to the Circuit
Pl let me know your suggestion on these readings I got.
thanks.
---------- Post added at 20:38 ---------- Previous post was at 20:32 ----------
If battery is not connected to the Circuit,
the Voltage Between PIN5 and PIN2 = + 0v
thanks.
