Easy peasy
Advanced Member level 6
using 6 diodes instead of 3 gives better utilisation of the sec windings, a smaller lighter transformer, and you get to spread the heat over 6 diodes. Using only positive pulses out of a Y winding is not the flashest way to run a transformer...
with a decent output choke the current is square pulses, the phase angle power factor is OK, and the true power factor is not too bad either, a lot bigger choke needed for the 3 diode setup ...
