newbie_hs
Full Member level 2
I need to design a PCB for RF Application.
The board contains jsut 4 sma connectors .Connected as shown below.
The frequency of operation is 20Ghz. Trace impedance should be 50 Ohm.Current 1A
Initially I decided to use 2layer board.Then I was told to use 4 layer board .The reason was told is it will help to reduce the trace width.
May I know is there any relation between PCB trace width and number of layers
