Junus2012
Advanced Member level 5
Dear friends,
In the early steps of designign the op-amp is to select the appropreiate value of overdrive voltage (Vov = Vgs-vth) to meet different criteria (ICMR, OCMR, ...etc)
in the Jakob book procedure he use for long channel transsitor the rule of Vov = 5% VDD. in Holberg and Gregorian book the authors stated that if (Vgs -Vth) < 100 mv then transistor enter in to the weak inversion region, in the David Benkley book if Vov < -75 mv then transistor is working in the weak region.
You see the definsion from David book (attached a picture from it) is far from other defision, why ?
Second thing, the overdrive voltage is depending on the transistor current and size, Vov = root(2Id/K(W/L)), if we reduce the current or increasing W/L both will reduce the Vov, however I see people only talking about the weak inversion when they are dealing with small currents.
Can you please explain me a better approach to say whether my transistor is in strong, moderate and weak inversion region ?
Thank you very much
Thank you very much
