yes
where is the return path of the AC current?
ac voltage is applied to a conductor inside of another hollow conductor
Is there any one type of coax that might be better to experiment with. The coax I have laying around is stranded wire on outside.
there is a distinct difference between EMF and Voltage, even though they look a lot alike and they have the same units
Would passing current through outer conductor provide better coupling to inner conductor. As opposed to passing current through inner conductor.
Your setup is unclear, as mentioned above. The normal use of coax is to have current on both inner and outer conductor, with opposite direction. Signal path and return path, you know ....
I understand post #4 quite differently.But if I'm understanding Easy peasey correctly it wouldn't work. No matter how many turns of a coaxial like conductor you wind on a core.
potential (voltage) is the energy per unit charge based on static charge distributions ...
Applying a voltage as such won't generate a current, thus no magnetic field and no induced voltage. Wwfeldmann assumes apparently that the voltage drives a current and asks about the return path...
when the "voltage is caused by "motion" as described by faraday's law, there is no potential difference, but there is an emf...
