thederke
Newbie level 6
Hey everyone, I'm designing a discrete op amp with the following specs (per the professor):
1. Two inputs one plus , one negative
2. Capable of driving a 50 K ohm load to + 10 V
3. Frequency response DC - 10MHz + 2 db.
4. The input impedance must be at least 1 Megohm
5. The output impedance must be less than 50 ohms
8. Temperature range: 25 -- 100oC
9. The gain must be between 1000 - 1500
I found one previous post on here that didn't help me too much, apparently this isn't an uncommon project. I'm having trouble reaching the gain values, highest I can get is around 200. See attached circuit and waveform; note the differential input stage, the high gain stage (CEs), and the buffer stage (havent tweaked that yet).
What tricks do I have at my disposal for raising the gain more? It seems to distort if I try to raise resistor values. Trying to avoid PMOS components due to availability but if I must then I must..
Any help or hints are appreciated!
