jean12
Advanced Member level 2
Hello,please help,I am using PIC18F46K22 for generating 3PWM signals to control a full bridge,three phase circuit but the problem I have is that the output voltage is very low at 345mv,could you please help me to handle this problem,I even disconnected the load(IGBT driver) and measure only the output of the PIC but the voltage remain the same at 345mv.
I am judging that the mistake might be from the configuration bits or the way I used for setting data direction on the ports,here below are my two files`s codes I am using:
1.Program
2.File to include:
Please help to sort this out!!
1.Program
PHP:
include <p18F46K22.inc>
include <3im_vf.inc>
; CONFIG1H
CONFIG FOSC = HSHP ; Oscillator Selection bits (HS oscillator (high power > 16 MHz))
CONFIG PLLCFG = OFF ; 4X PLL Enable (Oscillator used directly)
CONFIG PRICLKEN = ON ; Primary clock enable bit (Primary clock is always enabled)
CONFIG FCMEN = ON ; Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
CONFIG IESO = OFF ; Internal/External Oscillator Switchover bit (Oscillator Switchover mode enabled)
; CONFIG2L
CONFIG PWRTEN = OFF ; Power-up Timer Enable bit (Power up timer disabled)
CONFIG BOREN = SBORDIS ; Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
CONFIG BORV = 190 ; Brown Out Reset Voltage bits (VBOR set to 1.90 V nominal)
; CONFIG2H
CONFIG WDTEN = OFF ; Watchdog Timer Enable bits (Watch dog timer is always disabled. SWDTEN has no effect.)
CONFIG WDTPS = 32768 ; Watchdog Timer Postscale Select bits (1:32768)
; CONFIG3H
CONFIG CCP2MX = PORTC1 ; CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
CONFIG PBADEN = OFF ; PORTB A/D Enable bit (PORTB<5:0> pins are configured as digital I/O on Reset)
CONFIG CCP3MX = PORTB5 ; P3A/CCP3 Mux bit (P3A/CCP3 input/output is multiplexed with RB5)
CONFIG HFOFST = OFF ; HFINTOSC Fast Start-up (HFINTOSC output and ready status are not delayed by the oscillator stable status)
CONFIG T3CMX = PORTC0 ; Timer3 Clock input mux bit (T3CKI is on RC0)
CONFIG P2BMX = PORTD2 ; ECCP2 B output mux bit (P2B is on RD2)
CONFIG MCLRE = EXTMCLR ; MCLR Pin Enable bit (MCLR pin enabled, RE3 input pin disabled)
; CONFIG4L
CONFIG STVREN = ON ; Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
CONFIG LVP = OFF ; Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
CONFIG XINST = OFF ; Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
; CONFIG5L
CONFIG CP0 = OFF ; Code Protection Block 0 (Block 0 (000800-003FFFh) not code-protected)
CONFIG CP1 = OFF ; Code Protection Block 1 (Block 1 (004000-007FFFh) not code-protected)
CONFIG CP2 = OFF ; Code Protection Block 2 (Block 2 (008000-00BFFFh) not code-protected)
CONFIG CP3 = OFF ; Code Protection Block 3 (Block 3 (00C000-00FFFFh) not code-protected)
; CONFIG5H
CONFIG CPB = OFF ; Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
CONFIG CPD = OFF ; Data EEPROM Code Protection bit (Data EEPROM not code-protected)
; CONFIG6L
CONFIG WRT0 = OFF ; Write Protection Block 0 (Block 0 (000800-003FFFh) not write-protected)
CONFIG WRT1 = OFF ; Write Protection Block 1 (Block 1 (004000-007FFFh) not write-protected)
CONFIG WRT2 = OFF ; Write Protection Block 2 (Block 2 (008000-00BFFFh) not write-protected)
CONFIG WRT3 = OFF ; Write Protection Block 3 (Block 3 (00C000-00FFFFh) not write-protected)
; CONFIG6H
CONFIG WRTC = OFF ; Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
CONFIG WRTB = OFF ; Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
CONFIG WRTD = OFF ; Data EEPROM Write Protection bit (Data EEPROM not write-protected)
; CONFIG7L
CONFIG EBTR0 = OFF ; Table Read Protection Block 0 (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
CONFIG EBTR1 = OFF ; Table Read Protection Block 1 (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
CONFIG EBTR2 = OFF ; Table Read Protection Block 2 (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
CONFIG EBTR3 = OFF ; Table Read Protection Block 3 (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
; CONFIG7H
CONFIG EBTRB = OFF ; Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
#define TIMER0_OV_FLAG 0
#define OFFSET1_FLAG 4
#define OFFSET2_FLAG 5
#define OFFSET3_FLAG 6
#define MOTOR_DIRECTION 7
#define MOTOR_RUNNING 1
#define DEBOUNCE 0
#define ON_OFF_FLAG 1
#define DELAY_COUNT1 0xFF
#define DELAY_COUNT2 0xFF
;RAM locations in Access bank, uninitialized
UDATA_ACS
TABLE_OFFSET1 res 1 ;Phase1 offset to the Sine table(0)
TABLE_OFFSET2 res 1 ;Phase2 offset to the Sine table(120)
TABLE_OFFSET3 res 1 ;Phase3 offset to the Sine table(240)
COUNTER res 1 ;General counters
COUNTER1 res 1
FLAGS res 1 ;Flags registers used to indicate different status
FLAGS1 res 1
FREQ_REF_H res 1 ;Referance Frequency input in counts
FREQ_REF_L res 1
FREQUENCY res 1
CCPR1L_TEMP res 1 ;Temporary locations
CCPR2L_TEMP res 1
CCPR3L_TEMP RES 1
PWM_DUTYCYCLE RES 1
TEMP res 1
TEMP1 res 1
TEMP_LOCATION res 2
SINE_TABLE res 0x14 ;Sine table
STARTUP code 0x00
goto Start ;Reset Vector address
CODE 0x08
goto ISR_HIGH ;Higher priority ISR at 0x0008
PRG_LOW CODE 0x018
goto ISR_LOW ;Lower priority ISR at 0x0018
PROG1 code
Start
;Initialization of the Ports and timers
clrf FLAGS ;Clear the flags
BSF TRISB,0
BCF TRISB,5;PWM output 3
BCF TRISC,1;PWM output 1
BCF TRISC,2 ;PWM output 2
BSF TRISB,RUN_STOP_KEY ;set input pin for push button
BSF TRISB,FWD_REV_KEY ;set input pin for push button
CLRF LATB
CLRF LATC
CLRF PORTB
CLRF PORTC
bsf TRISB,FAULT_BIT ;Fault input from driver
movlw 0x0C
movwf CCP1CON ;CCP1 and CCP2 configured to PWM
movwf CCP2CON
movwf CCP3CON ;CCP3 configured to PWM
MOVLW 0x01
MOVWF PSTR1CON ;configure PWM controlling registers
MOVWF PSTR2CON;configure PWM controlling registers
MOVWF PSTR3CON;configure PWM controlling registers
MOVLW 0X80
MOVWF PWM1CON;configure PWM controlling registers
MOVWF PWM2CON;configure PWM controlling registers
MOVWF PWM3CON;configure PWM controlling registers
CLRF ECCP1AS;configure PWM controlling registers
CLRF ECCP2AS;configure PWM controlling registers
CLRF ECCP3AS;configure PWM controlling registers
CLRF CCPTMRS0 ;select Timer 2 to use for PWM
bsf T2CON,2 ;Timer2 ON
movlw PR2_VALUE ;Load PR2 value to PR2 register
movwf PR2 ;place PR2_VALUE into PR2 register
movlw 0x90
movwf CCPR1L
movwf CCPR2L
MOVWF CCPR3L
movlw 0x81 ;Timer1 prescaler 1:2
movwf T1CON
call Init_Motor_Parameters ;Initialize motor parameters
call COPY_TABLE_TO_RAM
;Initialize ADC registers
movlw ADCON0_VALUE ;From ".inc" file
movwf ADCON0
movlw ADCON1_VALUE ;From ".inc" file
movwf ADCON1
movlw 0x33 ;RA0,RA4,RA5 inputs,RA2&RA3-Outputs
movwf TRISA ;
; bsf DRIVER_ENABLE_PORT,DRIVER_ENABLE_BIT ;Enable the driver chip
;Timre0 Initialization with prescaler
movlw 0X83 ;Load the T0CON with value
movwf T0CON ;TMR0 ON and prescalar is 1:16
movlw 0xF8 ;Timer0 Initialisation
movwf TMR0H
movlw 0x5E ;
movwf TMR0L
bsf INTCON,TMR0IE ;Timer0 overflow Interrupt enable
bsf PIE1,TMR2IE ;"Timer2 to PR2 match" Interrupt enable
bsf PIE1,TMR1IE ;Timer1 overflow Interrupt enable
bsf PIE1,ADIE ;AD Converter over Interrupt enable
bcf IPR1,ADIP ;Low priority for ADC interrupt
bsf INTCON,RBIE ;PortB interrupt enable with low priority
bcf INTCON2,RBIP ;for Fault checking
movlw 0x093 ;Power ON reset status bit/Brownout reset status bit
movwf RCON ;and Instruction flag bits are set
;Priority level on Interrupots enabled
bsf INTCON,PEIE ;Port interrupts enable
bsf INTCON,GIE ;Global interrupt enable
;Main loop where the program will be looping
MAIN_LOOP
btfss FLAGS,TIMER0_OV_FLAG ;back from Timer0 overflow?
bra bypass ;No
call UPDATE_PWM_DUTYCYCLES ;Yes, update the PWM duty cycle with new value
call UPDATE_TABLE_OFFSET ;Update 3 offsets
bcf FLAGS,TIMER0_OV_FLAG ;Clear the flag
bypass
call SET_ADC_GO ;Start AD conversion
call KEY_CHECK ;Check keys change
bra MAIN_LOOP
;Higher priority interrupt service routine
;"Timer2 to PR2 match", "Timer1 overflow" and Timer0 overflow are checked
ISR_HIGH
btfsc PIR1,TMR2IF ;Timer2 to PR2 match?
bra TIMER2_PR2_Match
; btfsc PIR1,TMR1IF ;Timer1 overflow Interrupt?
; bra TIMER1_OVERFLOW
btfsc INTCON,TMR0IF ;Timer0 overflow Interrupt?
bra TIMER0_OVERFLOW ;Yes
RETFIE FAST
;MODIFIED BY MYSELF FOR REMOVING TIMER 2 NOT USED FOR PWM GENERATION
TIMER2_PR2_Match
bcf PIR1,TMR2IF ;
; tstfsz CCPR3L_TEMP ;If Software PWM duty cycle=0, then
tstfsz CCPR3L
bra PWM3_NOT_0 ;no need to set the PWM3 port pin
RETFIE FAST
PWM3_NOT_0
movlw 0xFF ;Higher byte of Timer1 loaded with FFh
movwf TMR1H
movff CCPR3L_TEMP,TMR1L
RETFIE FAST
;TIMER1_OVERFLOW
; bcf PWM3_PORT,PWM3_PORT_PIN ;PWM3 pin cleared after the duty cycle time expires
; BCF PORTB,5
; bcf PIR1,TMR1IF
; RETFIE FAST
TIMER0_OVERFLOW ;TMR0 overflow ISR
movff FREQ_REF_H,TMR0H ;Load the Higher byte of SpeedCommand to TMR0H
movff FREQ_REF_L,TMR0L ;Load the Lower byte of SpeedCommand to TMR0L
bsf FLAGS,TIMER0_OV_FLAG
bcf INTCON,TMR0IF ;Clear TMR0IF
RETFIE FAST
;Lower priority interrupt service routine
;Change on PortB(Fault checking) interrupt & "ADConversion over" interrupt are checked
ISR_LOW
btfsc INTCON,RBIF ;RB interrupt?
bra CHECK_FAULT ;Yes
btfsc PIR1,ADIF
bra AD_CONV_COMPLETE
RETFIE FAST
CHECK_FAULT
movf PORTB,W ;Check for fault bit
btfss WREG,FAULT_BIT
bra THERE_IS_FAULT
call RUN_MOTOR_AGAIN ;Fault cleared?
bcf INTCON,RBIF ;Run motor again
RETFIE FAST
THERE_IS_FAULT ;Yes,fault is there
call STOP_MOTOR ;Stop motor
bcf INTCON,RBIF
RETFIE FAST
AD_CONV_COMPLETE ;ADC interrupt
movff ADRESH,FREQUENCY
movlw 0x14 ;Minimum Frequency set to 5Hz (scaling factor X4)
cpfsgt FREQUENCY
movwf FREQUENCY
movlw 0xF0 ;Limiting V/F to F= 60Hz (scaling factor X4)
cpfslt FREQUENCY
movwf FREQUENCY
movwf PORTD ;Out frequency to PORTD for set value
bcf PIR1,ADIF ;ADIF flag is cleared for next interrupt
RETFIE FAST
;This routine will update the PWM duty cycle on CCPx according to the
;offset to the table with 0-120-240 degrees.
;This routine scales the PWM value from the table based on the frequency to keep V/F
;constant.
movf TABLE_OFFSET1,W
movf PLUSW0,W
bz PWM1_IS_0
mulwf FREQUENCY ;Table_value X Frequency
movff PRODH,CCPR1L_TEMP
bra UPDATE_PWM2
PWM1_IS_0
clrf CCPR1L_TEMP ;Clear the PWM duty cycle register
bcf CCP1CON,4
bcf CCP1CON,5
UPDATE_PWM2
movf TABLE_OFFSET2,W
movf PLUSW0,W
bz PWM2_IS_0
movff PRODH,CCPR2L_TEMP
bra UPDATE_PWM3
PWM2_IS_0
clrf CCPR2L_TEMP ;Clear the PWM duty cycle register
bcf CCP2CON,4
bcf CCP2CON,5
UPDATE_PWM3
movf TABLE_OFFSET3,W
movf PLUSW0,W
bz PWM3_IS_0
movff PRODH,CCPR3L_TEMP
bra SET_PWM12
PWM3_IS_0
clrf CCPR3L_TEMP ;Clear the PWM duty cycle register
bcf CCP2CON,4
bcf CCP2CON,5
;ABOVE WERE MODIFIED BY MYSELF
SET_PWM12
btfss FLAGS,MOTOR_DIRECTION
bra ROTATE_REVERSE
movff CCPR1L_TEMP,CCPR1L
movff CCPR2L_TEMP,CCPR2L
BANKSEL CCPR3L
movff CCPR3L_TEMP,CCPR3L
; movff CCPR3L_TEMP,PWM_DUTYCYCLE
; movff PWM_DUTYCYCLE,CCPR3L
bsf PORT_LED1,LED1
return
;/DEACTIVATE TWO DIRECTION OPERATION BY MYSELF
ROTATE_REVERSE
movff CCPR2L_TEMP,CCPR1L
movff CCPR1L_TEMP,CCPR2L
MOVFF PWM_DUTYCYCLE,CCPR3L
bcf PORT_LED1,LED1
return
;This routine Updates the offset pointers to the table after every access
UPDATE_TABLE_OFFSET
btfss FLAGS,OFFSET1_FLAG ;If set incr. on table
bra DECREMENT_OFFSET1
movlw (SINE_TABLE_ENTRIES-1) ;Check for the last value on the table
cpfslt TABLE_OFFSET1
bra CLEAR_OFFSET1_FLAG
incf TABLE_OFFSET1,F ;Increment offset1
bra UPDATE_OFFSET2
CLEAR_OFFSET1_FLAG
bcf FLAGS,OFFSET1_FLAG
DECREMENT_OFFSET1
dcfsnz TABLE_OFFSET1,F ;Decrement offset1
bsf FLAGS,OFFSET1_FLAG
UPDATE_OFFSET2
btfss FLAGS,OFFSET2_FLAG ;If set incr. on table
bra DECREMENT_OFFSET2
cpfslt TABLE_OFFSET2
bra CLEAR_OFFSET2_FLAG
incf TABLE_OFFSET2,F ;Increment offset2
bra UPDATE_OFFSET3
CLEAR_OFFSET2_FLAG
bcf FLAGS,OFFSET2_FLAG
DECREMENT_OFFSET2
dcfsnz TABLE_OFFSET2,F ;Decrement offset2
bsf FLAGS,OFFSET2_FLAG
UPDATE_OFFSET3
btfss FLAGS,OFFSET3_FLAG ;If set incr. on table
bra DECREMENT_OFFSET3
cpfslt TABLE_OFFSET3
bra CLEAR_OFFSET3_FLAG
incf TABLE_OFFSET3,F ;Increment offset3
return
CLEAR_OFFSET3_FLAG
bcf FLAGS,OFFSET3_FLAG
DECREMENT_OFFSET3
dcfsnz TABLE_OFFSET3,F ;Decrement offset3
bsf FLAGS,OFFSET3_FLAG
return
;This routine calculates the Timer0 reload value based on ADC read value and the
;scaling factor calculated based on the main clock and number of Sine table entries.
;Timer0 value = FFFF - (FREQUENCY_SCALE/Frequency) Frequ = (adc result)
CALCULATE_FREQUENCY
movff FREQUENCY,PORTD
clrf TEMP
clrf TEMP1
movlw HIGH(FREQUENCY_SCALE) ;FREQUENCY_SCALE/Frequency
movwf TEMP_LOCATION ;16 bit by 8 bit division
movlw LOW(FREQUENCY_SCALE) ;
movwf TEMP_LOCATION+1
continue_subtraction
bsf STATUS,C
movf FREQUENCY,W
subwfb TEMP_LOCATION+1,F
clrf WREG
subwfb TEMP_LOCATION,F
btfss STATUS,C
goto keep_result_in_rpm
incf TEMP,F
btfsc STATUS,C ;Result of the division is stored in TEMP&TEMP1
incf TEMP1,F
goto continue_subtraction
keep_result_in_rpm
;Timer0 value = FFFF-Timer0
bsf STATUS,C
movlw 0xFF
subfwb TEMP,F
subfwb TEMP1,F ;The Timer0 reload value stored in
movff TEMP1,FREQ_REF_H ;FREQ_REF_H & FREQ_REF_L
movff TEMP,FREQ_REF_L ;These values will be loaded to
return ;Timer0 in Timer0 overflow interrupt
;This routine sets the ADC GO bit high after an aquisition time of 20uS approx.
SET_ADC_GO
call CALCULATE_FREQUENCY
btfss ADCON0,GO
bsf ADCON0,GO ;Set GO bit for ADC conversion start
return
;This routine initializes the parameters required for motor initialization.
clrf CCPR1L ;Initialize all duty cycles to 0
clrf CCPR2L
CLRF CCPR3L
movlw 0x09 ;Initialize the table offset to 3 registers
movwf TABLE_OFFSET1 ;to form 0-120-240 degrees
movlw 0x03
movwf TABLE_OFFSET2
movlw 0x0F
movwf TABLE_OFFSET3
bsf FLAGS,OFFSET1_FLAG ;Offset flags initialization
movlw 0x30 ;Initialize frequency to 12Hz
movwf FREQUENCY
movlw 0xFD ;Timer0 Initialisation
movwf FREQ_REF_H
movwf TMR0H
movlw 0x2C ;
movwf TMR0L
movwf FREQ_REF_L
return
;Upon initialization the Sine table contents are copied to the RAM from
;Program memory
COPY_TABLE_TO_RAM
movlw UPPER sine_table ;Initialize Table pointer to the first
movwf TBLPTRU ;location of the table
movlw HIGH sine_table
movwf TBLPTRH
movlw LOW sine_table
movwf TBLPTRL
movlw LOW(SINE_TABLE)
movwf FSR0L
movlw HIGH(SINE_TABLE)
movwf FSR0H
movlw 0x14
movwf TEMP
COPY_AGAIN
TBLRD*+
movff TABLAT,POSTINC0
decfsz TEMP,F
bra COPY_AGAIN
movlw LOW(SINE_TABLE) ;FSR0 points to the starting of the table
movwf FSR0L
movwf FSR0H
return
;This routine checks for the keys status. 2 keys are checked, Run/Stop and
;Forward(FWD)/Reverse(REV)
KEY_CHECK
btfss PORTB,RUN_STOP_KEY ;Is key pressed "RUN/STOP"?
bra KEY_IS_RUN
bcf PORT_LED2,LED2
call STOP_MOTOR
bsf FLAGS,MOTOR_RUNNING
return
KEY_IS_RUN
bsf PORT_LED2,LED2
btfss FLAGS,MOTOR_RUNNING
bra CONT_RUN_KEY
bcf FLAGS,MOTOR_RUNNING
return
CONT_RUN_KEY
btfsc PORTB,FWD_REV_KEY ;Fwd/Rev key pressed?
;btfss PORTA,FWD_REV_KEY ;Fwd/Rev key pressed?
bra MOTOR_SET_FWD
btfsc FLAGS,MOTOR_DIRECTION
return
call STOP_MOTOR
call DELAY
call DELAY
call DELAY
call DELAY
call DELAY
call DELAY
bsf FLAGS,MOTOR_DIRECTION
return
MOTOR_SET_FWD
return
call STOP_MOTOR
call DELAY
call DELAY
call DELAY
call DELAY
call DELAY
call DELAY
bcf FLAGS,MOTOR_DIRECTION
return
;This routine stops the motor by driving the PWMs to 0% duty cycle.
STOP_MOTOR
clrf CCPR1L
clrf CCPR2L
CLRF CCPR3L
clrf TABLE_OFFSET1
clrf TABLE_OFFSET2
clrf TABLE_OFFSET3
bcf INTCON,TMR0IE
bcf PIE1,TMR2IE
bcf PIE1,TMR1IE
bcf PIE1,ADIE
return
;This routine starts motor from previous stop with motor parameters initialized
RUN_MOTOR_AGAIN
bsf INTCON,TMR0IE
bsf PIE1,TMR2IE
bsf PIE1,TMR1IE
bsf PIE1,ADIE
return
;Delay routine.
DELAY
movlw DELAY_COUNT1
movwf COUNTER
dec_count
movlw DELAY_COUNT2
movwf COUNTER1
dec_count1
decfsz COUNTER1,F
bra dec_count1
decfsz COUNTER,F
bra dec_count
clrf COUNTER
clrf COUNTER1
return
;Sine table for the inverter.
TABLE code 0x0100
;below table is from 270 eg. to 90 deg @ 10 deg. resolution; for 20MHz, PR2 = F9, Timer2 1:1 prescale
sine_table db 0x0,0x3,0x07,0x10,0x1B,0x28,0x38,0x4A,0x5C,0x70,0x83,0x96,0xA7,0xB7,0xC4,0xD0,0xD8,0xDD,0xDE
END
PHP:
;User defined variables
;Oscillator frequency
#define OSCILLATOR d'20000000'
;Timer0 prescaler
#define TIMER0_PRESCALE d'16'
;number of entries in the sine table, or the sampling frequency
#define SINE_TABLE_ENTRIES d'19'
SAMPLES_PER_CYCLE = (SINE_TABLE_ENTRIES-1)*d'2'
INSTRUCTION_CYCLE = (OSCILLATOR)/d'4'
FREQUENCY_SCALE = (INSTRUCTION_CYCLE/SAMPLES_PER_CYCLE)/(TIMER0_PRESCALE/4)
;Timer prescale/4 is done to componsate ADC multiplication factor of 4 to the frequency)
;PWM frequency definition
#define TIMER2_PRESCALE d'01'
#define PWM_FREQUENCY d'20000'
PR2_VALUE = (OSCILLATOR/(4*PWM_FREQUENCY*TIMER2_PRESCALE))-1
;ADC initialization
#define Fosc_by_2 b'000'
#define Fosc_by_8 b'001'
#define Fosc_by_32 b'010'
#define FRC b'011'
#define Fosc_by_4 b'100'
#define Fosc_by_16 b'101'
#define Fosc_by_64 b'110'
#define ADC_CLOCK Fosc_by_32
#define ADC_CHANNEL d'0'
#define ADC_ON_BIT b'1'
#define LEFT_JUSTIFIED
#define ADC_PORT_CONFIG b'1110' ;Refer the table in the manual for selection
ADCON0_VALUE = ((ADC_CLOCK<<6)|(ADC_CHANNEL<<4)|(ADC_ON_BIT))
if ((ADC_CLOCK==Fosc_by_2)||(ADC_CLOCK ==Fosc_by_8)||(ADC_CLOCK ==Fosc_by_32)||(ADC_CLOCK==FRC))
ifndef LEFT_JUSTIFIED
ADCON1_VALUE = ((1<<7) | (ADC_PORT_CONFIG))
else
ADCON1_VALUE = ADC_PORT_CONFIG
endif
endif
if ((ADC_CLOCK==Fosc_by_4)||(ADC_CLOCK==Fosc_by_16)||(ADC_CLOCK==Fosc_by_64))
ADCON1_VALUE = ((1<<7) |(1<<6)| (ADC_PORT_CONFIG))
else
ADCON1_VALUE = ( (1<<6)| (ADC_PORT_CONFIG))
endif
endif
;Port definitions
#define DRIVER_ENABLE_PORT PORTB
; #define DRIVER_ENABLE_BIT 3
#define FAULT_BIT 4
#define FWD_REV_KEY 1 ;It was 4
#define RUN_STOP_KEY 0 ;It was 5
#define PORT_LED1 PORTA
#define LED1 1
#define PORT_LED2 PORTA
#define LED2 2
