rafgamo
Member level 1
- Joined
- Sep 26, 2014
- Messages
- 39
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Location
- Philippines
- Activity points
- 234
See page-36 in the following.I've been working on a PFD shown in fig. 1.
I'm wondering on how to show, by using Synopsys
It is very natural result !!But, I'm still unable of showing the diagram I am looking for
Syntax #1
.SN TRES=<Tr> PERIOD=<T> [TRINIT=<Ti>]
+ [SWEEP parameter_sweep] [MAXTRINITCYCLES=<integer>]
or, Syntax #2
.SN TONE=<F1> NHARMS=<N> [TRINIT=<Ti]>
Sweep phase difference between V2(ref_clk) and V16(out_clk).
And then plot zero order harmonics of current flowing to C7 v.s. phase difference.
Pancho, can you please teach/tell me how to do so? Thanks. I'm a newbie to this so I did read papers on hspice but did not find any luck.
xi12 vdd! down up out_clk ref_clk start pfdv2_sch
v17 start gnd! dc=0 pulse ( 0 1.8 500p 1p 0 500n 1000n )
v16 out_clk gnd! dc=0 pulse ( 0 1.8 0 5p 5p 1n 2n )
v2 ref_clk gnd! dc=0 pulse ( 0 1.8 0 5p 5p 1n 2n )
v5 vdd! gnd! dc=1.8
c18 vctrl- gnd! c=.8p
c7 vctrl+ gnd! c=.8p
xi17 down up vctrl+ vctrl- cpv2_sch
.op All 0
.sn tres=.5n period=2n trinit=0 maxtrinitcycles=10 SWEEP Phase_Difference OCT 4
+ 0 360
.option opfile=1 split_dp=1
.probe snfd v(*)
.end
.param fund_period=2n
.param delta_phase_deg=0.0
.param tdelay='(delta_phase_deg/360)*fund_period'
v17 start gnd! dc=0 pulse(0 1.8 500p 1p 0 0.5 1)
v2 ref_clk gnd! dc=0 pulse(0 1.8 '1.1*fund_period'
+ 5p 5p 'fund_period/2' fund_period)
v16 out_clk gnd! dc=0 pulse(0 1.8 '1.1*fund_period+tdelay'
.sn tres='fund_period/10' period=fund_period
+ trinit='5*fund_period' maxtrinitcycles=5
+ sweep delta_phase_deg lin 101 -360 360
.probe i1(c7)
No. I use Synopsys Galaxy Custom Design.Do you launch HSPICE from Cadence ADE ?
I'm using Synopsys Custom WaveView.What post processing tool do you use ?
I understand.I use Synopsys Galaxy Custom Design.
I have "Synopsys Custom WaveView".I'm using Synopsys Custom WaveView.
But can I still show the diagrams I wanted given the tools I am using now?You can never make use of full abilities of HSPICE, if you launch it from Cadence ADE
I just noticed it now that I attached the wrong version of my schematic, I'm sorry for that. Here is the final version by the way.I noticed that your charge pump is differential type, although it was signle ended type in attached schematic of start of this thread
Then I realized I cant use it any further. So I tried making a new netlist with the code you gave in #9, and run it. But I can't see the output file (like for the .tran is .tr0)Sweep phase difference between V2(ref_clk) and V16(out_clk).
The time domain data are output to .sn0 files.Finally, I think I correctly run the .sn analysis and able to get the .sn waveforms which is iterated 100 times.
There is only the .sn0 here.Do they(.sn0, .snf0) exist ?
The logfile:Show me top level netlist and log file.
HEADER
"PSFversion" "1.00"
"Log Generator" "drlLog rev. 1.0"
"Log Time Stamp" "Thu Oct 22 22:18:44 2015"
"simulator" "HSPICE"
"version" "D-2010.03-SP2"
"rundate" "10/22/15 22:18"
"runtitle" "* Generated for: HSPICE"
"runtype" "logFile"
TYPE
"analysisInst" STRUCT(
"analysisType" STRING *
"dataFile" STRING *
"format" STRING *
"parent" STRING *
"sweepVariable" ARRAY ( * ) STRING *
"description" STRING *
VALUE
"input.op0" "analysisInst" (
"DC operating point"
"input.op0"
"PSF"
"timeSweep" "analysisInst" (
"Transient Analysis"
"PSF"
("alter name")
"sweep parent"
) PROP(
"sweep_tree_type" "paramSetSweepNode"
"input.tr0" "analysisInst" (
"input.tr0"
"PSF"
"timeSweep"
("time")
) PROP(
"sweep_tree_type" "leafNode"
"alter name" 0.00000
"snSweep" "analysisInst" (
"td.pss"
"PSF"
("DELTA_PHASE_DEG")
"sweep parent"
) PROP(
"input.sn0@0" "analysisInst" (
"td.pss"
"input.sn0@0"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -360.000
"input.sn0@1" "analysisInst" (
"td.pss"
"input.sn0@1"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -352.800
"input.sn0@2" "analysisInst" (
"td.pss"
"input.sn0@2"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -345.600
"input.sn0@3" "analysisInst" (
"td.pss"
"input.sn0@3"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -338.400
"input.sn0@4" "analysisInst" (
"td.pss"
"input.sn0@4"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -331.200
"input.sn0@5" "analysisInst" (
"td.pss"
"input.sn0@5"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -324.000
"input.sn0@6" "analysisInst" (
"td.pss"
"input.sn0@6"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -316.800
"input.sn0@7" "analysisInst" (
"td.pss"
"input.sn0@7"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -309.600
"input.sn0@8" "analysisInst" (
"td.pss"
"input.sn0@8"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -302.400
"input.sn0@9" "analysisInst" (
"td.pss"
"input.sn0@9"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -295.200
"input.sn0@10" "analysisInst" (
"td.pss"
"input.sn0@10"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -288.000
"input.sn0@11" "analysisInst" (
"td.pss"
"input.sn0@11"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -280.800
"input.sn0@12" "analysisInst" (
"td.pss"
"input.sn0@12"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -273.600
"input.sn0@13" "analysisInst" (
"td.pss"
"input.sn0@13"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -266.400
"input.sn0@14" "analysisInst" (
"td.pss"
"input.sn0@14"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -259.200
"input.sn0@15" "analysisInst" (
"td.pss"
"input.sn0@15"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -252.000
"input.sn0@16" "analysisInst" (
"td.pss"
"input.sn0@16"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -244.800
"input.sn0@17" "analysisInst" (
"td.pss"
"input.sn0@17"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -237.600
"input.sn0@18" "analysisInst" (
"td.pss"
"input.sn0@18"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -230.400
"input.sn0@19" "analysisInst" (
"td.pss"
"input.sn0@19"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -223.200
"input.sn0@20" "analysisInst" (
"td.pss"
"input.sn0@20"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -216.000
"input.sn0@21" "analysisInst" (
"td.pss"
"input.sn0@21"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -208.800
"input.sn0@22" "analysisInst" (
"td.pss"
"input.sn0@22"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -201.600
"input.sn0@23" "analysisInst" (
"td.pss"
"input.sn0@23"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -194.400
"input.sn0@24" "analysisInst" (
"td.pss"
"input.sn0@24"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -187.200
"input.sn0@25" "analysisInst" (
"td.pss"
"input.sn0@25"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -180.000
"input.sn0@26" "analysisInst" (
"td.pss"
"input.sn0@26"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -172.800
"input.sn0@27" "analysisInst" (
"td.pss"
"input.sn0@27"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -165.600
"input.sn0@28" "analysisInst" (
"td.pss"
"input.sn0@28"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -158.400
"input.sn0@29" "analysisInst" (
"td.pss"
"input.sn0@29"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -151.200
"input.sn0@30" "analysisInst" (
"td.pss"
"input.sn0@30"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -144.000
"input.sn0@31" "analysisInst" (
"td.pss"
"input.sn0@31"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -136.800
"input.sn0@32" "analysisInst" (
"td.pss"
"input.sn0@32"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -129.600
"input.sn0@33" "analysisInst" (
"td.pss"
"input.sn0@33"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -122.400
"input.sn0@34" "analysisInst" (
"td.pss"
"input.sn0@34"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -115.200
"input.sn0@35" "analysisInst" (
"td.pss"
"input.sn0@35"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -108.000
"input.sn0@36" "analysisInst" (
"td.pss"
"input.sn0@36"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -100.800
"input.sn0@37" "analysisInst" (
"td.pss"
"input.sn0@37"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -93.6000
"input.sn0@38" "analysisInst" (
"td.pss"
"input.sn0@38"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -86.4000
"input.sn0@39" "analysisInst" (
"td.pss"
"input.sn0@39"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -79.2000
"input.sn0@40" "analysisInst" (
"td.pss"
"input.sn0@40"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -72.0000
"input.sn0@41" "analysisInst" (
"td.pss"
"input.sn0@41"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -64.8000
"input.sn0@42" "analysisInst" (
"td.pss"
"input.sn0@42"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -57.6000
"input.sn0@43" "analysisInst" (
"td.pss"
"input.sn0@43"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -50.4000
"input.sn0@44" "analysisInst" (
"td.pss"
"input.sn0@44"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -43.2000
"input.sn0@45" "analysisInst" (
"td.pss"
"input.sn0@45"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -36.0000
"input.sn0@46" "analysisInst" (
"td.pss"
"input.sn0@46"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -28.8000
"input.sn0@47" "analysisInst" (
"td.pss"
"input.sn0@47"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -21.6000
"input.sn0@48" "analysisInst" (
"td.pss"
"input.sn0@48"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -14.4000
"input.sn0@49" "analysisInst" (
"td.pss"
"input.sn0@49"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" -7.20000
"input.sn0@50" "analysisInst" (
"td.pss"
"input.sn0@50"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 0.00000
"input.sn0@51" "analysisInst" (
"td.pss"
"input.sn0@51"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 7.20000
"input.sn0@52" "analysisInst" (
"td.pss"
"input.sn0@52"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 14.4000
"input.sn0@53" "analysisInst" (
"td.pss"
"input.sn0@53"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 21.6000
"input.sn0@54" "analysisInst" (
"td.pss"
"input.sn0@54"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 28.8000
"input.sn0@55" "analysisInst" (
"td.pss"
"input.sn0@55"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 36.0000
"input.sn0@56" "analysisInst" (
"td.pss"
"input.sn0@56"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 43.2000
"input.sn0@57" "analysisInst" (
"td.pss"
"input.sn0@57"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 50.4000
"input.sn0@58" "analysisInst" (
"td.pss"
"input.sn0@58"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 57.6000
"input.sn0@59" "analysisInst" (
"td.pss"
"input.sn0@59"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 64.8000
"input.sn0@60" "analysisInst" (
"td.pss"
"input.sn0@60"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 72.0000
"input.sn0@61" "analysisInst" (
"td.pss"
"input.sn0@61"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 79.2000
"input.sn0@62" "analysisInst" (
"td.pss"
"input.sn0@62"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 86.4000
"input.sn0@63" "analysisInst" (
"td.pss"
"input.sn0@63"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 93.6000
"input.sn0@64" "analysisInst" (
"td.pss"
"input.sn0@64"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 100.800
"input.sn0@65" "analysisInst" (
"td.pss"
"input.sn0@65"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 108.000
"input.sn0@66" "analysisInst" (
"td.pss"
"input.sn0@66"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 115.200
"input.sn0@67" "analysisInst" (
"td.pss"
"input.sn0@67"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 122.400
"input.sn0@68" "analysisInst" (
"td.pss"
"input.sn0@68"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 129.600
"input.sn0@69" "analysisInst" (
"td.pss"
"input.sn0@69"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 136.800
"input.sn0@70" "analysisInst" (
"td.pss"
"input.sn0@70"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 144.000
"input.sn0@71" "analysisInst" (
"td.pss"
"input.sn0@71"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 151.200
"input.sn0@72" "analysisInst" (
"td.pss"
"input.sn0@72"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 158.400
"input.sn0@73" "analysisInst" (
"td.pss"
"input.sn0@73"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 165.600
"input.sn0@74" "analysisInst" (
"td.pss"
"input.sn0@74"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 172.800
"input.sn0@75" "analysisInst" (
"td.pss"
"input.sn0@75"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 180.000
"input.sn0@76" "analysisInst" (
"td.pss"
"input.sn0@76"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 187.200
"input.sn0@77" "analysisInst" (
"td.pss"
"input.sn0@77"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 194.400
"input.sn0@78" "analysisInst" (
"td.pss"
"input.sn0@78"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 201.600
"input.sn0@79" "analysisInst" (
"td.pss"
"input.sn0@79"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 208.800
"input.sn0@80" "analysisInst" (
"td.pss"
"input.sn0@80"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 216.000
"input.sn0@81" "analysisInst" (
"td.pss"
"input.sn0@81"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 223.200
"input.sn0@82" "analysisInst" (
"td.pss"
"input.sn0@82"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 230.400
"input.sn0@83" "analysisInst" (
"td.pss"
"input.sn0@83"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 237.600
"input.sn0@84" "analysisInst" (
"td.pss"
"input.sn0@84"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 244.800
"input.sn0@85" "analysisInst" (
"td.pss"
"input.sn0@85"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 252.000
"input.sn0@86" "analysisInst" (
"td.pss"
"input.sn0@86"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 259.200
"input.sn0@87" "analysisInst" (
"td.pss"
"input.sn0@87"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 266.400
"input.sn0@88" "analysisInst" (
"td.pss"
"input.sn0@88"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 273.600
"input.sn0@89" "analysisInst" (
"td.pss"
"input.sn0@89"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 280.800
"input.sn0@90" "analysisInst" (
"td.pss"
"input.sn0@90"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 288.000
"input.sn0@91" "analysisInst" (
"td.pss"
"input.sn0@91"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 295.200
"input.sn0@92" "analysisInst" (
"td.pss"
"input.sn0@92"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 302.400
"input.sn0@93" "analysisInst" (
"td.pss"
"input.sn0@93"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 309.600
"input.sn0@94" "analysisInst" (
"td.pss"
"input.sn0@94"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 316.800
"input.sn0@95" "analysisInst" (
"td.pss"
"input.sn0@95"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 324.000
"input.sn0@96" "analysisInst" (
"td.pss"
"input.sn0@96"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 331.200
"input.sn0@97" "analysisInst" (
"td.pss"
"input.sn0@97"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 338.400
"input.sn0@98" "analysisInst" (
"td.pss"
"input.sn0@98"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 345.600
"input.sn0@99" "analysisInst" (
"td.pss"
"input.sn0@99"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 352.800
"input.sn0@100" "analysisInst" (
"td.pss"
"input.sn0@100"
"PSF"
"snSweep"
"td.pss"
) PROP(
"DELTA_PHASE_DEG" 360.000
END
Show me all file lists.There is only the .sn0 here.
This is not logfile.The logfile:Code:HEADER "PSFversion" "1.00" ...... END
All top level netlist except for sub circuit definition and device model file.For the top level netlist, on what particular part do you need?
I am sorry I can't show you the full netlist.
figure 3 is meaningless.But I have no idea how to show the figures 2 and 3 in thread #1.
HSPICE RF -- D-2010.03-SP2 (Aug 26 2010)
Copyright (C) 2010 Synopsys,Inc. All rights reserved.
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
hspicerf 32-bit version D-2010.03-SP2 (Aug 26 2010 11:54:45)
machine info: Linux microlab.coe.msuiit.edu.ph 2.6.18-164.el5xen #1 SMP Thu Sep 3 04:03:03 EDT 2009 x86_64
current time: 22:18:44 10/22/2015
command line: hspicerf input.spi
Warning: 2 subcircuits are ignored because not called by any instance.
Subcircuits not called by any instance:
| Location | Subckt |
| (/home/TSMC018um/models/hspice/rf018.l:10515) | "NCH_MIS" |
| (/home/TSMC018um/models/hspice/rf018.l:11848) | "PCH_MIS" |
Total number of lines parsed: 20246
Resource Usage for Parsing
| CPU Time | 0.16 sec |
| Peak Memory | 0.09 Mb |
Warning: option "SPLIT_DP" ignored
Source Files
| "/home/TSMC018um/models/hspice/rf018.l" |
| "input.spi" |
Options
| Option | Value |
| ARTIST | 2 |
| OPFILE | 1 |
| PSF | 1 |
| TEMPC | 25 |
| TEMPK | 298.15 |
Warning: (input.spi:183) pulse fall time is < or = zero, reset to tstep
30 unique instance models are loaded.
Resource Usage for Load Netlist Data
| CPU Time | 0.01 sec |
| Peak Memory | 2.66 Mb |
License user information
| FLEXLM | v8.5b |
| USER | |
| HOSTNAME | microlab.coe.msuiit.edu.ph |
| HOSTID | 001e68da1ca2 |
| PID | 20709 |
License file: 27020@microlab.coe.msuiit.edu.ph
| license | checkout number | expiration date | # in use / total | server |
| hspice | 1 | 18-aug-2016/2015.06 | 1/15 | microlab.coe.msuiit.edu.ph |
| FLEXLM | v8.5b |
| USER | |
| PID | 20709 |
| hspicerf | 1 | 18-aug-2016/2015.06 | 1/15 | microlab.coe.msuiit.edu.ph |
Netlist Statistics
| Type | Count |
| nmos | 41 |
| pmos | 29 |
| resistor | 1 |
| capacitor | 2 |
| vsrc | 4 |
Summary of Possible Problems in Netlist
| Negative resistor | 0 |
| Negative capacitor | 0 |
| Negative inductor | 0 |
| Unconnected node | 0 |
| Dangling terminal | 0 |
| Non-rail bulk terminal | 0 |
| Floating MOS gate | 0 |
| Floating MOS bulk | 0 |
| Floating BJT substrate | 0 |
| Floating controlled input | 0 |
| Floating current source nodes | 0 |
| Source loop | 0 |
Resource Usage for Netlist Check
| CPU Time | 0.00 sec |
| Peak Memory | 2.80 Mb |
Number of nodes: 52
Total number of nodes (including internal nodes): 192
Resource Usage for Netlist Data Compression
| Peak Memory | 2.84 Mb |
Simulation
OP: finished using direct method
Number of iterations for OP analysis: 145
Resource Usage for Operating Point
| CPU Time | 0.08 sec |
| Peak Memory | 3.04 Mb |
Transient Analysis
10.0% time = 7.5 ns ( etc = 2.0 sec, ett = 3.0 sec )
( slv=749 evl=290 rej=36 mem=3362K cpu=0 wall=0 )
20.0% time = 15.0 ns ( etc = 2.0 sec, ett = 3.0 sec )
( slv=1554 evl=616 rej=83 mem=3362K cpu=0 wall=0 )
30.0% time = 22.5 ns ( etc = 2.0 sec, ett = 3.0 sec )
( slv=2396 evl=951 rej=135 mem=3362K cpu=0 wall=0 )
40.0% time = 30.0 ns ( etc = 1.0 sec, ett = 3.0 sec )
( slv=3162 evl=1271 rej=179 mem=3362K cpu=0 wall=0 )
50.0% time = 37.5 ns ( etc = 1.0 sec, ett = 3.0 sec )
( slv=4034 evl=1625 rej=231 mem=3362K cpu=1 wall=1 )
60.0% time = 45.0 ns ( etc = 1.0 sec, ett = 3.0 sec )
( slv=4839 evl=1951 rej=278 mem=3362K cpu=1 wall=1 )
70.0% time = 52.5 ns ( etc = 1.0 sec, ett = 3.0 sec )
( slv=5681 evl=2286 rej=330 mem=3362K cpu=1 wall=1 )
80.0% time = 60.0 ns ( etc = 0.0 sec, ett = 3.0 sec )
( slv=6446 evl=2605 rej=374 mem=3362K cpu=1 wall=1 )
90.0% time = 67.5 ns ( etc = 0.0 sec, ett = 3.0 sec )
( slv=7318 evl=2959 rej=426 mem=3362K cpu=2 wall=2 )
solve = 8123 eval = 3285 reject = 473
Transient time = 2.35 cpu sec, 2.48 wall sec
Resource Usage for Transient Analysis
| CPU Time | 2.35 sec |
| Peak Memory | 3.28 Mb |
Time Domain RF Analysis
Steady-State Time Domain Analysis will use the matrix-implicit gmres solver.
starting Shooting Newton Sweep
Shooting Newton Sweep:
0.0% DELTA_PHAS = -360.000000 ( etc = 0.0 sec, ett = 0.0 sec )
| CPU Time | 0.04 sec |
Input period: 2e-09
Warning: SN_ERR: Periodic source V17 has very small frequency=1 - may be incompatible with SN
begin circuit stabilization time...
Transient Analysis
20% ...
40% ...
Maxtrinitcycles reached. Starting SN analysis.
solve = 1120 eval = 446 reject = 57
Transient time = 0.29 cpu sec, 0.29 wall sec
| CPU Time | 0.30 sec |
| Peak Memory | 14.68 Mb |
circuit stabilization time done...
number of transient points: 0
********** Shooting-Newton iteration 1 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 857 eval = 287 reject = 9
Transient time = 0.23 cpu sec, 0.28 wall sec
| CPU Time | 0.23 sec |
| Peak Memory | 26.46 Mb |
number of transient points: 139
start GMRES
number of GMRES iterations: 9
current residual: 9.27773e-08
voltage residual: 0.00600663
********** Shooting-Newton iteration 2 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 965 eval = 310 reject = 15
Transient time = 0.26 cpu sec, 0.29 wall sec
| CPU Time | 0.27 sec |
| Peak Memory | 27.39 Mb |
number of transient points: 295
start GMRES
number of GMRES iterations: 12
current residual: 3.18559e-07
voltage residual: 0.0104062
********** Shooting-Newton iteration 3 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 898 eval = 295 reject = 0
Transient time = 0.24 cpu sec, 0.26 wall sec
| CPU Time | 0.24 sec |
start GMRES
number of GMRES iterations: 11
current residual: 1.0605e-07
voltage residual: 0.152663
********** Shooting-Newton iteration 4 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 816 eval = 295 reject = 0
Transient time = 0.24 cpu sec, 0.25 wall sec
start GMRES
current residual: 4.93628e-08
voltage residual: 0.00147587
********** Shooting-Newton iteration 5 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 815 eval = 295 reject = 0
| CPU Time | 0.25 sec |
start GMRES
current residual: 5.91847e-09
voltage residual: 0.000258129
********** Shooting-Newton iteration 6 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 817 eval = 295 reject = 0
Transient time = 0.25 cpu sec, 0.25 wall sec
start GMRES
number of GMRES iterations: 10
current residual: 2.13102e-09
voltage residual: 3.80289e-05
********** Shooting-Newton iteration 7 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 818 eval = 295 reject = 0
| Peak Memory | 27.40 Mb |
start GMRES
number of GMRES iterations: 8
current residual: 7.44716e-10
voltage residual: 1.32807e-05
********** Shooting-Newton iteration 8 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.3853e-10
voltage residual: 4.25655e-06
********** Shooting-Newton iteration 9 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.22 cpu sec, 0.25 wall sec
start GMRES
current residual: 5.97529e-11
voltage residual: 1.06503e-06
********** Shooting-Newton iteration 10 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.61001e-12
voltage residual: 1.33987e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1609 eval = 590 reject = 0
Transient time = 0.5 cpu sec, 0.5 wall sec
| CPU Time | 0.55 sec |
Steady-State Time Domain has converged successfully in 10 iterations
0.9% DELTA_PHAS = -352.800000 ( etc = 7:30, ett = 7:02 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1439 eval = 504 reject = 18
Transient time = 0.31 cpu sec, 0.39 wall sec
| CPU Time | 0.31 sec |
| Peak Memory | 36.53 Mb |
number of transient points: 243
start GMRES
number of GMRES iterations: 4
current residual: 1.46164e-08
voltage residual: 0.00704871
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1188 eval = 366 reject = 17
Transient time = 0.35 cpu sec, 0.35 wall sec
| CPU Time | 0.35 sec |
number of transient points: 349
start GMRES
current residual: 1.80052e-05
voltage residual: 0.00686181
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1017 eval = 349 reject = 0
Transient time = 0.29 cpu sec, 0.3 wall sec
| CPU Time | 0.29 sec |
start GMRES
current residual: 5.4763e-08
voltage residual: 0.224406
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.3 cpu sec, 0.31 wall sec
start GMRES
current residual: 3.3527e-07
voltage residual: 0.0129653
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.3 cpu sec, 0.3 wall sec
start GMRES
number of GMRES iterations: 6
current residual: 1.39887e-07
voltage residual: 0.00312593
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1016 eval = 349 reject = 0
start GMRES
current residual: 9.59814e-10
voltage residual: 5.63471e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.27 cpu sec, 0.29 wall sec
start GMRES
current residual: 9.39636e-13
voltage residual: 1.38193e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.32663e-15
voltage residual: 2.08311e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1380 eval = 477 reject = 1
Transient time = 0.38 cpu sec, 0.38 wall sec
| CPU Time | 0.38 sec |
Steady-State Time Domain has converged successfully in 8 iterations
1.9% DELTA_PHAS = -345.600000 ( etc = 6:25, ett = 6:08 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2508 eval = 590 reject = 42
Transient time = 0.7 cpu sec, 0.73 wall sec
| CPU Time | 0.70 sec |
| Peak Memory | 39.16 Mb |
number of transient points: 274
start GMRES
current residual: 1.28771e-06
voltage residual: 0.0707994
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1344 eval = 459 reject = 17
number of transient points: 221
start GMRES
number of GMRES iterations: 7
current residual: 1.61215e-06
voltage residual: 0.0103884
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1279 eval = 390 reject = 22
Transient time = 0.32 cpu sec, 0.33 wall sec
| CPU Time | 0.32 sec |
number of transient points: 368
start GMRES
current residual: 1.48284e-06
voltage residual: 0.00882583
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1094 eval = 368 reject = 0
start GMRES
current residual: 2.49613e-08
voltage residual: 0.00124598
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.31 cpu sec, 0.33 wall sec
start GMRES
current residual: 3.30112e-11
voltage residual: 5.4473e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.31 cpu sec, 0.3 wall sec
start GMRES
current residual: 3.21377e-12
voltage residual: 1.26447e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.28 cpu sec, 0.3 wall sec
| CPU Time | 0.28 sec |
start GMRES
current residual: 7.6935e-15
voltage residual: 2.44238e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1108 eval = 375 reject = 1
Transient time = 0.33 cpu sec, 0.32 wall sec
| CPU Time | 0.33 sec |
Steady-State Time Domain has converged successfully in 7 iterations
2.9% DELTA_PHAS = -338.400000 ( etc = 6:04, ett = 5:56 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2186 eval = 507 reject = 39
Transient time = 0.58 cpu sec, 0.61 wall sec
| CPU Time | 0.59 sec |
number of transient points: 234
start GMRES
current residual: 0.000100813
voltage residual: 0.0145717
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1286 eval = 384 reject = 17
number of transient points: 367
start GMRES
current residual: 0.000145196
voltage residual: 0.0130896
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1119 eval = 367 reject = 0
Transient time = 0.29 cpu sec, 0.33 wall sec
start GMRES
current residual: 6.4368e-07
voltage residual: 0.00190838
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.04501e-07
voltage residual: 0.000681511
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1118 eval = 367 reject = 0
start GMRES
current residual: 4.01114e-08
voltage residual: 0.000246133
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.3 cpu sec, 0.29 wall sec
start GMRES
current residual: 1.48003e-08
voltage residual: 8.90763e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1117 eval = 367 reject = 0
start GMRES
current residual: 5.33248e-09
voltage residual: 3.19237e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.844e-09
voltage residual: 1.1045e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.71912e-10
voltage residual: 3.44487e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1185 eval = 390 reject = 1
Transient time = 0.32 cpu sec, 0.32 wall sec
Steady-State Time Domain has converged successfully in 9 iterations
3.9% DELTA_PHAS = -331.200000 ( etc = 6:07, ett = 6:04 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1574 eval = 538 reject = 20
Transient time = 0.34 cpu sec, 0.35 wall sec
number of transient points: 259
start GMRES
current residual: 6.29609e-07
voltage residual: 0.00339655
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1504 eval = 478 reject = 24
number of transient points: 454
start GMRES
current residual: 5.21348e-07
voltage residual: 0.00283054
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1288 eval = 454 reject = 0
Transient time = 0.33 cpu sec, 0.34 wall sec
start GMRES
current residual: 1.61978e-09
voltage residual: 4.22463e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1286 eval = 454 reject = 0
Transient time = 0.34 cpu sec, 0.34 wall sec
start GMRES
current residual: 1.17463e-10
voltage residual: 7.71533e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1287 eval = 454 reject = 0
| CPU Time | 0.34 sec |
start GMRES
current residual: 1.09845e-11
voltage residual: 7.67089e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1289 eval = 454 reject = 0
start GMRES
current residual: 2.96756e-13
voltage residual: 1.03257e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2550 eval = 908 reject = 0
Transient time = 0.66 cpu sec, 0.67 wall sec
| CPU Time | 0.66 sec |
Steady-State Time Domain has converged successfully in 6 iterations
4.9% DELTA_PHAS = -324.000000 ( etc = 5:54, ett = 5:57 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1519 eval = 517 reject = 19
number of transient points: 249
start GMRES
current residual: 1.16575e-06
voltage residual: 0.00291353
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1459 eval = 457 reject = 24
Transient time = 0.37 cpu sec, 0.37 wall sec
| CPU Time | 0.37 sec |
number of transient points: 433
start GMRES
current residual: 9.19701e-07
voltage residual: 0.00268276
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1251 eval = 433 reject = 0
start GMRES
current residual: 1.11572e-09
voltage residual: 3.32399e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1250 eval = 433 reject = 0
start GMRES
current residual: 3.30318e-11
voltage residual: 2.03034e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1253 eval = 433 reject = 0
Transient time = 0.3 cpu sec, 0.32 wall sec
start GMRES
current residual: 1.05969e-12
voltage residual: 6.82869e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.28618e-15
voltage residual: 1.93344e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2478 eval = 866 reject = 0
Transient time = 0.63 cpu sec, 0.64 wall sec
| CPU Time | 0.64 sec |
5.9% DELTA_PHAS = -316.800000 ( etc = 5:41, ett = 5:49 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1539 eval = 510 reject = 18
Transient time = 0.35 cpu sec, 0.36 wall sec
number of transient points: 246
start GMRES
current residual: 2.98984e-08
voltage residual: 0.000909868
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1658 eval = 534 reject = 24
Transient time = 0.39 cpu sec, 0.41 wall sec
| CPU Time | 0.39 sec |
number of transient points: 510
start GMRES
current residual: 1.34213e-07
voltage residual: 0.00350647
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1414 eval = 510 reject = 0
start GMRES
current residual: 8.52719e-09
voltage residual: 5.08354e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.34 cpu sec, 0.36 wall sec
start GMRES
current residual: 2.03268e-14
voltage residual: 8.74714e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2799 eval = 1020 reject = 0
Transient time = 0.66 cpu sec, 0.71 wall sec
Steady-State Time Domain has converged successfully in 4 iterations
6.9% DELTA_PHAS = -309.600000 ( etc = 5:23, ett = 5:33 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1583 eval = 527 reject = 17
number of transient points: 255
start GMRES
current residual: 1.12611e-07
voltage residual: 0.000611542
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1508 eval = 498 reject = 20
Transient time = 0.36 cpu sec, 0.37 wall sec
| CPU Time | 0.36 sec |
number of transient points: 478
start GMRES
current residual: 6.24097e-07
voltage residual: 0.00152252
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1349 eval = 478 reject = 0
Transient time = 0.34 cpu sec, 0.33 wall sec
start GMRES
current residual: 1.29348e-10
voltage residual: 4.8781e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.28875e-15
voltage residual: 2.22743e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1819 eval = 646 reject = 1
Transient time = 0.44 cpu sec, 0.45 wall sec
| CPU Time | 0.44 sec |
7.9% DELTA_PHAS = -302.400000 ( etc = 5:04, ett = 5:18 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2604 eval = 604 reject = 42
Transient time = 0.68 cpu sec, 0.7 wall sec
| CPU Time | 0.68 sec |
| Peak Memory | 39.76 Mb |
number of transient points: 281
start GMRES
current residual: 1.16246e-08
voltage residual: 0.00113957
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1663 eval = 545 reject = 27
Transient time = 0.4 cpu sec, 0.39 wall sec
| CPU Time | 0.40 sec |
number of transient points: 518
start GMRES
current residual: 6.90301e-08
voltage residual: 0.0025842
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1430 eval = 518 reject = 0
start GMRES
current residual: 1.34287e-08
voltage residual: 6.25807e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1433 eval = 518 reject = 0
start GMRES
current residual: 7.88267e-13
voltage residual: 5.16849e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.37668e-15
voltage residual: 3.03242e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2833 eval = 1036 reject = 0
Transient time = 0.65 cpu sec, 0.68 wall sec
Steady-State Time Domain has converged successfully in 5 iterations
8.9% DELTA_PHAS = -295.200000 ( etc = 5:01, ett = 5:19 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2379 eval = 570 reject = 40
Transient time = 0.62 cpu sec, 0.61 wall sec
| CPU Time | 0.62 sec |
number of transient points: 265
start GMRES
current residual: 2.3987e-07
voltage residual: 0.00685801
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1673 eval = 515 reject = 30
Transient time = 0.38 cpu sec, 0.4 wall sec
number of transient points: 485
start GMRES
current residual: 2.86401e-07
voltage residual: 0.00261516
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1375 eval = 485 reject = 0
start GMRES
current residual: 1.2289e-07
voltage residual: 0.000847214
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1376 eval = 485 reject = 0
start GMRES
current residual: 4.75778e-08
voltage residual: 0.000305551
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1377 eval = 485 reject = 0
start GMRES
current residual: 1.85097e-08
voltage residual: 0.000110618
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.33 cpu sec, 0.33 wall sec
start GMRES
current residual: 6.57834e-09
voltage residual: 3.97802e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.30317e-09
voltage residual: 1.39158e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.39902e-10
voltage residual: 4.48166e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.86745e-10
voltage residual: 1.13676e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2719 eval = 970 reject = 0
Transient time = 0.66 cpu sec, 0.68 wall sec
9.9% DELTA_PHAS = -288.000000 ( etc = 5:12, ett = 5:35 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1585 eval = 528 reject = 18
Transient time = 0.33 cpu sec, 0.37 wall sec
start GMRES
current residual: 6.25424e-08
voltage residual: 0.000259712
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1913 eval = 648 reject = 23
Transient time = 0.47 cpu sec, 0.47 wall sec
| CPU Time | 0.47 sec |
| Peak Memory | 42.81 Mb |
number of transient points: 625
start GMRES
current residual: 1.10901e-05
voltage residual: 0.00258679
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1642 eval = 625 reject = 0
| Peak Memory | 42.83 Mb |
start GMRES
current residual: 1.59777e-08
voltage residual: 1.44385e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1644 eval = 625 reject = 0
Transient time = 0.4 cpu sec, 0.41 wall sec
| Peak Memory | 42.84 Mb |
start GMRES
current residual: 8.49174e-12
voltage residual: 4.42504e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.4 cpu sec, 0.42 wall sec
start GMRES
current residual: 6.21563e-13
voltage residual: 2.79028e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2040 eval = 788 reject = 1
| CPU Time | 0.51 sec |
10.8% DELTA_PHAS = -280.800000 ( etc = 5:09, ett = 5:35 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2678 eval = 632 reject = 46
Transient time = 0.59 cpu sec, 0.63 wall sec
number of transient points: 293
start GMRES
current residual: 1.36774e-05
voltage residual: 0.00131459
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1923 eval = 629 reject = 28
Transient time = 0.44 cpu sec, 0.43 wall sec
number of transient points: 601
start GMRES
current residual: 0.00128183
voltage residual: 0.00325827
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1591 eval = 601 reject = 0
start GMRES
current residual: 8.00492e-08
voltage residual: 3.04355e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1592 eval = 601 reject = 0
start GMRES
current residual: 1.84881e-09
voltage residual: 5.38671e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.16936e-12
voltage residual: 1.40901e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2261 eval = 871 reject = 1
Transient time = 0.53 cpu sec, 0.53 wall sec
| CPU Time | 0.54 sec |
11.8% DELTA_PHAS = -273.600000 ( etc = 5:04, ett = 5:34 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2698 eval = 694 reject = 40
Transient time = 0.62 cpu sec, 0.67 wall sec
| CPU Time | 0.63 sec |
| Peak Memory | 43.67 Mb |
number of transient points: 327
start GMRES
current residual: 2.47576e-07
voltage residual: 0.00117097
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1854 eval = 628 reject = 20
Transient time = 0.45 cpu sec, 0.44 wall sec
| CPU Time | 0.45 sec |
number of transient points: 608
start GMRES
current residual: 7.95093e-06
voltage residual: 0.000531827
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1599 eval = 608 reject = 0
Transient time = 0.39 cpu sec, 0.39 wall sec
start GMRES
current residual: 5.60021e-09
voltage residual: 0.000315553
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1595 eval = 608 reject = 0
start GMRES
current residual: 5.85995e-11
voltage residual: 1.16476e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.39 cpu sec, 0.4 wall sec
start GMRES
current residual: 7.99491e-16
voltage residual: 1.34857e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2188 eval = 844 reject = 1
Transient time = 0.51 cpu sec, 0.54 wall sec
12.8% DELTA_PHAS = -266.400000 ( etc = 5:00, ett = 5:33 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2672 eval = 679 reject = 41
Transient time = 0.68 cpu sec, 0.68 wall sec
| CPU Time | 0.69 sec |
number of transient points: 319
start GMRES
current residual: 2.81163e-08
voltage residual: 0.00157045
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1701 eval = 534 reject = 25
Transient time = 0.41 cpu sec, 0.41 wall sec
| CPU Time | 0.41 sec |
number of transient points: 509
start GMRES
current residual: 5.28491e-07
voltage residual: 0.00162354
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1433 eval = 509 reject = 0
Transient time = 0.36 cpu sec, 0.36 wall sec
start GMRES
current residual: 4.67055e-09
voltage residual: 2.15941e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1434 eval = 509 reject = 0
start GMRES
current residual: 5.36864e-13
voltage residual: 4.32692e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1638 eval = 581 reject = 1
13.8% DELTA_PHAS = -259.200000 ( etc = 4:51, ett = 5:28 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2485 eval = 603 reject = 39
Transient time = 0.6 cpu sec, 0.63 wall sec
| CPU Time | 0.60 sec |
number of transient points: 282
start GMRES
current residual: 3.55683e-07
voltage residual: 0.00687368
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1802 eval = 578 reject = 29
Transient time = 0.42 cpu sec, 0.42 wall sec
| CPU Time | 0.42 sec |
number of transient points: 549
start GMRES
current residual: 1.18413e-06
voltage residual: 0.00245817
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1498 eval = 549 reject = 0
Transient time = 0.37 cpu sec, 0.36 wall sec
start GMRES
current residual: 8.41299e-08
voltage residual: 0.000873984
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.46666e-08
voltage residual: 0.000315136
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.36 cpu sec, 0.35 wall sec
start GMRES
current residual: 2.16814e-07
voltage residual: 0.000114084
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1497 eval = 549 reject = 0
start GMRES
current residual: 4.61504e-09
voltage residual: 4.1042e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.37 cpu sec, 0.38 wall sec
start GMRES
current residual: 1.61837e-09
voltage residual: 1.4376e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.35 cpu sec, 0.37 wall sec
start GMRES
current residual: 5.2211e-10
voltage residual: 4.6484e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.33474e-10
voltage residual: 1.19273e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2965 eval = 1098 reject = 0
Transient time = 0.71 cpu sec, 0.76 wall sec
| CPU Time | 0.71 sec |
14.8% DELTA_PHAS = -252.000000 ( etc = 4:58, ett = 5:39 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2517 eval = 618 reject = 38
Transient time = 0.53 cpu sec, 0.58 wall sec
| CPU Time | 0.53 sec |
number of transient points: 290
start GMRES
current residual: 6.84439e-08
voltage residual: 0.00662024
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1646 eval = 523 reject = 23
number of transient points: 500
start GMRES
current residual: 2.95644e-07
voltage residual: 0.00237828
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1405 eval = 500 reject = 0
start GMRES
current residual: 3.85863e-10
voltage residual: 0.000843613
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1406 eval = 500 reject = 0
start GMRES
current residual: 1.12043e-10
voltage residual: 0.000303788
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.64621e-11
voltage residual: 0.000109892
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.26957e-11
voltage residual: 3.95232e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.00051e-12
voltage residual: 1.38538e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.41013e-12
voltage residual: 4.49256e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.35 cpu sec, 0.34 wall sec
start GMRES
current residual: 1.27762e-12
voltage residual: 1.1637e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1579 eval = 557 reject = 1
15.8% DELTA_PHAS = -244.800000 ( etc = 5:00, ett = 5:46 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2553 eval = 582 reject = 42
Transient time = 0.6 cpu sec, 0.6 wall sec
number of transient points: 270
start GMRES
current residual: 6.21928e-06
voltage residual: 0.000538523
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1696 eval = 550 reject = 26
number of transient points: 524
start GMRES
current residual: 5.17177e-06
voltage residual: 0.00123114
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1436 eval = 524 reject = 0
start GMRES
current residual: 1.08788e-07
voltage residual: 9.8373e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1437 eval = 524 reject = 0
start GMRES
current residual: 1.1093e-07
voltage residual: 9.81489e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
voltage residual: 9.81487e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1904 eval = 697 reject = 1
Transient time = 0.46 cpu sec, 0.47 wall sec
| CPU Time | 0.46 sec |
16.8% DELTA_PHAS = -237.600000 ( etc = 4:58, ett = 5:49 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2469 eval = 540 reject = 40
Transient time = 0.62 cpu sec, 0.66 wall sec
number of transient points: 250
start GMRES
current residual: 1.42467e-07
voltage residual: 0.0018168
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1608 eval = 506 reject = 26
number of transient points: 480
start GMRES
current residual: 9.58766e-06
voltage residual: 0.00182045
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1342 eval = 480 reject = 0
start GMRES
current residual: 7.48693e-07
voltage residual: 0.000280072
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1345 eval = 480 reject = 0
start GMRES
current residual: 2.02819e-12
voltage residual: 7.31848e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.06313e-15
voltage residual: 1.30526e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2655 eval = 958 reject = 0
17.8% DELTA_PHAS = -230.400000 ( etc = 4:53, ett = 5:47 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2168 eval = 467 reject = 41
Transient time = 0.55 cpu sec, 0.56 wall sec
number of transient points: 213
start GMRES
current residual: 3.09113e-05
voltage residual: 0.00686106
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1518 eval = 467 reject = 25
number of transient points: 442
start GMRES
current residual: 7.64784e-05
voltage residual: 0.00861063
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1274 eval = 442 reject = 0
start GMRES
current residual: 1.47533e-07
voltage residual: 0.00086833
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1275 eval = 442 reject = 0
start GMRES
current residual: 4.96161e-08
voltage residual: 0.000313086
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1276 eval = 442 reject = 0
start GMRES
current residual: 1.8419e-08
voltage residual: 0.000113349
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.68037e-09
voltage residual: 4.07755e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.34034e-09
voltage residual: 1.4279e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.53059e-10
voltage residual: 4.61341e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.90721e-10
voltage residual: 1.18111e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2523 eval = 884 reject = 0
Transient time = 0.65 cpu sec, 0.65 wall sec
| CPU Time | 0.65 sec |
18.8% DELTA_PHAS = -223.200000 ( etc = 4:54, ett = 5:52 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1248 eval = 377 reject = 17
number of transient points: 180
start GMRES
current residual: 1.2451e-06
voltage residual: 0.00241176
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1448 eval = 441 reject = 23
number of transient points: 418
start GMRES
current residual: 2.73221e-05
voltage residual: 0.00588625
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1208 eval = 418 reject = 0
start GMRES
current residual: 5.48637e-07
voltage residual: 0.000482795
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1210 eval = 418 reject = 0
start GMRES
current residual: 6.49012e-12
voltage residual: 5.20612e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.18829e-13
voltage residual: 6.25492e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2386 eval = 836 reject = 0
Transient time = 0.61 cpu sec, 0.62 wall sec
| CPU Time | 0.61 sec |
19.8% DELTA_PHAS = -216.000000 ( etc = 4:46, ett = 5:47 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1949 eval = 463 reject = 35
Transient time = 0.41 cpu sec, 0.43 wall sec
number of transient points: 214
start GMRES
current residual: 0.00032878
voltage residual: 0.0286259
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1376 eval = 444 reject = 23
number of transient points: 421
start GMRES
current residual: 0.000508656
voltage residual: 0.0322941
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1203 eval = 421 reject = 0
Transient time = 0.31 cpu sec, 0.32 wall sec
start GMRES
current residual: 4.59163e-06
voltage residual: 0.000949803
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1204 eval = 421 reject = 0
start GMRES
current residual: 4.84748e-11
voltage residual: 6.20099e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.20814e-14
voltage residual: 1.84232e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1260 eval = 439 reject = 1
20.7% DELTA_PHAS = -208.800000 ( etc = 4:40, ett = 5:44 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1935 eval = 443 reject = 35
Transient time = 0.42 cpu sec, 0.46 wall sec
number of transient points: 204
start GMRES
current residual: 0.000165038
voltage residual: 0.0237324
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1322 eval = 370 reject = 23
number of transient points: 347
start GMRES
current residual: 0.000398455
voltage residual: 0.0253606
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1092 eval = 347 reject = 0
Transient time = 0.28 cpu sec, 0.28 wall sec
start GMRES
current residual: 2.65746e-09
voltage residual: 0.000128528
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.26733e-11
voltage residual: 7.56886e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.85903e-15
voltage residual: 2.5679e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1581 eval = 502 reject = 1
21.7% DELTA_PHAS = -201.600000 ( etc = 4:32, ett = 5:39 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2242 eval = 470 reject = 44
Transient time = 0.59 cpu sec, 0.62 wall sec
start GMRES
current residual: 7.08092e-06
voltage residual: 0.429551
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1295 eval = 433 reject = 17
number of transient points: 208
start GMRES
current residual: 8.7067e-06
voltage residual: 0.0385918
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1509 eval = 504 reject = 14
number of transient points: 490
start GMRES
current residual: 2.09521e-07
voltage residual: 0.0409778
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1360 eval = 490 reject = 0
start GMRES
current residual: 1.09888e-09
voltage residual: 6.54621e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1361 eval = 490 reject = 0
start GMRES
current residual: 5.35336e-13
voltage residual: 5.20403e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.09081e-15
voltage residual: 4.04161e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2692 eval = 980 reject = 0
Transient time = 0.71 cpu sec, 0.72 wall sec
22.7% DELTA_PHAS = -194.400000 ( etc = 4:29, ett = 5:39 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2238 eval = 497 reject = 41
number of transient points: 228
start GMRES
current residual: 9.71661e-05
voltage residual: 0.178319
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1234 eval = 411 reject = 17
Transient time = 0.27 cpu sec, 0.28 wall sec
number of transient points: 197
start GMRES
current residual: 0.000147802
voltage residual: 0.00759433
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1396 eval = 443 reject = 15
Transient time = 0.38 cpu sec, 0.37 wall sec
number of transient points: 428
start GMRES
current residual: 0.000377999
voltage residual: 0.0107632
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1235 eval = 428 reject = 0
start GMRES
current residual: 1.87644e-08
voltage residual: 0.00068652
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.03584e-08
voltage residual: 0.000247606
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.1697e-08
voltage residual: 8.95232e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1233 eval = 428 reject = 0
start GMRES
current residual: 2.28002e-08
voltage residual: 3.20906e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1232 eval = 428 reject = 0
start GMRES
current residual: 2.0518e-08
voltage residual: 1.11301e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.17515e-08
voltage residual: 3.50063e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2223 eval = 790 reject = 1
Transient time = 0.6 cpu sec, 0.61 wall sec
23.7% DELTA_PHAS = -187.200000 ( etc = 4:28, ett = 5:43 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2161 eval = 458 reject = 34
Transient time = 0.59 cpu sec, 0.61 wall sec
number of transient points: 212
start GMRES
current residual: 0.000905049
voltage residual: 0.344747
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1243 eval = 393 reject = 23
Transient time = 0.29 cpu sec, 0.28 wall sec
number of transient points: 185
start GMRES
current residual: 2.57997e-05
voltage residual: 0.00392714
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1374 eval = 471 reject = 13
Transient time = 0.4 cpu sec, 0.4 wall sec
number of transient points: 458
start GMRES
current residual: 6.72795e-05
voltage residual: 0.00577851
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1240 eval = 458 reject = 0
start GMRES
current residual: 4.1319e-06
voltage residual: 0.00122111
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1237 eval = 458 reject = 0
start GMRES
current residual: 6.48729e-06
voltage residual: 0.000424762
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1235 eval = 458 reject = 0
start GMRES
current residual: 2.35159e-10
voltage residual: 0.000153539
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.08896e-11
voltage residual: 5.53945e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1234 eval = 458 reject = 0
start GMRES
current residual: 2.15565e-11
voltage residual: 1.96481e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.98417e-12
voltage residual: 6.59996e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.94252e-12
voltage residual: 1.89256e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1299 eval = 480 reject = 1
Transient time = 0.37 cpu sec, 0.39 wall sec
24.7% DELTA_PHAS = -180.000000 ( etc = 4:29, ett = 5:49 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1904 eval = 425 reject = 31
Transient time = 0.52 cpu sec, 0.53 wall sec
| CPU Time | 0.52 sec |
start GMRES
current residual: 4.64906e-06
voltage residual: 0.0107562
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1145 eval = 318 reject = 21
number of transient points: 297
start GMRES
current residual: 2.20894e-07
voltage residual: 0.00892722
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 921 eval = 297 reject = 0
Transient time = 0.25 cpu sec, 0.26 wall sec
start GMRES
current residual: 3.5437e-08
voltage residual: 0.00039837
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 922 eval = 297 reject = 0
Transient time = 0.26 cpu sec, 0.26 wall sec
| CPU Time | 0.26 sec |
start GMRES
current residual: 2.17056e-08
voltage residual: 0.000209646
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 920 eval = 297 reject = 0
start GMRES
current residual: 4.71085e-09
voltage residual: 0.000208702
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.20086e-09
voltage residual: 0.000208699
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.41149e-09
voltage residual: 0.000208795
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.24329e-09
voltage residual: 0.000208794
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1809 eval = 594 reject = 0
Transient time = 0.5 cpu sec, 0.51 wall sec
| CPU Time | 0.50 sec |
25.7% DELTA_PHAS = -172.800000 ( etc = 4:25, ett = 5:48 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1412 eval = 488 reject = 14
Transient time = 0.33 cpu sec, 0.35 wall sec
number of transient points: 237
start GMRES
current residual: 2.82102e-06
voltage residual: 0.00619031
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1232 eval = 389 reject = 15
number of transient points: 374
start GMRES
current residual: 2.04982e-05
voltage residual: 0.00522481
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1095 eval = 374 reject = 0
start GMRES
current residual: 1.94693e-08
voltage residual: 0.000198737
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.02729e-08
voltage residual: 0.000192845
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1097 eval = 374 reject = 0
start GMRES
current residual: 2.28863e-13
voltage residual: 3.64018e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1121 eval = 384 reject = 1
26.7% DELTA_PHAS = -165.600000 ( etc = 4:18, ett = 5:44 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1298 eval = 431 reject = 15
Transient time = 0.27 cpu sec, 0.32 wall sec
start GMRES
current residual: 2.60184e-06
voltage residual: 0.0062802
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1121 eval = 322 reject = 16
number of transient points: 306
start GMRES
current residual: 5.30142e-08
voltage residual: 0.00403109
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 978 eval = 306 reject = 0
start GMRES
current residual: 2.59264e-07
voltage residual: 0.00288328
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 979 eval = 306 reject = 0
start GMRES
current residual: 1.35027e-12
voltage residual: 1.37336e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.26 cpu sec, 0.25 wall sec
start GMRES
current residual: 9.11376e-15
voltage residual: 7.02614e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1921 eval = 612 reject = 0
Transient time = 0.51 cpu sec, 0.51 wall sec
27.7% DELTA_PHAS = -158.400000 ( etc = 4:10, ett = 5:39 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1087 eval = 341 reject = 15
number of transient points: 163
start GMRES
number of GMRES iterations: 5
current residual: 2.46592e-05
voltage residual: 0.00976826
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1269 eval = 333 reject = 23
Transient time = 0.32 cpu sec, 0.31 wall sec
number of transient points: 310
start GMRES
current residual: 1.37313e-05
voltage residual: 0.00620988
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1007 eval = 310 reject = 0
start GMRES
current residual: 2.23409e-08
voltage residual: 7.3567e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.51778e-13
voltage residual: 2.06323e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1040 eval = 322 reject = 1
28.7% DELTA_PHAS = -151.200000 ( etc = 4:02, ett = 5:32 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1183 eval = 378 reject = 16
Transient time = 0.24 cpu sec, 0.28 wall sec
number of transient points: 181
start GMRES
current residual: 3.31705e-06
voltage residual: 0.00838998
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1338 eval = 409 reject = 19
number of transient points: 390
start GMRES
current residual: 2.19047e-06
voltage residual: 0.0157967
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1135 eval = 390 reject = 0
start GMRES
current residual: 6.91072e-10
voltage residual: 0.000446308
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1134 eval = 390 reject = 0
start GMRES
current residual: 5.4514e-13
voltage residual: 1.1364e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1147 eval = 397 reject = 1
29.7% DELTA_PHAS = -144.000000 ( etc = 3:55, ett = 5:27 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1396 eval = 488 reject = 14
start GMRES
current residual: 1.10014e-05
voltage residual: 0.00582064
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1436 eval = 394 reject = 25
number of transient points: 369
start GMRES
current residual: 0.000449201
voltage residual: 0.0333193
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1118 eval = 369 reject = 0
start GMRES
current residual: 1.2733e-06
voltage residual: 0.000212066
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1117 eval = 369 reject = 0
start GMRES
current residual: 1.96949e-06
voltage residual: 0.000217388
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1120 eval = 369 reject = 0
start GMRES
current residual: 1.96946e-06
voltage residual: 0.000215725
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.9695e-06
voltage residual: 0.000217387
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.28 cpu sec, 0.29 wall sec
start GMRES
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1320 eval = 455 reject = 1
Transient time = 0.32 cpu sec, 0.35 wall sec
30.6% DELTA_PHAS = -136.800000 ( etc = 3:51, ett = 5:26 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1740 eval = 652 reject = 18
Transient time = 0.38 cpu sec, 0.39 wall sec
number of transient points: 317
start GMRES
current residual: 2.31992e-06
voltage residual: 0.0163549
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1373 eval = 373 reject = 21
number of transient points: 352
start GMRES
current residual: 6.98966e-07
voltage residual: 0.00913686
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1075 eval = 352 reject = 0
Transient time = 0.26 cpu sec, 0.28 wall sec
start GMRES
current residual: 3.08667e-09
voltage residual: 1.09644e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.27 cpu sec, 0.27 wall sec
start GMRES
current residual: 5.7629e-14
voltage residual: 1.79654e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1085 eval = 357 reject = 1
31.6% DELTA_PHAS = -129.600000 ( etc = 3:45, ett = 5:22 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1780 eval = 617 reject = 17
number of transient points: 300
start GMRES
current residual: 1.7669e-06
voltage residual: 0.00466516
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1621 eval = 547 reject = 20
number of transient points: 527
start GMRES
current residual: 2.51558e-06
voltage residual: 0.00540538
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1444 eval = 527 reject = 0
start GMRES
current residual: 1.80824e-07
voltage residual: 0.00229877
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.21229e-13
voltage residual: 1.2132e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.1608e-17
voltage residual: 1.5099e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1459 eval = 533 reject = 1
32.6% DELTA_PHAS = -122.400000 ( etc = 3:40, ett = 5:20 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1550 eval = 529 reject = 19
Transient time = 0.29 cpu sec, 0.35 wall sec
start GMRES
current residual: 8.75643e-07
voltage residual: 0.00204927
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1570 eval = 523 reject = 21
number of transient points: 502
start GMRES
current residual: 9.14045e-08
voltage residual: 0.00173562
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1386 eval = 502 reject = 0
start GMRES
current residual: 9.68758e-09
voltage residual: 0.000403494
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.76719e-13
voltage residual: 1.16541e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2741 eval = 1004 reject = 0
Transient time = 0.66 cpu sec, 0.66 wall sec
33.6% DELTA_PHAS = -115.200000 ( etc = 3:35, ett = 5:17 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1350 eval = 448 reject = 16
number of transient points: 216
start GMRES
current residual: 4.33548e-07
voltage residual: 0.00100067
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1639 eval = 524 reject = 23
number of transient points: 501
start GMRES
current residual: 6.52718e-07
voltage residual: 0.00478619
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1401 eval = 501 reject = 0
start GMRES
current residual: 1.5962e-07
voltage residual: 0.00274615
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.94751e-13
voltage residual: 1.69924e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.45066e-16
voltage residual: 6.44068e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2761 eval = 1002 reject = 0
Transient time = 0.68 cpu sec, 0.69 wall sec
34.6% DELTA_PHAS = -108.000000 ( etc = 3:31, ett = 5:16 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1431 eval = 478 reject = 18
number of transient points: 230
start GMRES
current residual: 5.21867e-08
voltage residual: 0.000148777
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1587 eval = 466 reject = 24
start GMRES
current residual: 3.3081e-06
voltage residual: 0.00548979
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1290 eval = 442 reject = 0
start GMRES
current residual: 2.534e-08
voltage residual: 0.000138065
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.48497e-15
voltage residual: 1.99137e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2546 eval = 884 reject = 0
35.6% DELTA_PHAS = -100.800000 ( etc = 3:26, ett = 5:14 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1324 eval = 430 reject = 18
Transient time = 0.27 cpu sec, 0.31 wall sec
number of transient points: 206
start GMRES
current residual: 1.144e-07
voltage residual: 0.000176985
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1850 eval = 595 reject = 24
number of transient points: 571
start GMRES
current residual: 2.7396e-07
voltage residual: 0.00106005
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1559 eval = 571 reject = 0
start GMRES
current residual: 4.55395e-08
voltage residual: 0.000293141
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.70846e-14
voltage residual: 5.99205e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 3070 eval = 1140 reject = 0
Transient time = 0.75 cpu sec, 0.76 wall sec
| CPU Time | 0.76 sec |
36.6% DELTA_PHAS = -93.600000 ( etc = 3:22, ett = 5:12 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1463 eval = 485 reject = 21
Transient time = 0.31 cpu sec, 0.34 wall sec
number of transient points: 232
start GMRES
current residual: 1.6791e-08
voltage residual: 0.000230598
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1727 eval = 506 reject = 27
Transient time = 0.42 cpu sec, 0.41 wall sec
number of transient points: 479
start GMRES
current residual: 4.72278e-06
voltage residual: 0.00561081
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1368 eval = 479 reject = 0
start GMRES
current residual: 9.03602e-08
voltage residual: 0.000173232
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.36 cpu sec, 0.34 wall sec
start GMRES
current residual: 5.82442e-14
voltage residual: 2.58848e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1944 eval = 691 reject = 1
Transient time = 0.48 cpu sec, 0.5 wall sec
| CPU Time | 0.48 sec |
37.6% DELTA_PHAS = -86.400000 ( etc = 3:17, ett = 5:10 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2995 eval = 769 reject = 53
Transient time = 0.77 cpu sec, 0.81 wall sec
| CPU Time | 0.77 sec |
| Peak Memory | 46.37 Mb |
number of transient points: 358
start GMRES
current residual: 2.13297e-06
voltage residual: 0.00720909
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1639 eval = 513 reject = 20
number of transient points: 493
start GMRES
current residual: 2.79874e-05
voltage residual: 0.00449097
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1392 eval = 493 reject = 0
start GMRES
current residual: 1.67694e-07
voltage residual: 0.00145074
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1393 eval = 493 reject = 0
start GMRES
current residual: 2.06488e-10
voltage residual: 0.000519195
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.42017e-11
voltage residual: 0.000187587
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1394 eval = 493 reject = 0
start GMRES
current residual: 2.44034e-11
voltage residual: 6.77759e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.0661e-12
voltage residual: 2.41666e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.76875e-12
voltage residual: 8.24537e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1391 eval = 493 reject = 0
start GMRES
current residual: 2.0991e-12
voltage residual: 2.47293e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2737 eval = 986 reject = 0
Transient time = 0.67 cpu sec, 0.68 wall sec
38.6% DELTA_PHAS = -79.200000 ( etc = 3:17, ett = 5:15 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2460 eval = 587 reject = 41
Transient time = 0.64 cpu sec, 0.67 wall sec
number of transient points: 273
start GMRES
current residual: 4.73506e-07
voltage residual: 0.00685933
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1561 eval = 444 reject = 31
number of transient points: 413
start GMRES
current residual: 0.000141155
voltage residual: 0.0139401
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1228 eval = 413 reject = 0
start GMRES
current residual: 2.83625e-07
voltage residual: 0.000854382
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1229 eval = 413 reject = 0
start GMRES
current residual: 3.3409e-08
voltage residual: 0.000308134
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.90296e-08
voltage residual: 0.000111555
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.96948e-07
voltage residual: 0.000212307
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1230 eval = 413 reject = 0
start GMRES
current residual: 1.57964e-09
voltage residual: 1.40401e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.31 cpu sec, 0.31 wall sec
start GMRES
current residual: 5.08077e-10
voltage residual: 4.52726e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.28771e-10
voltage residual: 1.15263e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2423 eval = 826 reject = 0
39.6% DELTA_PHAS = -72.000000 ( etc = 3:16, ett = 5:18 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1414 eval = 477 reject = 19
number of transient points: 229
start GMRES
current residual: 3.5335e-07
voltage residual: 0.000322529
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1788 eval = 549 reject = 26
number of transient points: 523
start GMRES
current residual: 7.45573e-05
voltage residual: 0.0260117
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1437 eval = 523 reject = 0
start GMRES
current residual: 1.56292e-09
voltage residual: 1.07532e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1438 eval = 523 reject = 0
start GMRES
current residual: 2.79571e-11
voltage residual: 8.13846e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.63847e-14
voltage residual: 1.50922e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1527 eval = 558 reject = 1
40.5% DELTA_PHAS = -64.800000 ( etc = 3:12, ett = 5:17 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1889 eval = 673 reject = 19
Transient time = 0.39 cpu sec, 0.42 wall sec
start GMRES
current residual: 1.33683e-05
voltage residual: 0.00359945
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1789 eval = 577 reject = 25
number of transient points: 552
start GMRES
current residual: 1.94526e-05
voltage residual: 0.00183718
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1503 eval = 552 reject = 0
start GMRES
current residual: 4.39458e-06
voltage residual: 0.00032665
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1506 eval = 552 reject = 0
start GMRES
current residual: 1.61278e-09
voltage residual: 0.000282649
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.74322e-13
voltage residual: 2.53072e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2964 eval = 1104 reject = 0
Transient time = 0.74 cpu sec, 0.75 wall sec
| CPU Time | 0.74 sec |
41.5% DELTA_PHAS = -57.600000 ( etc = 3:09, ett = 5:17 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1462 eval = 482 reject = 16
number of transient points: 233
start GMRES
current residual: 2.47961e-07
voltage residual: 0.00155995
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1844 eval = 635 reject = 20
Transient time = 0.43 cpu sec, 0.44 wall sec
| CPU Time | 0.43 sec |
number of transient points: 615
start GMRES
current residual: 6.15839e-05
voltage residual: 0.0250206
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1611 eval = 615 reject = 0
start GMRES
current residual: 2.17138e-08
voltage residual: 0.000147548
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.27068e-13
voltage residual: 5.61899e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1635 eval = 624 reject = 1
Warning: (input.spi:183) pulse fall time is < or = zero, reset to tstep
| CPU Time | 0.01 sec |
42.5% DELTA_PHAS = -50.400000 ( etc = 3:05, ett = 5:15 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1681 eval = 588 reject = 24
Transient time = 0.37 cpu sec, 0.41 wall sec
start GMRES
current residual: 4.54659e-06
voltage residual: 0.000489158
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1680 eval = 508 reject = 27
Transient time = 0.41 cpu sec, 0.42 wall sec
number of transient points: 481
start GMRES
current residual: 0.000154886
voltage residual: 0.0141386
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1374 eval = 481 reject = 0
start GMRES
current residual: 1.17453e-08
voltage residual: 2.87383e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.80378e-13
voltage residual: 1.50363e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2704 eval = 962 reject = 0
Total number of nodes (including internal nodes): 192
Resource Usage for Netlist Data Compression
| CPU Time | 0.00 sec |
43.5% DELTA_PHAS = -43.200000 ( etc = 3:01, ett = 5:14 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1456 eval = 490 reject = 18
number of transient points: 236
start GMRES
current residual: 2.87692e-05
voltage residual: 0.00162104
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1765 eval = 589 reject = 23
Transient time = 0.45 cpu sec, 0.47 wall sec
number of transient points: 566
start GMRES
current residual: 0.000129048
voltage residual: 0.00147736
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1490 eval = 566 reject = 0
start GMRES
current residual: 7.20145e-06
voltage residual: 0.00129549
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.41 cpu sec, 0.4 wall sec
start GMRES
current residual: 1.34403e-11
voltage residual: 3.94182e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.7241e-16
voltage residual: 2.54519e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1500 eval = 571 reject = 1
Transient time = 0.4 cpu sec, 0.44 wall sec
Resource Usage for Transient Analysis
44.5% DELTA_PHAS = -36.000000 ( etc = 2:57, ett = 5:13 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1938 eval = 455 reject = 33
number of transient points: 211
start GMRES
current residual: 1.00415e-06
voltage residual: 0.00323615
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1401 eval = 385 reject = 20
number of transient points: 365
start GMRES
current residual: 1.3029e-06
voltage residual: 0.00370758
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1156 eval = 365 reject = 0
start GMRES
current residual: 2.82141e-09
voltage residual: 2.48463e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.29 cpu sec, 0.29 wall sec
start GMRES
current residual: 2.86013e-16
voltage residual: 3.68935e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2273 eval = 730 reject = 0
Transient time = 0.56 cpu sec, 0.56 wall sec
| CPU Time | 0.56 sec |
Shooting Newton Sweep:
45.5% DELTA_PHAS = -28.800000 ( etc = 2:53, ett = 5:11 )
Input period: 2e-09
Warning: SN_ERR: Periodic source V17 has very small frequency=1 - may be incompatible with SN
number of transient points: 0
********** Shooting-Newton iteration 1 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1972 eval = 446 reject = 38
start GMRES
current residual: 7.98545e-07
voltage residual: 0.00670356
********** Shooting-Newton iteration 2 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1456 eval = 457 reject = 21
number of transient points: 436
start GMRES
current residual: 1.00397e-06
voltage residual: 0.00304625
********** Shooting-Newton iteration 3 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1262 eval = 436 reject = 0
start GMRES
current residual: 6.97022e-08
voltage residual: 0.00150617
********** Shooting-Newton iteration 4 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
number of GMRES iterations: 9
current residual: 1.55181e-08
voltage residual: 0.0002979
********** Shooting-Newton iteration 5 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1263 eval = 436 reject = 0
start GMRES
current residual: 5.78372e-09
voltage residual: 0.000107835
********** Shooting-Newton iteration 6 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.13393e-09
voltage residual: 3.87723e-05
********** Shooting-Newton iteration 7 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.797e-10
voltage residual: 1.35569e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.40886e-10
voltage residual: 4.36068e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.08435e-11
voltage residual: 1.10227e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2496 eval = 872 reject = 0
Transient time = 0.63 cpu sec, 0.65 wall sec
46.5% DELTA_PHAS = -21.600000 ( etc = 2:51, ett = 5:13 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1230 eval = 396 reject = 16
number of transient points: 190
start GMRES
current residual: 4.42564e-06
voltage residual: 0.00104119
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1333 eval = 358 reject = 28
number of transient points: 330
start GMRES
number of GMRES iterations: 10
current residual: 0.00024423
voltage residual: 0.00780695
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1040 eval = 330 reject = 0
start GMRES
current residual: 3.29871e-07
voltage residual: 0.000633179
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.28272e-11
voltage residual: 3.92548e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.35961e-14
voltage residual: 2.43249e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1598 eval = 513 reject = 1
47.5% DELTA_PHAS = -14.400000 ( etc = 2:47, ett = 5:11 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1923 eval = 337 reject = 35
Transient time = 0.57 cpu sec, 0.59 wall sec
| CPU Time | 0.57 sec |
number of transient points: 151
start GMRES
current residual: 0.0186135
voltage residual: 1.60186
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1124 eval = 347 reject = 17
| CPU Time | 0.25 sec |
number of transient points: 165
start GMRES
current residual: 2.70511e-05
voltage residual: 0.0204211
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1376 eval = 427 reject = 22
number of transient points: 405
start GMRES
number of GMRES iterations: 12
current residual: 2.09363e-05
voltage residual: 0.0194194
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1294 eval = 405 reject = 0
start GMRES
current residual: 0.000372769
voltage residual: 0.6626
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1187 eval = 405 reject = 0
| CPU Time | 0.31 sec |
start GMRES
current residual: 3.54824e-05
voltage residual: 0.179366
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1190 eval = 405 reject = 0
Transient time = 0.28 cpu sec, 0.32 wall sec
start GMRES
number of GMRES iterations: 6
current residual: 2.92353e-05
voltage residual: 0.0415861
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1191 eval = 405 reject = 0
Transient time = 0.29 cpu sec, 0.32 wall sec
| CPU Time | 0.29 sec |
start GMRES
number of GMRES iterations: 8
current residual: 5.96796e-06
voltage residual: 0.00837214
********** Shooting-Newton iteration 8 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1192 eval = 405 reject = 0
start GMRES
current residual: 3.63065e-07
voltage residual: 0.000570292
********** Shooting-Newton iteration 9 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.57213e-09
voltage residual: 2.44942e-06
********** Shooting-Newton iteration 10 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
| CPU Time | 0.30 sec |
start GMRES
current residual: 7.77104e-14
voltage residual: 1.32233e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1864 eval = 648 reject = 1
Transient time = 0.47 cpu sec, 0.5 wall sec
Steady-State Time Domain has converged successfully in 10 iterations
48.5% DELTA_PHAS = -7.200000 ( etc = 2:45, ett = 5:14 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1658 eval = 332 reject = 32
Transient time = 0.46 cpu sec, 0.49 wall sec
number of transient points: 150
start GMRES
current residual: 0.0166359
voltage residual: 1.49286
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1200 eval = 377 reject = 11
Transient time = 0.27 cpu sec, 0.29 wall sec
| CPU Time | 0.27 sec |
number of transient points: 183
start GMRES
current residual: 0.00789881
voltage residual: 0.695733
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1276 eval = 440 reject = 16
Transient time = 0.3 cpu sec, 0.3 wall sec
start GMRES
number of GMRES iterations: 4
current residual: 7.64097e-06
voltage residual: 0.0108958
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1162 eval = 351 reject = 16
Transient time = 0.31 cpu sec, 0.3 wall sec
number of transient points: 335
start GMRES
current residual: 0.000162784
voltage residual: 0.0110658
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1056 eval = 335 reject = 0
Transient time = 0.28 cpu sec, 0.27 wall sec
| CPU Time | 0.28 sec |
start GMRES
current residual: 9.82835e-06
voltage residual: 0.451697
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1024 eval = 335 reject = 0
start GMRES
current residual: 3.14535e-06
voltage residual: 0.107519
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1023 eval = 335 reject = 0
start GMRES
number of GMRES iterations: 7
current residual: 3.53312e-06
voltage residual: 0.0409039
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1022 eval = 335 reject = 0
start GMRES
current residual: 3.94958e-06
voltage residual: 0.00161279
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1021 eval = 335 reject = 0
start GMRES
current residual: 1.87006e-09
voltage residual: 6.22381e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.19043e-12
voltage residual: 6.85717e-08
********** Shooting-Newton iteration 11 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.11556e-15
voltage residual: 4.86167e-13
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1642 eval = 557 reject = 1
Steady-State Time Domain has converged successfully in 11 iterations
49.5% DELTA_PHAS = 0.000000 ( etc = 2:43, ett = 5:16 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1437 eval = 282 reject = 22
Transient time = 0.44 cpu sec, 0.46 wall sec
number of transient points: 130
start GMRES
current residual: 0.00310553
voltage residual: 0.166769
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 914 eval = 311 reject = 11
Transient time = 0.23 cpu sec, 0.24 wall sec
| CPU Time | 0.23 sec |
start GMRES
current residual: 0.000120783
voltage residual: 0.00584689
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 904 eval = 270 reject = 12
number of transient points: 258
start GMRES
current residual: 0.000984433
voltage residual: 0.0267612
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 777 eval = 258 reject = 0
Transient time = 0.22 cpu sec, 0.21 wall sec
| CPU Time | 0.22 sec |
start GMRES
current residual: 7.58017e-06
voltage residual: 0.374739
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 761 eval = 258 reject = 0
Transient time = 0.21 cpu sec, 0.22 wall sec
| CPU Time | 0.21 sec |
start GMRES
current residual: 3.49242e-06
voltage residual: 0.00885807
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 758 eval = 258 reject = 0
Transient time = 0.21 cpu sec, 0.21 wall sec
start GMRES
current residual: 1.17589e-05
voltage residual: 0.00236062
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 759 eval = 258 reject = 0
start GMRES
current residual: 1.15221e-05
voltage residual: 0.00356822
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.2 cpu sec, 0.22 wall sec
start GMRES
current residual: 1.14959e-05
voltage residual: 0.00070768
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 760 eval = 258 reject = 0
start GMRES
current residual: 1.15023e-05
voltage residual: 0.000313198
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.15025e-05
voltage residual: 0.000313202
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
********** Shooting-Newton iteration 12 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.22 cpu sec, 0.22 wall sec
start GMRES
********** Shooting-Newton iteration 13 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
Warning: trinit is extended by 4e-08
Transient Analysis
Maxtrinitcycles reached. Starting SN analysis.
solve = 2 eval = 1 reject = 0
Transient time = 0 cpu sec, 0 wall sec
********** Shooting-Newton iteration 14 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 902 eval = 313 reject = 13
Transient time = 0.22 cpu sec, 0.24 wall sec
start GMRES
current residual: 2.53271e-08
voltage residual: 0.00582317
********** Shooting-Newton iteration 15 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 860 eval = 252 reject = 8
number of transient points: 244
start GMRES
current residual: 1.11593e-06
voltage residual: 0.180388
********** Shooting-Newton iteration 16 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 751 eval = 244 reject = 0
start GMRES
current residual: 5.00023e-09
voltage residual: 0.000642802
********** Shooting-Newton iteration 17 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.19 cpu sec, 0.22 wall sec
| CPU Time | 0.20 sec |
start GMRES
current residual: 3.88763e-12
voltage residual: 6.36077e-05
********** Shooting-Newton iteration 18 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.50653e-13
voltage residual: 7.6539e-07
********** Shooting-Newton iteration 19 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.23 cpu sec, 0.22 wall sec
start GMRES
number of GMRES iterations: 11
current residual: 1.56559e-14
voltage residual: 2.93445e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 990 eval = 323 reject = 1
Transient time = 0.28 cpu sec, 0.3 wall sec
Steady-State Time Domain has converged successfully in 19 iterations
50.4% DELTA_PHAS = 7.200000 ( etc = 2:42, ett = 5:20 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2459 eval = 622 reject = 38
number of transient points: 292
start GMRES
current residual: 6.76999e-08
voltage residual: 0.141317
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1425 eval = 495 reject = 17
Transient time = 0.31 cpu sec, 0.35 wall sec
number of transient points: 239
start GMRES
current residual: 5.45375e-08
voltage residual: 0.0139976
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1157 eval = 348 reject = 18
Transient time = 0.3 cpu sec, 0.31 wall sec
start GMRES
current residual: 1.73158e-06
voltage residual: 0.0127976
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 982 eval = 330 reject = 0
Transient time = 0.26 cpu sec, 0.27 wall sec
start GMRES
current residual: 1.20215e-06
voltage residual: 0.0129735
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 984 eval = 330 reject = 0
start GMRES
current residual: 3.80682e-07
voltage residual: 0.00374445
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 985 eval = 330 reject = 0
start GMRES
current residual: 2.73942e-09
voltage residual: 7.08658e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.24153e-12
voltage residual: 2.46272e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.008e-15
voltage residual: 1.53277e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1358 eval = 460 reject = 1
Transient time = 0.38 cpu sec, 0.38 wall sec
| CPU Time | 0.38 sec |
Steady-State Time Domain has converged successfully in 8 iterations
51.4% DELTA_PHAS = 14.400000 ( etc = 2:38, ett = 5:21 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2149 eval = 548 reject = 34
Transient time = 0.56 cpu sec, 0.58 wall sec
number of transient points: 257
start GMRES
current residual: 1.31216e-06
voltage residual: 0.0707986
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1363 eval = 469 reject = 17
number of transient points: 226
start GMRES
current residual: 1.98644e-06
voltage residual: 0.0103928
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1466 eval = 491 reject = 20
number of transient points: 471
start GMRES
current residual: 2.00979e-06
voltage residual: 0.00438529
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1302 eval = 471 reject = 0
Transient time = 0.36 cpu sec, 0.37 wall sec
| CPU Time | 0.36 sec |
start GMRES
current residual: 5.61921e-08
voltage residual: 0.00021998
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.37701e-10
voltage residual: 1.18466e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.45065e-14
voltage residual: 5.08015e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1319 eval = 478 reject = 1
Transient time = 0.36 cpu sec, 0.38 wall sec
Steady-State Time Domain has converged successfully in 6 iterations
52.4% DELTA_PHAS = 21.600000 ( etc = 2:35, ett = 5:20 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2079 eval = 449 reject = 37
start GMRES
current residual: 1.10521e-06
voltage residual: 0.0159813
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1270 eval = 378 reject = 17
Transient time = 0.33 cpu sec, 0.34 wall sec
| CPU Time | 0.33 sec |
number of transient points: 361
start GMRES
current residual: 7.11699e-06
voltage residual: 0.00773035
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1108 eval = 361 reject = 0
start GMRES
current residual: 1.3001e-07
voltage residual: 0.000977033
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1109 eval = 361 reject = 0
start GMRES
current residual: 5.25063e-08
voltage residual: 0.000351926
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.95955e-08
voltage residual: 0.000127398
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1106 eval = 361 reject = 0
start GMRES
current residual: 7.10867e-09
voltage residual: 4.58986e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.48775e-09
voltage residual: 1.61562e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.96694e-10
voltage residual: 5.29825e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.97832e-10
voltage residual: 1.41649e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1249 eval = 408 reject = 1
Transient time = 0.32 cpu sec, 0.33 wall sec
Steady-State Time Domain has converged successfully in 9 iterations
53.4% DELTA_PHAS = 28.800000 ( etc = 2:32, ett = 5:21 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1713 eval = 553 reject = 21
| CPU Time | 0.40 sec |
number of transient points: 266
start GMRES
current residual: 7.75855e-06
voltage residual: 0.00293521
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1556 eval = 466 reject = 29
| CPU Time | 0.39 sec |
number of transient points: 437
start GMRES
current residual: 2.94341e-05
voltage residual: 0.00549658
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1265 eval = 437 reject = 0
Transient time = 0.31 cpu sec, 0.33 wall sec
| CPU Time | 0.32 sec |
start GMRES
current residual: 2.06639e-08
voltage residual: 5.9092e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1266 eval = 437 reject = 0
start GMRES
current residual: 9.55762e-12
voltage residual: 8.54461e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1267 eval = 437 reject = 0
start GMRES
current residual: 9.84726e-13
voltage residual: 1.2168e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1676 eval = 602 reject = 1
Steady-State Time Domain has converged successfully in 5 iterations
54.4% DELTA_PHAS = 36.000000 ( etc = 2:28, ett = 5:20 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2440 eval = 590 reject = 42
number of transient points: 274
start GMRES
current residual: 6.88847e-07
voltage residual: 0.00136159
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1454 eval = 434 reject = 28
number of transient points: 406
start GMRES
current residual: 7.2388e-06
voltage residual: 0.0070427
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1220 eval = 406 reject = 0
start GMRES
current residual: 6.31906e-07
voltage residual: 0.000687477
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1221 eval = 406 reject = 0
start GMRES
current residual: 2.18024e-12
voltage residual: 1.14609e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.00541e-14
voltage residual: 4.56502e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1360 eval = 453 reject = 1
55.4% DELTA_PHAS = 43.200000 ( etc = 2:24, ett = 5:19 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2546 eval = 674 reject = 40
Transient time = 0.51 cpu sec, 0.56 wall sec
| CPU Time | 0.51 sec |
start GMRES
current residual: 1.66381e-07
voltage residual: 0.0126412
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1575 eval = 515 reject = 25
Transient time = 0.39 cpu sec, 0.39 wall sec
start GMRES
current residual: 1.55209e-07
voltage residual: 0.00422134
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1364 eval = 490 reject = 0
Transient time = 0.34 cpu sec, 0.33 wall sec
| CPU Time | 0.34 sec |
start GMRES
current residual: 1.22103e-07
voltage residual: 0.00161601
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1368 eval = 490 reject = 0
start GMRES
current residual: 2.6782e-08
voltage residual: 0.000530907
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1366 eval = 490 reject = 0
Transient time = 0.34 cpu sec, 0.34 wall sec
start GMRES
current residual: 1.0379e-08
voltage residual: 0.000191981
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1365 eval = 490 reject = 0
start GMRES
current residual: 3.71434e-09
voltage residual: 6.9406e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.39635e-09
voltage residual: 2.47518e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1367 eval = 490 reject = 0
start GMRES
current residual: 4.61099e-10
voltage residual: 8.43613e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.33 cpu sec, 0.33 wall sec
start GMRES
current residual: 1.37461e-10
voltage residual: 2.51901e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2705 eval = 980 reject = 0
Transient time = 0.66 cpu sec, 0.67 wall sec
| CPU Time | 0.66 sec |
56.4% DELTA_PHAS = 50.400000 ( etc = 2:23, ett = 5:22 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1527 eval = 507 reject = 15
Transient time = 0.34 cpu sec, 0.35 wall sec
number of transient points: 246
start GMRES
current residual: 1.61187e-08
voltage residual: 0.00071632
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1664 eval = 553 reject = 25
| CPU Time | 0.41 sec |
number of transient points: 528
start GMRES
current residual: 7.17146e-08
voltage residual: 0.00265932
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1448 eval = 528 reject = 0
Transient time = 0.35 cpu sec, 0.35 wall sec
| CPU Time | 0.35 sec |
start GMRES
current residual: 2.85334e-08
voltage residual: 0.00014236
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1450 eval = 528 reject = 0
Transient time = 0.36 cpu sec, 0.36 wall sec
start GMRES
current residual: 1.35955e-11
voltage residual: 3.49717e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1451 eval = 528 reject = 0
Transient time = 0.35 cpu sec, 0.36 wall sec
start GMRES
current residual: 1.2091e-12
voltage residual: 2.217e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.36166e-15
voltage residual: 9.92177e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2872 eval = 1056 reject = 0
Transient time = 0.68 cpu sec, 0.73 wall sec
| CPU Time | 0.68 sec |
57.4% DELTA_PHAS = 57.600000 ( etc = 2:20, ett = 5:23 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1597 eval = 537 reject = 17
| CPU Time | 0.37 sec |
number of transient points: 260
start GMRES
current residual: 8.07493e-10
voltage residual: 0.00047695
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1797 eval = 621 reject = 18
Transient time = 0.44 cpu sec, 0.45 wall sec
| CPU Time | 0.45 sec |
number of transient points: 603
start GMRES
current residual: 4.42976e-06
voltage residual: 0.00388877
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1605 eval = 603 reject = 0
Transient time = 0.4 cpu sec, 0.41 wall sec
start GMRES
current residual: 4.61127e-09
voltage residual: 3.05049e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.4 cpu sec, 0.42 wall sec
start GMRES
current residual: 3.67922e-13
voltage residual: 7.51308e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.45503e-14
voltage residual: 1.15316e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1998 eval = 765 reject = 1
58.4% DELTA_PHAS = 64.800000 ( etc = 2:17, ett = 5:23 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2946 eval = 744 reject = 48
Transient time = 0.66 cpu sec, 0.7 wall sec
number of transient points: 348
start GMRES
current residual: 1.65038e-07
voltage residual: 0.00078563
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1704 eval = 542 reject = 23
| CPU Time | 0.42 sec |
number of transient points: 519
start GMRES
current residual: 1.59523e-07
voltage residual: 0.00259583
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1432 eval = 519 reject = 0
start GMRES
current residual: 1.54935e-08
voltage residual: 6.90936e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1433 eval = 519 reject = 0
Transient time = 0.37 cpu sec, 0.37 wall sec
start GMRES
current residual: 2.57834e-13
voltage residual: 4.35271e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2833 eval = 1038 reject = 0
Transient time = 0.74 cpu sec, 0.73 wall sec
Steady-State Time Domain has converged successfully in 4 iterations
59.4% DELTA_PHAS = 72.000000 ( etc = 2:12, ett = 5:21 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2558 eval = 648 reject = 40
Transient time = 0.55 cpu sec, 0.58 wall sec
| CPU Time | 0.55 sec |
number of transient points: 304
start GMRES
current residual: 8.36125e-08
voltage residual: 0.00665019
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1739 eval = 563 reject = 22
| CPU Time | 0.44 sec |
number of transient points: 541
start GMRES
current residual: 3.58831e-07
voltage residual: 0.00271253
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1471 eval = 541 reject = 0
Transient time = 0.37 cpu sec, 0.38 wall sec
start GMRES
current residual: 3.36629e-08
voltage residual: 0.000884571
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.48678e-08
voltage residual: 0.00029868
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.9026e-09
voltage residual: 0.000108124
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.12763e-09
voltage residual: 3.88795e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.44709e-10
voltage residual: 1.35966e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.39 cpu sec, 0.38 wall sec
start GMRES
current residual: 2.39368e-10
voltage residual: 4.37474e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.36 cpu sec, 0.39 wall sec
start GMRES
current residual: 6.04704e-11
voltage residual: 1.10657e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2909 eval = 1082 reject = 0
Transient time = 0.74 cpu sec, 0.77 wall sec
60.3% DELTA_PHAS = 79.200000 ( etc = 2:11, ett = 5:24 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1691 eval = 579 reject = 21
Transient time = 0.36 cpu sec, 0.4 wall sec
number of transient points: 279
start GMRES
current residual: 7.16027e-08
voltage residual: 0.000252023
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1753 eval = 552 reject = 31
number of transient points: 521
start GMRES
current residual: 4.21867e-05
voltage residual: 0.00451735
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1421 eval = 521 reject = 0
start GMRES
current residual: 6.00857e-11
voltage residual: 5.22883e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.36 cpu sec, 0.35 wall sec
start GMRES
current residual: 2.74835e-13
voltage residual: 4.13497e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.47667e-14
voltage residual: 4.34867e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1947 eval = 727 reject = 1
Transient time = 0.47 cpu sec, 0.48 wall sec
| CPU Time | 0.47 sec |
61.3% DELTA_PHAS = 86.400000 ( etc = 2:07, ett = 5:23 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2609 eval = 599 reject = 45
Transient time = 0.63 cpu sec, 0.69 wall sec
| CPU Time | 0.63 sec |
number of transient points: 277
start GMRES
current residual: 3.86747e-07
voltage residual: 0.00311205
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1735 eval = 562 reject = 23
Transient time = 0.42 cpu sec, 0.42 wall sec
number of transient points: 539
start GMRES
current residual: 2.82498e-05
voltage residual: 0.00271913
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1466 eval = 539 reject = 0
start GMRES
current residual: 1.62817e-08
voltage residual: 8.75237e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 9.74765e-14
voltage residual: 4.20913e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2904 eval = 1078 reject = 0
Transient time = 0.73 cpu sec, 0.73 wall sec
| CPU Time | 0.73 sec |
62.3% DELTA_PHAS = 93.600000 ( etc = 2:03, ett = 5:23 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2522 eval = 617 reject = 41
Transient time = 0.58 cpu sec, 0.62 wall sec
| CPU Time | 0.58 sec |
number of transient points: 288
start GMRES
current residual: 8.6219e-07
voltage residual: 0.00663297
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1698 eval = 537 reject = 22
Transient time = 0.42 cpu sec, 0.44 wall sec
number of transient points: 515
start GMRES
current residual: 4.18923e-05
voltage residual: 0.00371115
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1433 eval = 515 reject = 0
start GMRES
current residual: 4.03115e-08
voltage residual: 0.000819443
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.35 cpu sec, 0.41 wall sec
start GMRES
current residual: 1.57025e-08
voltage residual: 0.000295569
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.37 cpu sec, 0.42 wall sec
start GMRES
current residual: 5.82311e-09
voltage residual: 0.000106999
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.35 cpu sec, 0.39 wall sec
start GMRES
current residual: 2.10922e-09
voltage residual: 3.84691e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.38354e-10
voltage residual: 1.34474e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.37064e-10
voltage residual: 4.32106e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.96559e-11
voltage residual: 1.08884e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2837 eval = 1030 reject = 0
Transient time = 0.71 cpu sec, 0.75 wall sec
| CPU Time | 0.71 sec |
63.3% DELTA_PHAS = 100.800000 ( etc = 2:02, ett = 5:26 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1572 eval = 525 reject = 17
Transient time = 0.35 cpu sec, 0.38 wall sec
number of transient points: 254
start GMRES
current residual: 4.63932e-09
voltage residual: 0.000145479
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1842 eval = 610 reject = 21
Transient time = 0.45 cpu sec, 0.44 wall sec
number of transient points: 589
start GMRES
current residual: 0.00101826
voltage residual: 0.00331937
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1577 eval = 589 reject = 0
start GMRES
current residual: 3.2374e-08
voltage residual: 5.74467e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.78589e-13
voltage residual: 3.07679e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2026 eval = 750 reject = 1
64.3% DELTA_PHAS = 108.000000 ( etc = 1:57, ett = 5:23 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2568 eval = 595 reject = 43
Transient time = 0.63 cpu sec, 0.66 wall sec
number of transient points: 276
start GMRES
current residual: 5.22074e-07
voltage residual: 0.00197907
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1985 eval = 660 reject = 21
Transient time = 0.46 cpu sec, 0.5 wall sec
| CPU Time | 0.46 sec |
number of transient points: 639
start GMRES
current residual: 1.11525e-06
voltage residual: 0.00151464
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1716 eval = 639 reject = 0
start GMRES
current residual: 6.07036e-08
voltage residual: 0.000773304
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1715 eval = 639 reject = 0
start GMRES
current residual: 1.23983e-12
voltage residual: 5.34164e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.41553e-15
voltage residual: 1.53211e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1994 eval = 740 reject = 1
Transient time = 0.48 cpu sec, 0.49 wall sec
| CPU Time | 0.49 sec |
65.3% DELTA_PHAS = 115.200000 ( etc = 1:53, ett = 5:23 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1776 eval = 584 reject = 18
Transient time = 0.37 cpu sec, 0.4 wall sec
number of transient points: 283
start GMRES
current residual: 4.53389e-06
voltage residual: 0.000356641
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1672 eval = 541 reject = 22
start GMRES
current residual: 1.46758e-05
voltage residual: 0.00130065
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1422 eval = 519 reject = 0
start GMRES
current residual: 2.30439e-07
voltage residual: 8.39925e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.51586e-13
voltage residual: 3.59415e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1909 eval = 698 reject = 1
Transient time = 0.46 cpu sec, 0.48 wall sec
66.3% DELTA_PHAS = 122.400000 ( etc = 1:48, ett = 5:21 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2462 eval = 542 reject = 40
| CPU Time | 0.64 sec |
number of transient points: 251
start GMRES
current residual: 0.000119056
voltage residual: 0.000823623
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1730 eval = 585 reject = 23
number of transient points: 562
start GMRES
current residual: 0.000134115
voltage residual: 0.00314815
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1522 eval = 562 reject = 0
start GMRES
current residual: 2.33732e-06
voltage residual: 0.000185584
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1523 eval = 562 reject = 0
start GMRES
current residual: 4.68067e-07
voltage residual: 0.000146809
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.86257e-11
voltage residual: 2.6791e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1900 eval = 695 reject = 1
Transient time = 0.45 cpu sec, 0.48 wall sec
67.3% DELTA_PHAS = 129.600000 ( etc = 1:45, ett = 5:21 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2020 eval = 456 reject = 36
number of transient points: 210
start GMRES
current residual: 1.42454e-05
voltage residual: 0.0186182
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1590 eval = 496 reject = 27
number of transient points: 469
start GMRES
current residual: 2.76035e-05
voltage residual: 0.00622643
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1322 eval = 469 reject = 0
start GMRES
current residual: 1.56844e-07
voltage residual: 0.00215532
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.62546e-08
voltage residual: 0.000768271
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1323 eval = 469 reject = 0
start GMRES
current residual: 2.94017e-08
voltage residual: 0.000277274
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1324 eval = 469 reject = 0
Transient time = 0.32 cpu sec, 0.34 wall sec
start GMRES
current residual: 1.76798e-06
voltage residual: 0.000389335
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.93605e-09
voltage residual: 3.60364e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.36815e-09
voltage residual: 1.25481e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.31657e-10
voltage residual: 3.98802e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.03493e-10
voltage residual: 9.74273e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.1625e-11
voltage residual: 1.14825e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2616 eval = 938 reject = 0
Transient time = 0.64 cpu sec, 0.66 wall sec
| CPU Time | 0.65 sec |
68.3% DELTA_PHAS = 136.800000 ( etc = 1:42, ett = 5:24 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2141 eval = 442 reject = 36
Transient time = 0.5 cpu sec, 0.53 wall sec
number of transient points: 203
start GMRES
current residual: 4.03037e-07
voltage residual: 0.00756654
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1430 eval = 432 reject = 25
number of transient points: 407
start GMRES
current residual: 7.36715e-06
voltage residual: 0.00725394
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1185 eval = 407 reject = 0
start GMRES
current residual: 9.43643e-08
voltage residual: 0.000757959
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1184 eval = 407 reject = 0
start GMRES
current residual: 1.43439e-08
voltage residual: 0.000273536
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1186 eval = 407 reject = 0
start GMRES
current residual: 5.31518e-09
voltage residual: 9.90164e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.9219e-09
voltage residual: 3.55572e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.69515e-10
voltage residual: 1.23824e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.12159e-10
voltage residual: 3.93431e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.14494e-11
voltage residual: 9.59518e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2339 eval = 814 reject = 0
Transient time = 0.61 cpu sec, 0.62 wall sec
| CPU Time | 0.61 sec |
69.3% DELTA_PHAS = 144.000000 ( etc = 1:40, ett = 5:25 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1968 eval = 470 reject = 32
Transient time = 0.44 cpu sec, 0.44 wall sec
number of transient points: 219
start GMRES
current residual: 0.000230126
voltage residual: 0.0268531
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1492 eval = 494 reject = 23
start GMRES
current residual: 0.000409716
voltage residual: 0.0314
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1305 eval = 471 reject = 0
Transient time = 0.33 cpu sec, 0.32 wall sec
start GMRES
current residual: 3.81764e-06
voltage residual: 0.000776378
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 9.08547e-11
voltage residual: 2.64942e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.59778e-14
voltage residual: 1.61448e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1360 eval = 489 reject = 1
Transient time = 0.34 cpu sec, 0.36 wall sec
70.2% DELTA_PHAS = 151.200000 ( etc = 1:37, ett = 5:25 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1935 eval = 443 reject = 35
number of transient points: 204
start GMRES
current residual: 0.000164346
voltage residual: 0.0234494
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1389 eval = 434 reject = 23
number of transient points: 411
start GMRES
current residual: 0.000398441
voltage residual: 0.0253558
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1198 eval = 411 reject = 0
start GMRES
current residual: 7.69607e-09
voltage residual: 0.000202211
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.6891e-11
voltage residual: 1.817e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1663 eval = 565 reject = 1
Transient time = 0.45 cpu sec, 0.46 wall sec
71.2% DELTA_PHAS = 158.400000 ( etc = 1:34, ett = 5:24 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2459 eval = 492 reject = 44
Transient time = 0.65 cpu sec, 0.69 wall sec
number of transient points: 224
start GMRES
current residual: 0.0153184
voltage residual: 1.80037
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1111 eval = 333 reject = 17
Transient time = 0.24 cpu sec, 0.26 wall sec
| CPU Time | 0.24 sec |
number of transient points: 158
start GMRES
current residual: 0.000230251
voltage residual: 0.265643
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1388 eval = 458 reject = 18
number of transient points: 220
start GMRES
current residual: 6.01631e-06
voltage residual: 0.0354513
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1469 eval = 478 reject = 15
number of transient points: 463
start GMRES
current residual: 0.000305473
voltage residual: 0.0359034
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1316 eval = 463 reject = 0
start GMRES
current residual: 4.00818e-06
voltage residual: 0.000796159
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1317 eval = 463 reject = 0
Transient time = 0.38 cpu sec, 0.37 wall sec
start GMRES
current residual: 1.61556e-06
voltage residual: 9.50331e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.26541e-12
voltage residual: 2.16152e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2006 eval = 708 reject = 1
Transient time = 0.53 cpu sec, 0.54 wall sec
| CPU Time | 0.53 sec |
Steady-State Time Domain has converged successfully in 7 iterations
72.2% DELTA_PHAS = 165.600000 ( etc = 1:31, ett = 5:25 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2091 eval = 425 reject = 37
Transient time = 0.61 cpu sec, 0.63 wall sec
number of transient points: 194
start GMRES
current residual: 0.00109772
voltage residual: 0.278806
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1093 eval = 321 reject = 19
Transient time = 0.26 cpu sec, 0.26 wall sec
| CPU Time | 0.26 sec |
start GMRES
current residual: 8.76606e-07
voltage residual: 0.23759
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1111 eval = 333 reject = 21
number of transient points: 156
start GMRES
current residual: 2.24592e-05
voltage residual: 0.155164
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1266 eval = 414 reject = 20
Transient time = 0.3 cpu sec, 0.29 wall sec
number of transient points: 197
start GMRES
current residual: 1.12261e-05
voltage residual: 0.0174798
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1362 eval = 410 reject = 25
number of transient points: 385
start GMRES
current residual: 0.000249724
voltage residual: 0.0281892
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1132 eval = 385 reject = 0
start GMRES
current residual: 2.32097e-06
voltage residual: 0.000465396
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.28 cpu sec, 0.28 wall sec
start GMRES
current residual: 3.51108e-10
voltage residual: 0.000168181
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.26764e-10
voltage residual: 6.07146e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1130 eval = 385 reject = 0
start GMRES
current residual: 4.53951e-11
voltage residual: 2.15896e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.5345e-11
voltage residual: 7.30389e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.53524e-12
voltage residual: 2.13682e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1293 eval = 443 reject = 1
73.2% DELTA_PHAS = 172.800000 ( etc = 1:27, ett = 5:26 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2087 eval = 465 reject = 41
Transient time = 0.6 cpu sec, 0.61 wall sec
| CPU Time | 0.60 sec |
number of transient points: 212
start GMRES
current residual: 0.000121475
voltage residual: 0.141918
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1216 eval = 390 reject = 16
number of transient points: 187
start GMRES
current residual: 6.45599e-07
voltage residual: 0.00360955
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1412 eval = 472 reject = 18
number of transient points: 454
start GMRES
current residual: 2.03802e-05
voltage residual: 0.0102959
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1256 eval = 454 reject = 0
start GMRES
current residual: 1.64714e-06
voltage residual: 0.00067167
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1252 eval = 454 reject = 0
start GMRES
current residual: 1.56761e-08
voltage residual: 0.000242614
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1253 eval = 454 reject = 0
start GMRES
current residual: 9.45968e-09
voltage residual: 8.77908e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.37428e-09
voltage residual: 3.14561e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.16322e-09
voltage residual: 1.08748e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.58536e-10
voltage residual: 3.38416e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1270 eval = 461 reject = 1
74.2% DELTA_PHAS = 180.000000 ( etc = 1:24, ett = 5:26 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1561 eval = 562 reject = 14
Transient time = 0.37 cpu sec, 0.39 wall sec
start GMRES
current residual: 2.43295e-06
voltage residual: 0.000690851
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1117 eval = 319 reject = 19
number of transient points: 300
start GMRES
current residual: 1.2864e-05
voltage residual: 0.00561266
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 919 eval = 300 reject = 0
Transient time = 0.25 cpu sec, 0.25 wall sec
start GMRES
current residual: 1.91254e-06
voltage residual: 0.000373942
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 915 eval = 300 reject = 0
start GMRES
current residual: 4.83627e-10
voltage residual: 1.14055e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 917 eval = 300 reject = 0
start GMRES
current residual: 5.54269e-12
voltage residual: 7.40074e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.26 cpu sec, 0.25 wall sec
start GMRES
current residual: 2.39755e-13
voltage residual: 9.45494e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 927 eval = 305 reject = 1
Transient time = 0.25 cpu sec, 0.26 wall sec
75.2% DELTA_PHAS = 187.200000 ( etc = 1:20, ett = 5:25 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1326 eval = 445 reject = 15
Transient time = 0.31 cpu sec, 0.32 wall sec
number of transient points: 215
start GMRES
current residual: 7.28934e-07
voltage residual: 3.92687e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1114 eval = 305 reject = 25
Transient time = 0.28 cpu sec, 0.29 wall sec
number of transient points: 280
start GMRES
current residual: 0.000221288
voltage residual: 0.0114693
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 913 eval = 280 reject = 0
Transient time = 0.24 cpu sec, 0.24 wall sec
start GMRES
current residual: 7.57852e-06
voltage residual: 0.000558377
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 912 eval = 280 reject = 0
start GMRES
current residual: 1.62984e-11
voltage residual: 1.93247e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 914 eval = 280 reject = 0
start GMRES
current residual: 1.89647e-12
voltage residual: 6.28494e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.08692e-14
voltage residual: 1.9404e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 952 eval = 294 reject = 1
Transient time = 0.25 cpu sec, 0.27 wall sec
76.2% DELTA_PHAS = 194.400000 ( etc = 1:17, ett = 5:24 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1241 eval = 396 reject = 12
number of transient points: 192
start GMRES
current residual: 6.84234e-06
voltage residual: 0.000244147
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1202 eval = 362 reject = 20
number of transient points: 342
start GMRES
current residual: 2.19954e-05
voltage residual: 0.0105796
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1028 eval = 342 reject = 0
Transient time = 0.27 cpu sec, 0.28 wall sec
start GMRES
current residual: 3.00362e-06
voltage residual: 0.000436729
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1027 eval = 342 reject = 0
start GMRES
current residual: 3.14658e-11
voltage residual: 5.43565e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1063 eval = 355 reject = 1
77.2% DELTA_PHAS = 201.600000 ( etc = 1:13, ett = 5:22 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1116 eval = 339 reject = 15
Transient time = 0.21 cpu sec, 0.26 wall sec
number of transient points: 162
start GMRES
current residual: 8.56203e-07
voltage residual: 0.000172282
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1300 eval = 371 reject = 28
number of transient points: 343
start GMRES
current residual: 1.50408e-05
voltage residual: 0.0104656
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1070 eval = 343 reject = 0
Transient time = 0.27 cpu sec, 0.27 wall sec
start GMRES
current residual: 6.67056e-07
voltage residual: 0.000659579
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1069 eval = 343 reject = 0
start GMRES
current residual: 7.78731e-12
voltage residual: 4.38429e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.36609e-17
voltage residual: 1.59879e-13
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2107 eval = 686 reject = 0
Transient time = 0.55 cpu sec, 0.54 wall sec
78.2% DELTA_PHAS = 208.800000 ( etc = 1:10, ett = 5:21 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1340 eval = 425 reject = 19
Transient time = 0.28 cpu sec, 0.31 wall sec
| Peak Memory | 46.37 Mb |
start GMRES
current residual: 9.09235e-07
voltage residual: 0.000431375
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1370 eval = 420 reject = 28
number of transient points: 392
start GMRES
current residual: 9.91202e-06
voltage residual: 0.0122353
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1151 eval = 392 reject = 0
Transient time = 0.29 cpu sec, 0.3 wall sec
start GMRES
current residual: 1.30807e-06
voltage residual: 0.000255061
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.87581e-13
voltage residual: 2.83275e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.71304e-17
voltage residual: 6.66932e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2270 eval = 784 reject = 0
Transient time = 0.59 cpu sec, 0.6 wall sec
| CPU Time | 0.59 sec |
79.2% DELTA_PHAS = 216.000000 ( etc = 1:07, ett = 5:21 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1289 eval = 410 reject = 16
Transient time = 0.29 cpu sec, 0.31 wall sec
start GMRES
number of GMRES iterations: 5
current residual: 2.64473e-06
voltage residual: 0.000132712
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1386 eval = 411 reject = 29
Transient time = 0.35 cpu sec, 0.34 wall sec
number of transient points: 382
start GMRES
current residual: 0.000100613
voltage residual: 0.0112978
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1146 eval = 382 reject = 0
start GMRES
current residual: 1.30852e-07
voltage residual: 0.000313321
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.02681e-12
voltage residual: 1.04647e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.58294e-16
voltage residual: 2.14939e-13
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1179 eval = 394 reject = 1
Transient time = 0.32 cpu sec, 0.37 wall sec
80.1% DELTA_PHAS = 223.200000 ( etc = 1:04, ett = 5:20 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1301 eval = 411 reject = 17
Transient time = 0.27 cpu sec, 0.34 wall sec
start GMRES
current residual: 5.91567e-07
voltage residual: 0.00012579
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1614 eval = 498 reject = 26
number of transient points: 472
start GMRES
current residual: 4.63314e-05
voltage residual: 0.0132994
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1346 eval = 472 reject = 0
Transient time = 0.32 cpu sec, 0.36 wall sec
start GMRES
current residual: 8.93306e-06
voltage residual: 0.00173701
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.32335e-07
voltage residual: 0.000141016
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.96609e-13
voltage residual: 8.00863e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2660 eval = 944 reject = 0
Transient time = 0.66 cpu sec, 0.68 wall sec
81.1% DELTA_PHAS = 230.400000 ( etc = 1:01, ett = 5:20 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1291 eval = 406 reject = 16
number of transient points: 195
start GMRES
current residual: 2.01145e-06
voltage residual: 0.000175255
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1524 eval = 437 reject = 29
number of transient points: 408
start GMRES
current residual: 7.91458e-05
voltage residual: 0.0135372
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1240 eval = 408 reject = 0
Transient time = 0.32 cpu sec, 0.32 wall sec
start GMRES
current residual: 1.56786e-05
voltage residual: 0.00173086
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1238 eval = 408 reject = 0
start GMRES
current residual: 2.1362e-11
voltage residual: 1.24164e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1260 eval = 417 reject = 1
82.1% DELTA_PHAS = 237.600000 ( etc = 58.3 sec, ett = 5:18 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1305 eval = 410 reject = 18
number of transient points: 196
start GMRES
current residual: 1.23525e-06
voltage residual: 0.000164486
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1594 eval = 503 reject = 24
Transient time = 0.4 cpu sec, 0.4 wall sec
number of transient points: 479
start GMRES
current residual: 1.37033e-05
voltage residual: 0.00697891
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1346 eval = 479 reject = 0
Transient time = 0.33 cpu sec, 0.35 wall sec
start GMRES
current residual: 3.67767e-06
voltage residual: 0.00047867
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1348 eval = 479 reject = 0
start GMRES
current residual: 5.19425e-08
voltage residual: 1.42521e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.70489e-14
voltage residual: 8.48166e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1549 eval = 546 reject = 1
83.1% DELTA_PHAS = 244.800000 ( etc = 55.1 sec, ett = 5:17 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2046 eval = 690 reject = 20
start GMRES
current residual: 2.72691e-05
voltage residual: 0.00355959
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1876 eval = 646 reject = 20
Transient time = 0.47 cpu sec, 0.47 wall sec
number of transient points: 626
start GMRES
current residual: 4.46564e-05
voltage residual: 0.0153904
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1625 eval = 626 reject = 0
Transient time = 0.42 cpu sec, 0.41 wall sec
start GMRES
current residual: 5.53716e-06
voltage residual: 0.00064795
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1622 eval = 626 reject = 0
Transient time = 0.41 cpu sec, 0.41 wall sec
start GMRES
current residual: 8.93037e-09
voltage residual: 3.52256e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.59147e-14
voltage residual: 2.98872e-13
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1891 eval = 733 reject = 1
Transient time = 0.49 cpu sec, 0.51 wall sec
Warning: (input.spi:183) pulse fall time is < or = zero, reset to tstep
84.1% DELTA_PHAS = 252.000000 ( etc = 51.9 sec, ett = 5:17 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1526 eval = 490 reject = 20
number of transient points: 235
start GMRES
current residual: 1.10122e-07
voltage residual: 0.000386295
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1699 eval = 558 reject = 23
number of transient points: 535
start GMRES
current residual: 3.88411e-05
voltage residual: 0.0126937
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1446 eval = 535 reject = 0
start GMRES
current residual: 5.15031e-07
voltage residual: 0.000634716
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.37 cpu sec, 0.36 wall sec
start GMRES
current residual: 1.56579e-09
voltage residual: 1.75354e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.20553e-14
voltage residual: 5.79335e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1694 eval = 618 reject = 1
Total number of nodes (including internal nodes): 192
Resource Usage for Netlist Data Compression
| CPU Time | 0.00 sec |
85.1% DELTA_PHAS = 259.200000 ( etc = 48.8 sec, ett = 5:17 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1834 eval = 628 reject = 16
Transient time = 0.4 cpu sec, 0.43 wall sec
number of transient points: 306
start GMRES
current residual: 0.000271342
voltage residual: 0.157786
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1387 eval = 437 reject = 19
number of transient points: 209
start GMRES
current residual: 7.31616e-08
voltage residual: 0.000138792
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1787 eval = 605 reject = 19
Transient time = 0.44 cpu sec, 0.43 wall sec
number of transient points: 586
start GMRES
current residual: 1.86103e-05
voltage residual: 0.0101735
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1542 eval = 586 reject = 0
start GMRES
current residual: 2.36848e-06
voltage residual: 0.000602099
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1540 eval = 586 reject = 0
Resource Usage for Transient Analysis
start GMRES
current residual: 2.30059e-12
voltage residual: 8.38557e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 9.73614e-17
voltage residual: 2.04281e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1753 eval = 658 reject = 1
Transient time = 0.44 cpu sec, 0.47 wall sec
86.1% DELTA_PHAS = 266.400000 ( etc = 45.7 sec, ett = 5:17 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1565 eval = 508 reject = 22
number of transient points: 243
start GMRES
current residual: 1.14949e-05
voltage residual: 0.00235452
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1722 eval = 557 reject = 26
Transient time = 0.43 cpu sec, 0.43 wall sec
| CPU Time | 0.43 sec |
number of transient points: 531
start GMRES
current residual: 0.000122535
voltage residual: 0.0160458
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1437 eval = 531 reject = 0
start GMRES
current residual: 3.37635e-06
voltage residual: 0.000719508
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1433 eval = 531 reject = 0
start GMRES
current residual: 1.44296e-05
voltage residual: 0.0019903
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1434 eval = 531 reject = 0
start GMRES
current residual: 6.13762e-06
voltage residual: 0.000793041
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.69827e-11
voltage residual: 4.53409e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1536 eval = 565 reject = 1
Shooting Newton Sweep:
87.1% DELTA_PHAS = 273.600000 ( etc = 42.6 sec, ett = 5:17 )
Input period: 2e-09
Warning: SN_ERR: Periodic source V17 has very small frequency=1 - may be incompatible with SN
number of transient points: 0
********** Shooting-Newton iteration 1 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1723 eval = 590 reject = 18
number of transient points: 286
start GMRES
current residual: 6.6955e-06
voltage residual: 0.0037804
********** Shooting-Newton iteration 2 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1738 eval = 538 reject = 32
Transient time = 0.41 cpu sec, 0.42 wall sec
number of transient points: 506
start GMRES
current residual: 0.000155415
voltage residual: 0.0185018
********** Shooting-Newton iteration 3 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1387 eval = 506 reject = 0
start GMRES
current residual: 2.11639e-06
voltage residual: 0.000294552
********** Shooting-Newton iteration 4 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1391 eval = 506 reject = 0
start GMRES
number of GMRES iterations: 9
current residual: 7.21459e-10
voltage residual: 8.19959e-08
********** Shooting-Newton iteration 5 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.03043e-15
voltage residual: 6.30607e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1459 eval = 525 reject = 1
88.1% DELTA_PHAS = 280.800000 ( etc = 38.8 sec, ett = 5:16 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1626 eval = 525 reject = 21
number of transient points: 252
start GMRES
current residual: 1.30525e-05
voltage residual: 0.00156211
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1720 eval = 580 reject = 24
number of transient points: 556
start GMRES
current residual: 0.00014641
voltage residual: 0.016116
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1494 eval = 556 reject = 0
start GMRES
current residual: 3.76362e-06
voltage residual: 0.00105187
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1492 eval = 556 reject = 0
start GMRES
number of GMRES iterations: 10
current residual: 3.57945e-10
voltage residual: 9.39851e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.67362e-17
voltage residual: 9.99201e-15
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2947 eval = 1112 reject = 0
Transient time = 0.72 cpu sec, 0.74 wall sec
| CPU Time | 0.72 sec |
89.1% DELTA_PHAS = 288.000000 ( etc = 35.2 sec, ett = 5:16 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1359 eval = 429 reject = 17
number of transient points: 206
start GMRES
current residual: 3.20974e-07
voltage residual: 0.000253363
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1508 eval = 463 reject = 23
number of transient points: 440
start GMRES
current residual: 4.07097e-05
voltage residual: 0.00926385
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1273 eval = 440 reject = 0
start GMRES
current residual: 4.83521e-07
voltage residual: 0.000691806
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1276 eval = 440 reject = 0
start GMRES
current residual: 3.63684e-12
voltage residual: 1.73647e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.92832e-16
voltage residual: 3.33067e-14
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1309 eval = 451 reject = 1
Transient time = 0.3 cpu sec, 0.34 wall sec
90.0% DELTA_PHAS = 295.200000 ( etc = 32.2 sec, ett = 5:15 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1530 eval = 498 reject = 18
number of transient points: 240
start GMRES
current residual: 0.00121176
voltage residual: 0.207622
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1371 eval = 434 reject = 16
| CPU Time | 0.29 sec |
start GMRES
current residual: 1.14222e-07
voltage residual: 0.000334382
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1517 eval = 469 reject = 23
number of transient points: 446
start GMRES
number of GMRES iterations: 8
current residual: 2.60455e-05
voltage residual: 0.0115786
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1279 eval = 446 reject = 0
start GMRES
current residual: 9.53907e-05
voltage residual: 0.000719225
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.21671e-12
voltage residual: 1.76208e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1718 eval = 613 reject = 1
Transient time = 0.45 cpu sec, 0.45 wall sec
91.0% DELTA_PHAS = 302.400000 ( etc = 28.9 sec, ett = 5:14 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2637 eval = 503 reject = 41
number of transient points: 231
start GMRES
current residual: 8.4796e-05
voltage residual: 0.1289
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1517 eval = 508 reject = 18
Transient time = 0.31 cpu sec, 0.31 wall sec
| CPU Time | 0.31 sec |
number of transient points: 245
start GMRES
current residual: 1.6151e-06
voltage residual: 0.0816103
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1586 eval = 540 reject = 18
number of transient points: 261
start GMRES
current residual: 1.03227e-05
voltage residual: 0.0792159
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1525 eval = 516 reject = 20
number of transient points: 248
start GMRES
current residual: 2.06862e-06
voltage residual: 0.076349
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1540 eval = 522 reject = 20
start GMRES
current residual: 2.90483e-06
voltage residual: 0.0706716
********** Shooting-Newton iteration 6 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1608 eval = 551 reject = 19
start GMRES
current residual: 2.2901e-06
voltage residual: 0.0586747
Transient Analysis
solve = 4 eval = 1 reject = 0
| CPU Time | 0.01 sec |
********** Shooting-Newton iteration 7 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1213 eval = 370 reject = 18
number of transient points: 176
start GMRES
number of GMRES iterations: 6
current residual: 1.94531e-07
voltage residual: 0.0911031
********** Shooting-Newton iteration 8 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1694 eval = 598 reject = 16
number of transient points: 291
start GMRES
current residual: 1.48727e-07
voltage residual: 0.0809109
********** Shooting-Newton iteration 9 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1438 eval = 479 reject = 15
number of transient points: 232
start GMRES
current residual: 0.000117561
voltage residual: 0.0767352
********** Shooting-Newton iteration 10 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1571 eval = 535 reject = 19
start GMRES
current residual: 6.90252e-05
voltage residual: 0.0740486
********** Shooting-Newton iteration 11 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1849 eval = 673 reject = 17
Transient time = 0.39 cpu sec, 0.4 wall sec
number of transient points: 328
start GMRES
current residual: 3.45289e-05
voltage residual: 0.0524284
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1755 eval = 636 reject = 20
number of transient points: 308
start GMRES
number of GMRES iterations: 7
current residual: 4.76934e-07
voltage residual: 0.0425428
Warning: trinit is extended by 8e-08
Transient Analysis
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1532 eval = 522 reject = 18
start GMRES
current residual: 2.65362e-05
voltage residual: 0.086306
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1547 eval = 528 reject = 18
number of transient points: 255
start GMRES
current residual: 9.33951e-07
voltage residual: 0.0811679
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1684 eval = 595 reject = 17
number of transient points: 289
start GMRES
current residual: 0.000164515
voltage residual: 0.0786161
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1352 eval = 430 reject = 20
Transient time = 0.3 cpu sec, 0.3 wall sec
| CPU Time | 0.30 sec |
number of transient points: 205
start GMRES
current residual: 3.69636e-05
voltage residual: 0.0757005
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1596 eval = 547 reject = 19
number of transient points: 264
start GMRES
current residual: 6.70267e-05
voltage residual: 0.0709174
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2039 eval = 746 reject = 18
| Peak Memory | 47.50 Mb |
number of transient points: 364
start GMRES
current residual: 3.84773e-05
voltage residual: 0.0466738
Warning: trinit is extended by 1.2e-07
Transient Analysis
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1535 eval = 524 reject = 18
number of transient points: 253
start GMRES
current residual: 9.61787e-06
voltage residual: 0.083023
********** Shooting-Newton iteration 20 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1583 eval = 542 reject = 20
start GMRES
current residual: 7.7183e-05
voltage residual: 0.0792873
********** Shooting-Newton iteration 21 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1567 eval = 532 reject = 22
start GMRES
current residual: 1.14707e-05
voltage residual: 0.0760162
********** Shooting-Newton iteration 22 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1861 eval = 680 reject = 16
number of transient points: 332
start GMRES
number of GMRES iterations: 12
current residual: 5.64886e-07
voltage residual: 0.0722452
********** Shooting-Newton iteration 23 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1672 eval = 597 reject = 17
number of transient points: 290
start GMRES
current residual: 7.99e-05
voltage residual: 0.161923
********** Shooting-Newton iteration 24 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1625 eval = 575 reject = 17
start GMRES
current residual: 1.49248e-05
voltage residual: 0.0347035
Warning: trinit is extended by 1.6e-07
Transient Analysis
Maxtrinitcycles reached. Starting SN analysis.
Transient time = 0 cpu sec, 0 wall sec
********** Shooting-Newton iteration 25 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1533 eval = 524 reject = 18
start GMRES
current residual: 9.60812e-07
voltage residual: 0.0813362
********** Shooting-Newton iteration 26 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1681 eval = 595 reject = 17
start GMRES
current residual: 0.000171278
voltage residual: 0.0787872
********** Shooting-Newton iteration 27 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1388 eval = 444 reject = 20
start GMRES
current residual: 2.32937e-06
voltage residual: 0.0759927
********** Shooting-Newton iteration 28 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1860 eval = 666 reject = 22
Transient time = 0.38 cpu sec, 0.39 wall sec
number of transient points: 322
start GMRES
current residual: 8.86555e-06
voltage residual: 0.0731382
********** Shooting-Newton iteration 29 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1915 eval = 699 reject = 23
number of transient points: 338
start GMRES
current residual: 3.49577e-06
voltage residual: 0.068408
********** Shooting-Newton iteration 30 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1534 eval = 515 reject = 19
start GMRES
current residual: 1.58031e-05
voltage residual: 0.04426
Warning: trinit is extended by 2e-07
Transient Analysis
********** Shooting-Newton iteration 31 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1548 eval = 532 reject = 18
start GMRES
current residual: 2.61692e-05
voltage residual: 0.0805991
********** Shooting-Newton iteration 32 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1548 eval = 528 reject = 18
start GMRES
current residual: 8.89946e-06
voltage residual: 0.0789665
********** Shooting-Newton iteration 33 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1378 eval = 448 reject = 18
start GMRES
current residual: 3.14665e-05
voltage residual: 0.0758705
********** Shooting-Newton iteration 34 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1651 eval = 573 reject = 17
number of transient points: 278
start GMRES
current residual: 1.13615e-06
voltage residual: 0.0725764
********** Shooting-Newton iteration 35 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1599 eval = 549 reject = 17
Transient time = 0.3 cpu sec, 0.33 wall sec
start GMRES
current residual: 4.08576e-06
voltage residual: 0.0372927
********** Shooting-Newton iteration 36 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1749 eval = 564 reject = 23
start GMRES
current residual: 3.57941e-05
voltage residual: 0.0289941
********** Shooting-Newton iteration 37 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1472 eval = 541 reject = 0
start GMRES
number of GMRES iterations: 11
current residual: 1.16269e-05
voltage residual: 0.0207633
********** Shooting-Newton iteration 38 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1475 eval = 541 reject = 0
start GMRES
current residual: 5.37471e-07
voltage residual: 0.000485721
********** Shooting-Newton iteration 39 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.07958e-09
voltage residual: 4.4737e-05
********** Shooting-Newton iteration 40 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.22986e-12
voltage residual: 1.57572e-05
********** Shooting-Newton iteration 41 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.36 cpu sec, 0.37 wall sec
| CPU Time | 0.36 sec |
start GMRES
current residual: 2.00635e-12
voltage residual: 5.18312e-06
********** Shooting-Newton iteration 42 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 7.27956e-13
voltage residual: 1.39873e-06
********** Shooting-Newton iteration 43 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.27669e-13
voltage residual: 2.16335e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2447 eval = 920 reject = 1
Transient time = 0.58 cpu sec, 0.59 wall sec
Steady-State Time Domain has converged successfully in 43 iterations
92.0% DELTA_PHAS = 309.600000 ( etc = 28.2 sec, ett = 5:31 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2113 eval = 457 reject = 37
Transient time = 0.59 cpu sec, 0.61 wall sec
start GMRES
current residual: 0.000176085
voltage residual: 0.47479
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1264 eval = 396 reject = 16
| CPU Time | 0.27 sec |
number of transient points: 190
start GMRES
current residual: 1.88869e-05
voltage residual: 0.283405
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1285 eval = 396 reject = 20
Transient time = 0.26 cpu sec, 0.28 wall sec
number of transient points: 188
start GMRES
current residual: 5.32312e-05
voltage residual: 0.121145
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1374 eval = 435 reject = 17
| CPU Time | 0.28 sec |
start GMRES
current residual: 1.10274e-05
voltage residual: 0.00486268
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1406 eval = 378 reject = 30
start GMRES
current residual: 3.03181e-05
voltage residual: 0.0238892
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1110 eval = 348 reject = 0
start GMRES
current residual: 6.57383e-07
voltage residual: 0.000857107
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1112 eval = 348 reject = 0
start GMRES
current residual: 1.84975e-11
voltage residual: 2.46976e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.28 cpu sec, 0.27 wall sec
start GMRES
current residual: 9.42215e-15
voltage residual: 1.38581e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1286 eval = 404 reject = 1
| CPU Time | 0.33 sec |
Steady-State Time Domain has converged successfully in 8 iterations
93.0% DELTA_PHAS = 316.800000 ( etc = 24.8 sec, ett = 5:31 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2427 eval = 528 reject = 46
Transient time = 0.67 cpu sec, 0.66 wall sec
| CPU Time | 0.67 sec |
number of transient points: 241
start GMRES
current residual: 7.74158e-06
voltage residual: 0.314075
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1289 eval = 406 reject = 18
start GMRES
current residual: 1.15528e-06
voltage residual: 0.0662905
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1601 eval = 555 reject = 17
number of transient points: 269
start GMRES
current residual: 1.38772e-05
voltage residual: 0.0626791
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1382 eval = 442 reject = 22
start GMRES
current residual: 2.39787e-05
voltage residual: 0.0587987
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1409 eval = 441 reject = 21
start GMRES
current residual: 1.17206e-07
voltage residual: 0.0568209
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1353 eval = 443 reject = 17
number of transient points: 213
start GMRES
current residual: 6.62285e-07
voltage residual: 0.0532671
Warning: trinit is extended by 4e-08
Transient Analysis
solve = 6 eval = 1 reject = 0
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1297 eval = 395 reject = 15
start GMRES
current residual: 1.67611e-05
voltage residual: 0.120775
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1434 eval = 486 reject = 14
number of transient points: 236
start GMRES
current residual: 2.66483e-07
voltage residual: 0.0758522
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1428 eval = 474 reject = 22
number of transient points: 226
start GMRES
current residual: 2.84887e-07
voltage residual: 0.0650708
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1501 eval = 501 reject = 23
number of transient points: 239
start GMRES
current residual: 1.23631e-06
voltage residual: 0.0624178
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1273 eval = 396 reject = 20
start GMRES
current residual: 4.93598e-05
voltage residual: 0.060555
********** Shooting-Newton iteration 12 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1510 eval = 497 reject = 19
start GMRES
current residual: 3.36695e-06
voltage residual: 0.0584518
Transient Analysis
solve = 19 eval = 2 reject = 1
Transient time = 0 cpu sec, 0.01 wall sec
********** Shooting-Newton iteration 13 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1486 eval = 507 reject = 15
| CPU Time | 0.32 sec |
start GMRES
current residual: 1.81372e-05
voltage residual: 0.107652
********** Shooting-Newton iteration 14 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1446 eval = 485 reject = 17
number of transient points: 234
start GMRES
current residual: 2.49642e-08
voltage residual: 0.0715855
********** Shooting-Newton iteration 15 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1499 eval = 502 reject = 20
start GMRES
current residual: 1.43954e-07
voltage residual: 0.0631076
********** Shooting-Newton iteration 16 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1515 eval = 526 reject = 16
Transient time = 0.33 cpu sec, 0.33 wall sec
start GMRES
current residual: 2.9038e-06
voltage residual: 0.0552052
********** Shooting-Newton iteration 17 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1399 eval = 445 reject = 23
Transient time = 0.31 cpu sec, 0.3 wall sec
number of transient points: 211
start GMRES
current residual: 4.25945e-06
voltage residual: 0.0520441
********** Shooting-Newton iteration 18 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1341 eval = 420 reject = 18
number of transient points: 201
start GMRES
current residual: 0.000225362
voltage residual: 0.038413
Transient Analysis
solve = 15 eval = 1 reject = 0
Transient time = 0.01 cpu sec, 0.01 wall sec
********** Shooting-Newton iteration 19 **************
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1513 eval = 520 reject = 14
start GMRES
current residual: 8.64292e-05
voltage residual: 0.0970133
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1384 eval = 449 reject = 17
Transient time = 0.3 cpu sec, 0.31 wall sec
number of transient points: 216
start GMRES
current residual: 8.43691e-06
voltage residual: 0.0581447
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1349 eval = 445 reject = 17
number of transient points: 214
start GMRES
current residual: 1.35822e-05
voltage residual: 0.0563593
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1522 eval = 522 reject = 16
start GMRES
current residual: 4.16057e-06
voltage residual: 0.0526268
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1629 eval = 555 reject = 19
Transient time = 0.34 cpu sec, 0.35 wall sec
| CPU Time | 0.34 sec |
number of transient points: 268
start GMRES
current residual: 2.67311e-06
voltage residual: 0.0376798
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1508 eval = 451 reject = 19
| CPU Time | 0.37 sec |
number of transient points: 432
start GMRES
current residual: 4.00522e-05
voltage residual: 0.0370633
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1274 eval = 432 reject = 0
start GMRES
current residual: 0.00028071
voltage residual: 0.555508
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.55248e-05
voltage residual: 0.144809
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1266 eval = 432 reject = 0
start GMRES
current residual: 1.6893e-05
voltage residual: 0.0408732
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1268 eval = 432 reject = 0
Transient time = 0.32 cpu sec, 0.31 wall sec
start GMRES
current residual: 9.08532e-06
voltage residual: 0.00451291
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.68555e-06
voltage residual: 0.00107809
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.17885e-10
voltage residual: 2.47808e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.82533e-11
voltage residual: 5.12717e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.26435e-11
voltage residual: 3.96413e-08
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.96105e-12
voltage residual: 4.05195e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1980 eval = 696 reject = 1
Transient time = 0.49 cpu sec, 0.49 wall sec
| CPU Time | 0.50 sec |
Steady-State Time Domain has converged successfully in 33 iterations
94.0% DELTA_PHAS = 324.000000 ( etc = 22.4 sec, ett = 5:42 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2120 eval = 430 reject = 40
start GMRES
current residual: 0.000475215
voltage residual: 1.77828
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1444 eval = 396 reject = 18
number of transient points: 189
start GMRES
current residual: 0.0001637
voltage residual: 0.0574236
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1380 eval = 462 reject = 16
number of transient points: 223
start GMRES
number of GMRES iterations: 4
current residual: 7.3185e-06
voltage residual: 0.0301108
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1504 eval = 425 reject = 30
number of transient points: 395
start GMRES
current residual: 9.86063e-05
voltage residual: 0.0285768
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1286 eval = 395 reject = 0
start GMRES
current residual: 0.000313329
voltage residual: 0.646391
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1185 eval = 395 reject = 0
start GMRES
current residual: 9.8638e-05
voltage residual: 0.171065
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1183 eval = 395 reject = 0
start GMRES
current residual: 2.40765e-05
voltage residual: 0.0587148
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1184 eval = 395 reject = 0
start GMRES
current residual: 1.18179e-05
voltage residual: 0.0103467
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.28091e-07
voltage residual: 0.000703329
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.88102e-09
voltage residual: 2.19919e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.27623e-14
voltage residual: 3.55687e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
solve = 1866 eval = 631 reject = 0
Steady-State Time Domain has converged successfully in 11 iterations
95.0% DELTA_PHAS = 331.200000 ( etc = 18.9 sec, ett = 5:43 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1827 eval = 362 reject = 38
Transient time = 0.49 cpu sec, 0.52 wall sec
start GMRES
current residual: 0.00646213
voltage residual: 1.59095
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1261 eval = 404 reject = 14
start GMRES
current residual: 2.35712e-05
voltage residual: 0.0394447
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1466 eval = 413 reject = 23
Transient time = 0.36 cpu sec, 0.36 wall sec
number of transient points: 390
start GMRES
current residual: 0.000271433
voltage residual: 0.0361746
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1221 eval = 390 reject = 0
start GMRES
current residual: 0.000512091
voltage residual: 0.602027
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1197 eval = 390 reject = 0
start GMRES
current residual: 8.501e-05
voltage residual: 0.150304
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1185 eval = 390 reject = 0
start GMRES
current residual: 1.61873e-05
voltage residual: 0.0479351
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1184 eval = 390 reject = 0
start GMRES
current residual: 1.17331e-05
voltage residual: 0.0107996
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 8.37017e-07
voltage residual: 0.000930015
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1183 eval = 390 reject = 0
start GMRES
current residual: 1.21504e-09
voltage residual: 4.82916e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 5.60378e-13
voltage residual: 4.01545e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1844 eval = 612 reject = 1
| CPU Time | 0.44 sec |
Steady-State Time Domain has converged successfully in 10 iterations
96.0% DELTA_PHAS = 338.400000 ( etc = 15.1 sec, ett = 5:43 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1709 eval = 356 reject = 38
Transient time = 0.47 cpu sec, 0.48 wall sec
| CPU Time | 0.47 sec |
number of transient points: 159
start GMRES
current residual: 0.00725773
voltage residual: 1.38501
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1262 eval = 377 reject = 17
number of transient points: 180
start GMRES
current residual: 0.000129519
voltage residual: 0.0600612
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1231 eval = 396 reject = 18
start GMRES
current residual: 1.19289e-05
voltage residual: 0.0300622
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1346 eval = 362 reject = 28
Transient time = 0.34 cpu sec, 0.33 wall sec
number of transient points: 334
start GMRES
current residual: 0.000107139
voltage residual: 0.0294474
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1160 eval = 334 reject = 0
Transient time = 0.29 cpu sec, 0.28 wall sec
start GMRES
current residual: 0.000439864
voltage residual: 0.798545
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1044 eval = 334 reject = 0
Transient time = 0.27 cpu sec, 0.26 wall sec
start GMRES
current residual: 5.41155e-05
voltage residual: 0.186679
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1040 eval = 334 reject = 0
start GMRES
current residual: 1.88344e-05
voltage residual: 0.0216927
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1042 eval = 334 reject = 0
Transient time = 0.26 cpu sec, 0.27 wall sec
start GMRES
current residual: 6.01451e-06
voltage residual: 0.00616016
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.21433e-07
voltage residual: 0.000263507
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.76761e-10
voltage residual: 3.45082e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.31839e-16
voltage residual: 2.98409e-12
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1673 eval = 542 reject = 1
Transient time = 0.42 cpu sec, 0.43 wall sec
| CPU Time | 0.42 sec |
97.0% DELTA_PHAS = 345.600000 ( etc = 11.5 sec, ett = 5:44 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1684 eval = 348 reject = 32
start GMRES
current residual: 0.0143747
voltage residual: 1.65234
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1348 eval = 426 reject = 24
start GMRES
current residual: 0.000257526
voltage residual: 0.0215737
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1357 eval = 415 reject = 23
start GMRES
current residual: 0.000200888
voltage residual: 0.0104303
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1163 eval = 392 reject = 0
start GMRES
current residual: 4.67067e-06
voltage residual: 0.0105294
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1165 eval = 392 reject = 0
start GMRES
current residual: 3.20025e-07
voltage residual: 0.000529563
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 1.12754e-09
voltage residual: 2.15768e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 6.67973e-14
voltage residual: 4.05902e-11
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1851 eval = 636 reject = 1
Transient time = 0.48 cpu sec, 0.48 wall sec
| CPU Time | 0.48 sec |
98.0% DELTA_PHAS = 352.800000 ( etc = 7.6 sec, ett = 5:43 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2099 eval = 525 reject = 39
Transient time = 0.57 cpu sec, 0.59 wall sec
| CPU Time | 0.58 sec |
start GMRES
current residual: 1.5828e-06
voltage residual: 0.0558518
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1228 eval = 426 reject = 16
start GMRES
current residual: 2.0453e-06
voltage residual: 0.00363346
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1427 eval = 431 reject = 18
number of transient points: 413
start GMRES
current residual: 0.00108855
voltage residual: 0.00188267
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1169 eval = 413 reject = 0
start GMRES
current residual: 1.56648e-07
voltage residual: 0.0107869
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 3.69975e-09
voltage residual: 0.00127869
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 2.86808e-11
voltage residual: 8.25696e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.74447e-14
voltage residual: 2.58987e-10
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2271 eval = 819 reject = 1
Transient time = 0.6 cpu sec, 0.6 wall sec
99.0% DELTA_PHAS = 360.000000 ( etc = 3.8 sec, ett = 5:43 )
Input period: 2e-09
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1711 eval = 323 reject = 35
Transient time = 0.48 cpu sec, 0.52 wall sec
number of transient points: 144
start GMRES
current residual: 3.2477e-07
voltage residual: 0.00686851
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1503 eval = 609 reject = 10
| CPU Time | 0.45 sec |
number of transient points: 599
start GMRES
current residual: 8.05837e-07
voltage residual: 0.515853
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1283 eval = 599 reject = 0
| CPU Time | 0.40 sec |
start GMRES
current residual: 1.51751e-07
voltage residual: 0.00893986
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1284 eval = 599 reject = 0
start GMRES
current residual: 3.14402e-08
voltage residual: 0.00234227
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 1282 eval = 599 reject = 0
Transient time = 0.39 cpu sec, 0.41 wall sec
| CPU Time | 0.39 sec |
start GMRES
current residual: 1.19304e-08
voltage residual: 0.000502534
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.36 cpu sec, 0.4 wall sec
start GMRES
current residual: 4.32955e-09
voltage residual: 4.03183e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.38 cpu sec, 0.41 wall sec
| CPU Time | 0.38 sec |
start GMRES
current residual: 1.50724e-09
voltage residual: 1.3878e-05
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
start GMRES
current residual: 4.80971e-10
voltage residual: 4.46756e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.4 cpu sec, 0.41 wall sec
start GMRES
current residual: 1.19634e-10
voltage residual: 1.13175e-06
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
Transient time = 0.38 cpu sec, 0.4 wall sec
start GMRES
current residual: 1.48761e-11
voltage residual: 1.46497e-07
Transient Analysis
20% ...
40% ...
60% ...
80% ...
100%
solve = 2542 eval = 1198 reject = 0
Transient time = 0.76 cpu sec, 0.78 wall sec
| CPU Time | 0.77 sec |
30 unique instance models are loaded.
Compressing
finished Shooting Newton Sweep (345.5 sec)
Shooting Newton Sweep time = 345.5 cpu sec
Shooting-Newton time = 345.53 cpu sec
Total Shooting-Newton memory = 47.50 Mbytes
Resource Usage for Time Domain Analysis
| CPU Time | 345.53 sec |
--- hspicerf done [input.spi] ---
Total time = 352.22 cpu sec (5:52)
Total memory = 47.50 Mbytes
Show me all file lists.
Are the list in thread #8 not what your looking for?All top level netlist except for sub circuit definition and device model file.
Why?figure 3 is meaningless.
Remove ARTIST and PSF.Options
| Option | Value |
| ARTIST | 2 |
| OPFILE | 1 |
| PSF | 1 |
| TEMPC | 25 |
| TEMPK | 298.15 |
Never.Are the list in thread #8 not what your looking for?
Do you surely understand differerence between fig-2 and fig-3 ?Why?
*Custom Designer (TM) Version F-2011.09-SP2
*Thu Oct 22 19:35:48 2015
.GLOBAL gnd! vdd!
* Library : Thesis
* Cell : INV1_SCH
* View : schematic
* View Search List : hspice hspiceD cmos.sch cmos_sch schematic veriloga
* View Stop List : hspice hspiceD
.subckt inv1_sch in out
m0 out in gnd! gnd! nch l=0.2u w=1u m=32 ad=4.8e-13 as=4.8e-13 pd=2.96e-06 ps=2.96e-06
+ nrd=0.135 nrs=0.135
m1 out in vdd! vdd! pch l=0.2u w=3u m=32 ad=1.44e-12 as=1.44e-12 pd=6.96e-06 ps=6.96e-06
.ends inv1_sch
* Library : Thesis
* Cell : dynamicDFF
* View : schematic
.subckt dynamicdff d q rst clk
m8 net33 net40 gnd! gnd! nch l=0.2u w=1u m=20 ad=4.8e-13 as=4.8e-13 pd=2.96e-06
+ ps=2.96e-06 nrd=0.135 nrs=0.135
m7 net42 clk net33 gnd! nch l=0.2u w=1.8u m=20 ad=8.64e-13 as=8.64e-13 pd=4.56e-06
+ ps=4.56e-06 nrd=0.135 nrs=0.135
m6 net40 rst gnd! gnd! nch l=0.2u w=2u m=30 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
+ ps=4.96e-06 nrd=0.135 nrs=0.135
m2 net40 net15 net11 gnd! nch l=0.2u w=2u m=20 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m1 net11 clk gnd! gnd! nch l=0.2u w=2u m=20 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m0 net15 d gnd! gnd! nch l=0.2u w=1u m=20 ad=4.8e-13 as=4.8e-13 pd=2.96e-06 ps=2.96e-06
m9 net42 net40 vdd! vdd! pch l=0.2u w=2.5u m=20 ad=1.2e-12 as=1.2e-12 pd=5.96e-06
+ ps=5.96e-06 nrd=0.135 nrs=0.135
m5 net40 clk vdd! vdd! pch l=0.2u w=2.5u m=20 ad=1.2e-12 as=1.2e-12 pd=5.96e-06
m4 net19 d vdd! vdd! pch l=0.2u w=2.5u m=20 ad=1.2e-12 as=1.2e-12 pd=5.96e-06
m3 net15 clk net19 gnd! pch l=0.2u w=2.5u m=20 ad=1.2e-12 as=1.2e-12 pd=5.96e-06
xi10 net42 q inv1_sch
.ends dynamicdff
* Library : Thesis
* Cell : NANDDFFV1_SCH
* View : schematic
.subckt nanddffv1_sch _rst d q rst rsta rstb clk
xi10 net38 q inv1_sch
m3 net44 clk net45 gnd! pch l=0.2u w=2.3u m=20 ad=1.104e-12 as=1.104e-12 pd=5.56e-06
+ ps=5.56e-06 nrd=0.135 nrs=0.135
m4 net45 d vdd! vdd! pch l=0.2u w=2.3u m=20 ad=1.104e-12 as=1.104e-12 pd=5.56e-06
m5 net40 clk vdd! vdd! pch l=0.2u w=2.3u m=20 ad=1.104e-12 as=1.104e-12 pd=5.56e-06
m9 net38 net40 vdd! vdd! pch l=0.2u w=2.3u m=20 ad=1.104e-12 as=1.104e-12 pd=5.56e-06
m10 net41 rstb net42 gnd! nch l=0.2u w=2u m=30 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m11 net40 rsta net41 gnd! nch l=0.2u w=2u m=30 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m0 net44 d gnd! gnd! nch l=0.2u w=1u m=20 ad=4.8e-13 as=4.8e-13 pd=2.96e-06 ps=2.96e-06
m1 net43 clk gnd! gnd! nch l=0.2u w=2u m=20 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m2 net40 net44 net43 gnd! nch l=0.2u w=2u m=20 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m6 net42 _rst gnd! gnd! nch l=0.2u w=2u m=35 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m7 net38 clk net39 gnd! nch l=0.2u w=2u m=20 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m8 net39 net40 gnd! gnd! nch l=0.2u w=1u m=20 ad=4.8e-13 as=4.8e-13 pd=2.96e-06
m12 net40 rst gnd! gnd! nch l=0.2u w=2u m=30 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
.ends nanddffv1_sch
* Library : Thesis
* Cell : PFDV2_SCH
* View : schematic
.subckt pfdv2_sch n1 down up out_clk ref_clk start
xddff n1 net42 net43 ref_clk dynamicdff
xnand_dn start n1 down net43 down up out_clk nanddffv1_sch
xnand_up start net42 up net43 up down ref_clk nanddffv1_sch
xi4 start net43 inv1_sch
.ends pfdv2_sch
* Library : Thesis
* Cell : CPV2_SCH
* View : schematic
.subckt cpv2_sch down up vctrl+ vctrl-
m43 net13 net13 vdd! vdd! pch l=0.96u w=1.92u m=4 ad=9.216e-13 as=9.216e-13 pd=4.8e-06
+ ps=4.8e-06 nrd=0.135 nrs=0.135
m42 net15 net13 vdd! vdd! pch l=0.96u w=1.92u m=4 ad=9.216e-13 as=9.216e-13 pd=4.8e-06
m41 net12 net13 vdd! vdd! pch l=0.18u w=1.68u m=4 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
+ ps=4.32e-06 nrd=0.135 nrs=0.135
m31 vctrl- net4 net1 vdd! pch l=0.18u w=1.68u m=4 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m30 net1 net3 vdd! vdd! pch l=0.18u w=1.68u m=1 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m29 vctrl+ net4 net6 vdd! pch l=0.18u w=1.68u m=4 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m28 net4 net4 net9 vdd! pch l=0.18u w=1.68u m=4 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m27 net6 net8 vdd! vdd! pch l=0.18u w=1.68u m=1 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m26 net9 gnd! vdd! vdd! pch l=0.18u w=1.68u m=4 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m25 net5 net11 vdd! vdd! pch l=0.18u w=1.68u m=4 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m24 net11 net11 vdd! vdd! pch l=0.18u w=1.68u m=4 ad=8.064e-13 as=8.064e-13 pd=4.32e-06
m45 net15 net15 gnd! gnd! nch l=0.18u w=2u m=4 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m44 net13 net15 net14 gnd! nch l=0.18u w=2u m=4 ad=9.6e-13 as=9.6e-13 pd=4.96e-06
m40 net2 up gnd! gnd! nch l=0.18u w=0.96u m=1 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
+ ps=2.88e-06 nrd=0.135 nrs=0.135
m39 vctrl- net5 net2 gnd! nch l=0.18u w=0.96u m=4 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
m38 net7 down gnd! gnd! nch l=0.18u w=0.96u m=1 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
m37 net10 vdd! gnd! gnd! nch l=0.18u w=0.96u m=4 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
m36 vctrl+ net5 net7 gnd! nch l=0.18u w=0.96u m=4 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
m35 net5 net5 net10 gnd! nch l=0.18u w=0.96u m=4 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
m34 net4 net12 gnd! gnd! nch l=0.18u w=0.96u m=4 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
m33 net11 net12 gnd! gnd! nch l=0.18u w=0.96u m=4 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
m32 net12 net12 gnd! gnd! nch l=0.18u w=0.96u m=4 ad=4.608e-13 as=4.608e-13 pd=2.88e-06
xi1 down net3 inv1_sch
xi0 up net8 inv1_sch
r24 net14 gnd! r=120
.ends cpv2_sch
* Library : Thesis
* Cell : CPV1_tb
* View : schematic
xi12 vdd! down up out_clk ref_clk start pfdv2_sch
v17 start gnd! dc=0 pulse ( 0 1.8 500p 1p 0 500n 1000n )
v16 out_clk gnd! dc=0 pulse ( 0 1.8 .5n 10p 10p .5n 1n )
v2 ref_clk gnd! dc=0 pulse ( 0 1.8 0 10p 10p .5n 1n )
v5 vdd! gnd! dc=1.8
c18 vctrl- gnd! c=.8p
c7 vctrl+ gnd! c=.8p
xi17 down up vctrl+ vctrl- cpv2_sch
I also doubt myself :-DDo you surely understand differerence between fig-2 and fig-3 ?
My advices are not reflected at all.*Custom Designer (TM) Version F-2011.09-SP2
.GLOBAL gnd! vdd!
[.....] snipped
v5 vdd! gnd! dc=1.8
fig-2 and fig-3 show different type PFD.I also doubt myself
Can you please tell me?
.option PARHIER = LOCAL
.option ARTIST=2 PSF=2
.temp 25
.GLOBAL gnd! vdd!
.param fund_period=2n
.param delta_phase_deg=0.0
.param tdelay='(delta_phase_deg/360)*fund_period'
v17 start gnd! dc=0 pulse ( 0 1.8 500p 1p 0 0.5 1)
v16 out_clk gnd! dc=0 pulse(0 1.8 '1.1*fund_period+tdelay'
+ 5p 5p 'fund_period/2' fund_period)
v2 ref_clk gnd! dc=0 pulse(0 1.8 '1.1*fund_period'
v5 vdd! gnd! dc=1.8
.tran .1n 75n start=0
.sn tres='fund_period/10' period=fund_period
+ trinit='5*fund_period' maxtrinitcycles=5
+ sweep delta_phase_deg lin 101 -360 360
.op All 0
.option opfile=1 split_dp=1
.probe i1(c7)
.probe i1(c18)
.end
I think the sweep range you did is just fine. ThanksIf you would like to expand range of delta_phase, expand sweep range
