doom3cool3
Newbie level 6
- Joined
- Dec 26, 2012
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 2
- Trophy points
- 1,281
- Activity points
- 1,371
Hello,just as the title,I want to build a controllable high voltage power supply,which means I can adjust the input and get the different output high voltage.
I use the variac as input which can operate in a range of 0~260VAC with 5A,then connect with a Cockcroft–Walton circuit.I used 1N4007 as the diodes and 104/1KV as capacitors.
And I made it 10 stages.
Will this way work? Or will it be danger ?
Thanks for giving me some idea.
