sam1145
Junior Member level 3
Heating up mosfets in an inverter while charging with the same inverter
am trying to build an inverter of 3.5kva,so far it is working but not up satisfaction because my transformer first of all was heating up seriously when charging then i replaced it with a higher rating next the mosfets started heating also beyond normal, now i am stock i need help don't know what to do next,.am using irf150[2x6] pieces and sg3524 for the oscillation...
24vdc
50hz
modified sine wave
about 3.5kva load
220vac
about 15amps
so that 220vac is as both input for charging and output from inverter
output with a curent of about 20amps
2x12v battery of 200ah] to give 24v 200ah
24vdc
50hz
modified sine wave
about 3.5kva load
220vac
about 15amps
