iVenky
Advanced Member level 2
- Joined
- Jul 11, 2011
- Messages
- 584
- Helped
- 37
- Reputation
- 76
- Reaction score
- 35
- Trophy points
- 1,318
- Location
- College Station, Texas
- Activity points
- 6,124
I am using Atmega 16. Here's the circuit diagram.+
I have used HyperTerminal software to send the data from my computer. ( I followed as it was given in this video:
AVR Microcontroller (Atmega16) Serial Communication (USART) - YouTube )
Here's the code
// Program to receive data from USART and displaying it on LCD
Receive data from serial port and display it on LCD
LCD DATA port----PORT A
ctrl port------PORT B
rs-------PB0
rw-------PB1
en-------PB2
using external clock frequency 12MHz
#define F_CPU 12000000UL
#define USART_BAUDRATE 9600 // Baud Rate value
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
#include<avr/io.h>
#include<util/delay.h>
#define LCD_DATA PORTA //LCD data port
#define ctrl PORTC
#define en PC2 // enable signal
#define rw PC1 // read/write signal
#define rs PC0 // register select signal
void LCD_cmd(unsigned char cmd);
void init_LCD(void);
void LCD_write(unsigned char data);
void LCD_clear();
void usart_init();
void usart_putch(unsigned char send);
unsigned int usart_getch();
int main()
unsigned char value;
DDRA=0xff; // LCD_DATA port as output port
DDRC=0x07;
_delay_ms(100); // signal as out put
init_LCD(); //initialization of LCD
_delay_ms(50); // delay of 50 milli seconds
usart_init(); // initialization of USART
while(1)
value=usart_getch(); // Call a function to get data from serial port
LCD_cmd(0xC0); // to go in second line and zeroth position on LCD
LCD_write(value); // write data to LCD
return 0;
void init_LCD(void)
LCD_cmd(0x38); // initialization of 16X2 LCD in 8bit mode
_delay_ms(50);
LCD_cmd(0x01); // clear LCD
_delay_ms(50);
LCD_cmd(0x0E); // cursor ON
_delay_ms(50);
LCD_cmd(0x80); // ---8 go to first line and --0 is for 0th position
_delay_ms(50);
return;
LCD_DATA=cmd;
ctrl =(0<<rs)|(0<<rw)|(1<<en);
_delay_ms(50);
ctrl =(0<<rs)|(0<<rw)|(0<<en);
_delay_ms(50);
return;
LCD_DATA= data;
ctrl = (1<<rs)|(0<<rw)|(1<<en);
_delay_ms(50);
ctrl = (1<<rs)|(0<<rw)|(0<<en);
_delay_ms(50);
return ;
void usart_init()
UCSRB |= (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
UCSRC |= (1 << URSEL) | (1<<USBS) | (1 << UCSZ0) | (1 << UCSZ1);
// Use 8-bit character sizes
UBRRL = BAUD_PRESCALE;
// Load lower 8-bits of the baud rate value into the low byte of the UBRR register
UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value..
// into the high byte of the UBRR register
while ((UCSRA & (1 << RXC)) == 0);
// Do nothing until data has been received and is ready to be read from UDR
return(UDR); // return the byte
I see the cursor in the LCD screen so I guess there is no problem with the lcd code but the problem is that I can't send the data from my computer. When I type the data in HyperTerminal nothing happens in the LCD screen. Where does the problem lie?
Here's the code
rs-------PB0
rw-------PB1
en-------PB2
#include<avr/io.h>
#define ctrl PORTC
void LCD_clear();
void usart_init();
int main()
DDRC=0x07;
while(1)
return 0;
void init_LCD(void)
_delay_ms(50);
_delay_ms(50);
_delay_ms(50);
_delay_ms(50);
return;
LCD_DATA=cmd;
_delay_ms(50);
_delay_ms(50);
return;
LCD_DATA= data;
_delay_ms(50);
_delay_ms(50);
return ;
void usart_init()
