- Joined
- Jan 22, 2008
- Messages
- 53,027
- Helped
- 14,788
- Reputation
- 29,863
- Reaction score
- 14,266
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 300,708
piezo amplifier 500v
The sitemaps aren't understandable, I think. Just garbage.
Basically, you can expect that a solution with a rather small transformer is possible, cause it already exists. That's reassuring. I have difficulties to match the impedance measurement at 200 kHz (very lossy capacitor) with the waveforms. Has it been taken under identical conditions (e. g. medium load) and with the same device? It seems not helpful in calculating a resonant transformer that apparently exists ih the measurements. A solution could be to treat the impedance as unknown in detail and design the transformer by trial and error. The basic properties can be determined with lower voltage, without considering 1000 V isolation. That makes it easier to modify the transformer by simply adding or removing some turns.
