trastikata
I have experience in the digital domain but almost none in the analog domain. So I need some advise on the following issue.
I have a design with micro controller and small FM transmitter (I am using FM module with no option to regulate the power output) where the RF output is connected straight to an antenna, hence transmitting at full power. I would like to have the option to switch between two levels of transmitting power to the same antenna - full and reduced.
The only thing that I know is using a PIN diode as switch so I was thinking to use three pin diodes that will be commanded from the MCU to switch between the two paths and an unbalanced T attenuator on one of the paths.
I was wondering if there is some more elegant way to achieve that?
Thank you
Thank you
