tahir4awan
Full Member level 4
Someone replied for the question what are active and passive devices. The answer was,
"Active devices : the devices in which the electron flow( current) can be controlled electrically.
Passive devices : the devices where electron flow ( current ) cannot be controlled electrically.
Linear and Nonlinear generally applies to Active devices, even if there is no Passive device perfect linear.
Following the above definition, diode is an Active device."
It is confusing that many people say that diode is an active device while some say that it is a passive device because there is now control pin in diode.
what do you thing is diode an active or passive device?
