danadakk
Advanced Member level 6
- Joined
- Mar 26, 2018
- Messages
- 3,595
- Helped
- 429
- Reputation
- 881
- Reaction score
- 822
- Trophy points
- 113
- Activity points
- 15,410
For the 2'ond time ignore the earlier Newark link, posted in error. I do not support its
conclusion. They are a distributor of parts, nothing more.
If I eliminate noise, which causes deviations from true value, then I have improved accuracy.
And yes noise causes impact on accuracy AND precision. Per above wiki definitions.
This discusses INL and DNL reduction thru a cycling and averaging technique
Excellent comment for both of us.
And then we have this :
Note I had an error above, by not noting that noise also impacts precision, now corrected.
Knight
Accuracy and precision are two measures of observational error. Accuracy is how close a given set of measurements (observations or readings) are to their true value, while precision is how close the measurements are to each other.
You of course read the ap note on HW averaging reducing offsets, per your inquiry above ?Like the last time: I asked you to focus your example on accuracy errors like, offset, gain, linearity (Read the document of your own NEWARK link)
* But you provided an example for a precision error (noise. But not offset, gain, linearity).
If you are not willing learn ... how can we expect forum members to learn?
Knight
