dope40
Member level 4
I am trying to make a frequency counter using a pic 16f882 .
The idea is using TMR1 to measure the pulse period and use it to get the frequency.
I am using a 16 MHz crystal so that TMR1 increases every 250ns ( FOSC/4 and 1:1 Prescale Value )
Here is the code :
I am feeding 100 Hz in RB0 pin. Based on that i am expecting the value of Total to be 40000 , but i get around 19000 ( using PICKit 3 as debugger , also my freq. gen is not ideal so i am expecting some fluctuation . Still i get half of what i am expecting ).
The interrupt is on the rising edge.
Does anyone know what i am doing wrong ?
P.S .... Also i failed to mention , for the purposes i need it the duty cycle is high ( ~ 90 % ) , but still i think that shouldn't be a problem , right ?
Here is the code :
#include <xc.h>
// CONFIG1
#pragma config FOSC = EXTRC_CLKOUT// Oscillator Selection bits (RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, RC on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON // RE3/MCLR pin function select bit (RE3/MCLR pin function is MCLR)
#pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = ON // Brown Out Reset Selection bits (BOR enabled)
#pragma config IESO = ON // Internal External Switchover bit (Internal/External Switchover mode is enabled)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
#pragma config LVP = OFF // Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming)
// CONFIG2
#pragma config BOR4V = BOR40V // Brown-out Reset Selection bit (Brown-out Reset set to 4.0V)
#pragma config WRT = OFF // Flash Program Memory Self Write Enable bits (Write protection off)
#define _XTAL_FREQ 16000000
#include <stdio.h>
#include <stdlib.h>
int aa, bb, state ;
unsigned long overflow, total ;
void interrupt tc_int()
if (T1CONbits.TMR1ON == 0) {
T1CONbits.TMR1ON = 1 ; // start timer
INTCONbits.INTF = 0 ; // clear flag
else if (T1CONbits.TMR1ON == 1) {
T1CONbits.TMR1ON = 0 ; // disable TMR1
total =(TMR1H<<8)|(TMR1L);
INTCONbits.INTE = 0 ; // disable interupt
TMR1H=0;
TMR1L=0;
// total =(4000000/total);
INTCONbits.INTE = 1; //Enable RB0/INT external Interrupt
INTCONbits.INTF = 0; // clear the interrupt flag
void Init(void){
TRISA = 0xFF; //set all digital I/O to inputs
TRISB = 0xFF;
TRISC = 0xFF;
ANSEL = 0x00; //disable all analog ports
ANSELH = 0x00;
T1CON=0X00;
TMR1H=0;
TMR1L=0; // intialization of timer one prescalar and internal clock
INTCONbits.GIE = 1; //Enable Global Interrupt
OPTION_REGbits.INTEDG = 0; //Interrupt on rising edge
void main(void)
Init() ;
while(1)
