YEAR_
Junior Member level 3
- Joined
- Dec 6, 2011
- Messages
- 25
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Activity points
- 1,410
the input to 7805 must be at least higher than the input by 1.25 v, if u can maintain that the output is guaranteed to be at 5v or 4.99v. hence the normal configuration will suffice. but I had the same problem once due to bad resonator. does your code run on many interrupt routines. you should be careful with interrupt routines, when translated in to assembly or hex they create a lot of mess.
