12VDC to 24VDC flyback converter(multiple output)
murali_dece,
attach are picture of respective taping points to measure output voltage.
Please advice.Thank you.
Hi Peggy,
Sorry i was busy and your two multimeter puzzle become brain teaser to me, finally I found that in output -2 one end of winding is connected to diode and other end(i.e black wire) you forgot to ground. in such case output-2 become open circuit. output-1 is good one end is grounded and feedback is taken from it. output-2 is open circuit scine you are not grounded black wire, when you measure with multimeter, multimeter internal resistor closes the circuit and shows the voltage of DC pulse train scince no filter across output-2 (output capacitor you are used is not in circuit with respect to S2).
when two multimeters come into picture this Ac component in S2 couples to S1 and influence feedback, resulting in voltage variation.
Scince Aux winding of your transformer carry max 200ma of current you can expect only 50mA per single output and 100mA combined. carry out load test on your power supply.
