z9u2k
Hey,
While fixing my about-15-years-old washing machine, I encountered a device I'm not familiar with inside it I was hoping someone could help me understand.
The thermostat I found was a small box that had a ribbon connecting it to the control box, two wires going out to the heater, and a single wire connected to something I can only assume is the water's temperature sensor, as it sits partially inside the drum.
It is a little metal cylinder (about an inch in length and half an inch in diameter) with two leads - One connected to the thermostat, and the other isn't connected at all. Instead, it is wrapped with an insulator, and the wire going to the thermostat is wound around it about two or three times.
I was wondering how this device is used to measure temperature with only one wire. I'm familiar with NTCs, but they require current. I was thinking along the line of AC going in the wire (like an antenna) and the device is inducing interference into the signal in proportion to its temperature (perhaps with a phase lag). This could allow the thermostat to filter out the original signal and measure the interference - but I'm not too sure about the details...
Can someone shed some light? Thanks!
