R
red_alert
I think I'll go with a single (and bigger) ferrite core transformer (E71/3C90) running at 50 kHz, to minimize the switching losses (175A). Is it a good option to insert a capacitor in the transformer's primary circuit to avoid any DC component (I've seen it in various schematic diagrams)?
The primary inductance will be 10uH (one turn). I guess I'll have to use 6 layers of copper foil (0.2 x 35 mm) to build the primary winding. The secondary winding will have 18 turns.
So it's OK to wind them like that:
P (1 two-layer turn) - S (6 turns) - P (1 two-layer turn) - S (6 turns) - P (1 two-layer turn) - S (6 turns)
.. then connect all the primary windings (3 x 1 turn) in parallel and all the secondary turns (3 x 6 turns) in series?
PS: If the leakage inductance will be a problem, I'll try a resonant design later.
