Kurenai_ryu
Advanced Member level 2
o yes, on the manual ,it specifies an 4x4 keypad with the last column as letters 'A' 'B' 'C' and 'D' , as 'D' as a VALID button, as you put an 3x4keypad, missing the last column, the 'D' button was outside labeled as VALID. now you must press 'D' (uppercase! don't forget!) to send the VALID button...
With a little patience it works well, I got to change password, set areas and set the alarm... (don't forget to put password and 'blank' button '1111-' or acept the data with the VALID button 'D' uppercase)
i'll got to work on an specific terminal for this projetc, I'm planning to use a PIC16f628 OR a PIC16F88 let me know Which one do you prefere or do you have at hand or can get easily... (tye ol' 16f84 is too old for an eficient work... need one with integrated usart...)
checking the datasheets... my work would be quite easier with an 16f628 than a 16f88 so if you can get both, let me choose an 16f628, anyway i'll wait for your answer...
