dgnani
Advanced Member level 1
not sure what simulator are you using? if spectre useI didn't understand this and I think that's the reason I'm having a difficulty on plotting the data. I did include these codes the .print vdb(n5) vdb(n3). AOL(dB) = N5(dB) - N3(dB). Is this correct? I inserted the "vn1 vn1 gnd dc 0V ac 1V" at the positive input of the OP.
dB20(V(VN5) / (V(N1)-V(N3)))
phase(V(N5) / (V(N1)-V(N3)))
for eldo just plot
it will give both magnitude in dB and phase automatically
your source has to break the wire not drive it, it should be something like
vn1 n1 n1_old dc 0V ac 1V
where you rename all other previous n1 nodes as n1_old except for the opamp input which is still n1
But right now it does not matter (at least not to solve your problem)...
... I finally noticed that your N1 and N3 do track nicely so gain was there, I misunderstood post #8 where you described N1 and N3 behavior I thought they were at different voltages
Congratulation Leo_o2, the new plots show clearly a second OP, now it is just a question of stabilizing the loops, a good cap in the right place will probably do the trick...
I guess allennlowaton you can try that next to see how your loop gain looks in the circuit, just break the output wire instead of the input one and look at
L=v(n5_opamp)/v(n5)
after inserting
vn5 n5 n5_opamp dc 0V ac 1V
and connecting the opamp output to n5_opamp instead of n5
do this at the OP where you see the oscillation
The circuit apparently still works but you'll like it better w/o the ringing, I'm sure
