speedEC
Full Member level 6
Dear all,
I have made a battery charging circuit using "L200" for my 6v, 4.2 mAh sealed alkaline battery (usually seen at emergency lamp). The circuit is based on the datasheet of L200.
I have used 9v, 500mA AC to DC Adopter for charging the battery. When I measure the voltage output on the circuit (Not Connected to Battery), the multimeter shows 9v. The voltage output on PIN5 is 5.49v. 10K Resistor (R3) placed between PIN5 and PIN2. So the output current (max) is: I = ((V5 - 2) / R3). i.e. (5.49v - 2) / 10K = 0.349 amps or 349mA. Right? But, I don't know how to measure the amps flowing into the battery. I can't able to know whether my battery is charging correctly or not. Can anyone help me i this regard.
pmk
pmk
