Antenna radiation pattern
jabidof
Member level 5
Member level 5
change the radiation pattern
Hello everybody,
I have the following issue to solve. Imagine you have a dipole or PIFA antenna for a given UHF frequency. Now, depending on the position of the feeding point you'll choose, you'll get different input impedance, i.e. theoretically from 0 to infinity [Ohms].
1. Does the radiation pattern of the antenna change with a change in the feeding point position?
2. Considering we're always power-matched to the input impedance of the antenna, does the efficiency of the antenna change with a change in the feeding point position?
Thanks for your appreciated help :),
Jpc
antenna radiation pattern matching
position is very important ,or you can get low gain
you can find some theary in some book of antenna
Reactions: Y_P
    Y_P
the structure determines the radiation pattern ,so ,when you change the feeding point ,the pattern doesn't change ,but the vswr changes as well as the efficiency
in printed antennas or the same structure the feeding point change
the current and the modes so it change also the pattern like center feed
and end feed in patch. in some ways it change also the polarization from
linear to circular.
PL
    jabidof
Consider an extreme case: two antennas (e.g. two pieces of wire) with very weak mutual coulpling or no coupling at all. This can be considered “an antenna” (a single “antenna”; why not?). Obviously, the radiation pattern, the matching, the efficiency, the polarization, etc. change if you change the feeding point between one to the other.
Z
