darkseid
Hi
I am trying to design a rail to rail input CMOS differential amplifier. I have attached the circuit file.
Bias current source: 50u A
All transistors have W/L = 32:1.
However the output gain is only 30 dB. Is there a way to boost the output gain. I tried using a cascode amplifier second stage but its not working. In fact is gain dropped drastically.
Kindly advice a solution
