mydreamhouse
skill language
who has the reference of cadence skill language
rimser9 said:sklanguser.pdf and skdfref.pdf are the best to start with to learn skill programming. If u want to learn it quick, dont waste time reading it from start to end. Start writing scripts.
I suggest u right a script for Placement. Inputs will be spice file, Pcells library name and then the script should create cells and pcells, sub-blocks in the Top-level library.
