The equivalent of PAL007A IC
king25
Newbie level 2
Newbie level 2
Hy!
I have Pioneer car-radio and the ic PAL007a is dead.
Im looking for PAL007A in Slovenia and i didnt find it :(
I put in TDA7560 and the radio work fine for about 1hour,than he stoped working :(
Can anibody please tell me what should i poot instade of PAL007A ??
Are TDA7560 and TDA7386 OK ??? Or i must put only original ...
Please help me!
Sorry for my bad english.
pal007a pioneer
You may want to try **broken link removed** to send inquiry of PAL007A to USComponent.com, a professional sourcing web site using by purchasing and engineers. Hopefully it helps.
pac011a replacement
PA501 STK082 LIN-IC
PA0016 14-DIP LIN-IC PIONEER
PA0017 9-SIP LIN-IC PIONEER
PA023AD 14-DIP LIN-IC PIONEER
PA0026 LIN-IC PIONEER
PA0034A VHIPA0034A/1 42-SDIP LIN-IC PIONEER
PA0045 LIN-IC PIONEER
PA0049 LIN-IC PIONEER
PA0058A 30-SDIP LIN-IC PIONEER
PA2006 LAP502
PA2012 LIN-IC PIONEER
PA2018 TA8251AH LIN-IC PIONEER
PA2019A TA8251AH LIN-IC PIONEER
PA2024A LIN-IC
PA3001A 16-DIP LIN-IC PIONEER
PA3002 UPC1188H ( HA1397 CUT OFF 1ST 2LEG) 10-ZIP LIN-IC PIONEER
PA3003 UPC1188H 10-ZIP LIN-IC PIONEER
PA3003 ORIG HA1397B HA1379 UPC1188H LIN-IC PIONEER
PA3005-2 HA1384 HA1388 12-SIP LIN-IC PIONEER
PA3009 LIN-IC PIONEER
PA3011 LIN-IC PIONEER
PA3018 18-DIP LIN-IC PIONEER
PA3027A SEE PA3027B PAU001A HA13150A HA13151 HA13152 HA13153 HA13154 HA13155 23-ZIP LIN-IC PIONEER
PA3029B HA13151 23-ZIP LIN-IC PIONEER
PA4001 LIN-IC PIONEER
PA5009 30-SDIP LIN-IC PIONEER
PA5010 LIN-IC PIONEER
PA5013A 56-SMFP LIN-IC PIONEER
PAC002A LA9425 LIN-IC PIONEER
PAC003A LA9420 LIN-IC PIONEER
PAC005A LA7133 LIN-IC PIONEER
PAC007A SEE STK4231V STK4231 V HYBRID-IC PIONEER
PAC008A SEE STK4044II STK4044 II HYBRID-IC PIONEER
PAC009A STK4211 II HYBRID-IC PIONEER
PAC010A SEE STK411-230E STK411-230E HYBRID-IC PIONEER
PAC011A HYBRID-IC PIONEER
PAC012A STK411-200F HYBRID-IC PIONEER
PAC013A STK410-000F HYBRID-IC PIONEER
PAL001A TDA7394V 15-ZIP LIN-IC PIONEER
PAL002A TDA7394V 15-ZIP LIN-IC PIONEER
PAL003A TDA7384A 25-ZIP LIN-IC PIONEER
PAL005A TDA7560 TDA7385A 25-ZIP LIN-IC PIONEER
PAL006A TDA7560 TDA7385A 25-ZIP LIN-IC PIONEER
PAL007A TDA7560 TDA7385A 25-ZIP LIN-IC PIONEER
Hello, i have also a problem with pioneer PD5165A witch is broken. Please tell me what CI can replace PD5165A ??? Here is a schematic Pioneer PD5165A.jpg with PD5165A from Pioneer A-450R.
No direct replacement for this circuit.
By the way, I have read your story here:
and based on that info it seems there’s no need to replace this circuit... :cool:
