Second stage PMOS Common source design problem
yefj
Hello,I am designing a two stage amplifier. my first stage amplies 33dB.
On my second stage i have gm=126u rout=105.2||249K=105.2Ohm ,so its not amplifying at all i have -5 gain.
our gain formula is A_2nd=gm*Rout
if we increase PMOS W our gm rises but our Rout gets smaller ,If we have low PMOS rds then it doesnt matter what is the NMOS RDS because it cancels it in parralel.The diagram of my circuit is attached.
How to make the second stage into 30dB amplifier?
Thanks.
See the reply to your other post - you cant make a reliable dc operating point in the amplifier unless you provide DC feedback.
your upper PMOS is on triode !!!! check VD = 1.79 and your VS = 1.8 !
Fix the dc bias transistor to have 0.9 volt at the output, you will see the gain
Reactions: yefj
    yefj
