Junus2012
Dear friends,
I have been suggested in one of my former posts to use the decoupling capacitor for the power supply rails after I finish with the design specially if I have some empty space which I can use this cap to fill in.
Most of the people I seen are using the MOS as a capacitor , why not I can use a poly capacitor for example ?
What is the value should be around of this capacitor or it can be any value.
Do we really need the decoupling capacitor for analog circuit like the case I am designing fully differential amplifier ? in my opinion the decoupling capacitors are more needed for digital circuit where the square wave signal disturb the power lines. However decoupling capacitor is also useful to improve the PSRR. Such kind of capacitors are in the range above 100 nF. So I am thinking that tens of fF which I add it may be useless.
I am not sure therefore I would like to have your kind opinion
Best Regards
Best Regards
