Junus2012
Hello dear friends,
I attached you two images of the same circuit folded cascode opamp, one from Jakb Baker and the other from Huihsing
in jakob he is bising the current source of the upper transistor using the half value of the tail current of the differential pair,
in Huijsing he is biasing using the same amount of the biasing current,
As a result the currents as you can see will be different at the down mirror .
which one of them do you thing should be better ?
Thank you in advance
