double volt-ampermeter with pic
why did 6.8k pot's in the measuring points
and one more thing you make this and using it, how much accuracy it have??????
plz dont think that I have doubt on you...i just want to know.....and thank you a lot
one more thing may i have the source files of the programing plz..
is working fine. the source cod i don`t have it. internetuser2k12 he make me the hex file, maybe he will give you the source code.
ok........what abaut the pot's??
can i chenge with fixed resister??
hello internetuser2k12......
actually i want to study it.......and i do have many questions in my mind...so if you give me the source file
but that circuit not giving ant reading with this hex file......see
Hey internetuser2k12 I can`t make a hex file for you`re cod source, i have modificated the startup mesage, but i can`t make it hex file with mikro C. Can you help me?
  • code1.txt
Here is the whole project file. It is compiled for 20 MHz and PIC16F628A
  • vlad.rar
Hey internetuser2k12 can you modify the code on my pic 16f876A because i think the first ADC input(pin2 and 3) not work.... my mstake, can you make to be pin 4 for read voltaje and pin 4 for read amps?
What do you mean by PIN 4 for voltage and PIN 4 for Read amps?
i think the adc 0 and 1 is broken, and i want to read the values whit adc 2 and 3
Here is the complete project.
  • adc v2.rar
Hi Vlad.
from the same scheme I realized another using PIC16F690 and as display a NOKIA5110 clone. What I liked most though was the realization of software.
PS: I see you're from Suceava. What a small world
Thanks man for project i solved. works pretty good now.. Lachmannmarcel interesesting project but I don`t have nokia 5110 clone display. Have a nice day.
I have also done the same thing to come to the same wall in that i could not find a hex for the project> i now am sitting here ready to test my design and need the hex to run it all.
i simply want to have the first line read LASER CNC and the secound line have V and A readings>you guys have done some nice work what file should i use for the simple v and a readings for now just to test the circuit
please and thanks
