muddasirwaheedmalik
Junior Member level 2
- Joined
- Jul 3, 2012
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,535
Him I intend to design a two step (square wave ) at the moment, inverter. power target 4KVA, input 48v DC, switching module fuji BJT 500A/2.5 KW in pairs or EUPEC 11.kW IGBT.
But the transformer and current requirements are very steep for such a load, so i intend to make an intermediate stage inverter at say 50KHZ using a much smaller EI core ferrite transformer converting 48V dc to 110 or 220V . rectify it using high power high speed diode modules some filter caps and then then switch it with power module from 110v/220v dc to 220v ac.
Reason. its more complex, more components and costly, BUT, would i be saving on the 4kva transformer which would now be requiring lesser guage wires 20 AMPS on both primary and secondary at 4KW as compared to 100Amps on primary side if i were to switch from 48v Dc ????? any suggestions????
